[Review] 77 Outdoors D25 Headlamp (18650)
249 posts / 0 new
gchart
gchart's picture
Last seen: 3 hours 41 min ago
alpg88 wrote:
if you ever feel like it, and have time could you make the base wider for 35mm band, just the base , grips are fine the way they are.
Yup, next time I’m on the computer I’ll get a version like that whipped up.
gchart
gchart's picture
Alright man, how’s this? With the grips being centered, you’ll now need supports under those too. But that’s how 3D printing goes…
alpg88
Last seen: 2 weeks 1 day ago
looks awesome, yep, will definitely need supports, but it is ok, sharp razor removes most of the marks, and they are in such location where it isn’t noticeable much, thanks gchart, again great work.
alpg88
printed one from abs, I like so much better than petg, it prints so much better, no stinging, supports come off easy, and i was able to print it laying flat. layer adhesion is great. and i can make it smooth with acetone vapor, it will look like injection molded. i used hatchbox black abs. now i got more brackets that flashlights, lol
gchart
gchart's picture
Very cool. I’ve never tried ABS. I don’t have my printer in an enclosure… that’s highly recommended for ABS, right? Is yours enclosed?
alpg88
yes, i build one myself, my printer did not come with one. i seen people use reflective emergency blankets, they are sold at walmart for few bucks, some even simply put a large cardboard box over the printer, it does the job.
alpg88
pennzy
pennzy's picture
Last seen: 51 min 34 sec ago
Could you make one for the Sofirn SP40 and sell it? The one it comes with is too tight.
alpg88
i’d print one for you no charge, but i need stl file, i can only print, i can’t design one, and i can’t test it either, since i have no sp40. if you can find stl, i’ll print you one.
gchart
gchart's picture
I no longer have my SP40, but I might be able to borrow it from the guy I sold it to.
Or… If you have calipers and can take some measurements, I can design one from the measurements. I had considered doing the same for the Convoy H1 (which I do have) if there’s interest.
pennzy
pennzy's picture
Thanks for offering but I don’t have a file.
pennzy
pennzy's picture
No calipers to take measurements but thanks.
JasonWW
JasonWW's picture
Last seen: 1 day 14 hours ago
The Sp40 has a flexible rubber holder, correct? So you can’t really use measurements from it. maybe you can put the SP40 in the D10 holder and see what needs to be changed. Adjust the width of the fingers, maybe their diameter and all the rest can be the same. Just a thought.
alpg88
i think every headlamp needs such holder, so much more convenient than a silicone one. every HL would benefit from it, imo
Agro
Agro's picture
Last seen: 35 sec ago
I was not really interested in D10 / D25 but once I learned about D20 I started reading up….
WOW.
Guys, what you’ve done is awesome. Especially gchart.
gchart wrote:
Thanks, Tom! Having the same pin mapping as the original MCU made things easier (physically). And I think it was close to 4KB when I compiled it for the 85, I didn’t really do much trimming. Next step is to try and get NarsilM and Anduril ported. But I’m sure I’ll need to switch to the x16 chips since those are available in 8KB and 16KB versions. It certainly won’t be for this headlamp though – the x16 chips are QFN.
I did a barebones build of Andruil (Emisar D1 target, Attiny85), removing literally every feature that could be removed.
Under 3K. Still has not-so-easy to remove bells and whistles like stepped ramp and LVP.
A very comfortable config without thermal regulation is under 4K easily but enabling this single feature makes the size jump to almost 5K….
Quadrupel
Quadrupel's picture
Last seen: 14 hours 14 min ago
Agro, you want headlamp without LVP ( low voltage protection) and thermal protection ? Big Smile
gchart
gchart's picture
WOW.
Agro wrote:
I wonder why did you choose RampingIOS over the more-common Andruil. Do you simply like it more? Was it easier to port to this MCU for you? Any other reason?
Thanks man! The choice of RampingIOS over Anduril was for two primary reasons:
  • RampingIOS is pretty much in one single code file and as such, was much easier to port instead hunting and pecking across 20 files (or however many Anduril uses… its a bunch IIRC)
  • In the SOIC8 footprint, the largest memory offered is currently 4KB. I knew I could get RampingIOS to fit, but I figured Anduril would be too large no matter what I stripped out. Facepalm Now I’m going to have to revisit this and see just how many features I can get packed into a 4KB build. Another thought I’ve been mulling is making an adapter PCB to mount a QFN chip (like the attiny816, 1616, or 3216) onto a SOIC8 footprint… that would be extremely versatile.
If I can find the time, I’m really hoping to get Anduril ported over to the new tinyAVR 1-Series for the OL Scratch Build contest.
alpg88
i ordered xpg3 on 16mm star, some gaskets, and reflectors, will try to see if i can get it focus properly. i like d25 but its bad beam profile is a turn off.
Photonica
Photonica's picture
Last seen: 1 week 12 hours ago
Adafruit makes a breakout board/adaptor available through Digikey. $2.95, but shipping and minimum order will eat you up. If you don’t need the wire attachment through-holes, you could probably design a sheet and have them made somewhere. You can sometimes find QFN sockets with SOIC footprint, but that would only be useful in a prototype board – they’re pretty tall.
More Photons!
Quadrupel
Quadrupel's picture
blink-blink
FET+1, Zebralight like or Anduril UI . 11$ shipped. If interested PM.
gchart
gchart's picture
I’m thinking something like this:
It’s a WIP, but shouldn’t take much to complete it. I just need to make sure I optimize the pin mapping (PIC’s ADC pins to ADC pins on the Attiny, etc). Unfortunately, the minimum board size at Oshpark is 0.25” × 0.25”. So some filing may need to be done, but I’m making it such that it won’t harm any traces.
Agro
Agro's picture
This is not a yes-no question really.
The purpose of my experiment was to find the limits. The baseline. I found it and started adding features. I ended up with something comfortable that still fit 4KB.
It didn’t feature thermal regulation but it did feature LVP (as I said, it’s not immediately possible to remove it anyway).
Would I want it? Yes, having UI tuned for my preferences matters to me more than thermal protection.
Now…there’s something that puzzles me.
Does thermal protection of Andruil really consume nearly 2 KB?
I have my reservations. I think it’s likely that either enabling it pulls some unnecessary stuff or that disabling it removes something crucial. So this 4KB Andruil build may not actually be feasible….
Quadrupel wrote:
blink-blink Tap on pic ;)) only 10$ , Sir ;))… with Zebralight like UI on board LOL
I find your driver interesting. Fair price, nice upgrade. I’m not a fan of Zebralight UI but nevertheless I may ask you to make me one at some point. ;)
Another great idea. Smile
This is already a nice budget light family. Fitting it with full Andruil for the price of MCU and a small OSHPark board would be awesome.
Actually…Sofirn upgrades these lights already. This further inexpensive tweak would make the light way better without costing them a lot. I wonder if it would be possible to convince them to make such upgrade…
gchart
gchart's picture
Well… the easy part should be done now (Oshpark link). Now just to port over the code Ughh
Alternatively, one could make a similar board using the attiny1634 and use the existing D4V2 target since it utilizes the attiny1634. I doubt you could get away with on-board programming though unless you’d manage to squeeze the pads on the underside of the board.
Just to make sure it’s clear: I no longer have a D25 headlamp and I doubt I’ll ever personally install one of these boards in a D25. But once I get this working for other flashlights, I’m sure it could port over to the D10/D25.
alpg88
spend a day watching you tube videos about 123d design, and seems like got enough skills to make a simplest design, so i made similar holder for zebralight 600 series. first one came a bit crooked, the base was not 100% parallel to the printer bed. but otherwise the holder works, holds the light pretty firm, so today i made another design, hopefully better, will try to print tonight, this one is for zebralight as well.
anyone wants stl, pm i’ll email it, i can’t upload it to imgur. now that i know how, (it was not that hard turns out) i’ll replace all my silicone holders on all headlamps.
gchart
gchart's picture
Nicely done, sir
aswang
Looks like gchart et al. is making this a blf favorite headlamp. I’m thinking of getting another one to mod with combo spot and flood optics. Anybody with ideas how to improve waterproofing on this one without sealing the top cover?
YuvalS wrote:
It looks like the perfect backup light for caving (just need to replace the driver with one that can control the 2 LEDs independently using 2 different channels tongue-out).
Please update about replacing the reflectors with TIRs. I am thinking of combine 10 and 90 degrees TIRs.
Hey @YuvalS. Have you managed to get your modified caving A6 driver to control 2 leds leds separately to work on this thing? I think this may be a perfect headlamp to test that.
Pavlo
Last seen: 4 hours 26 min ago
I have noticed a few seemingly identical versions of this headlamp, ranging from as little as $10.76 USD on AliExpress, to a whopping $92.99 CND at Lynx OGT.
Other than the battery and headband, is there any difference from all of these versions to justify such a significant price range?
gchart
gchart's picture
Only difference I’m aware of is the Sofirn D25S where they changed emitters and UI (I think those were the changes, I haven’t owned one).
aswang
!{width:75%}https://static.wixstatic.com/media/2d922d_4dd6cc3b29e7430a90545b961ff620...!
Damn that Lynx version is expensive. Looks like they have the other generic boruit models too at 10x the price. A few are even sold out!!. Even if they put zebralight level driver, leds from the best bins and improve waterproofing don’t think the price is justified for this host. At $10 though, it’s one of the best bang for buck headlamps out there.
Pavlo
I doubt the driver is any different from one model to the other. Even the green button is the same across all price variations!
