Test/review of TrustFire IMR26650 4200mAh (Red-gold) 2019
6 posts / 0 new
HKJ
HKJ's picture
Last seen: 4 hours 48 min ago
DSC_4870
Official specifications:
  • Brand: Trustfire
  • Model: IMR 26650
  • Capacity: 4200mah
  • Type: Li-ion battery
  • Voltage: 3.7V
  • Watt hour: 15.54Wh
  • Maximum discharge current: 45A
  • Size: 26.16*66mm
TrustFire%20IMR26650%204200mAh%20(Red-gold)%202019-info
A 26650 battery rated for a very high current.
DSC_4868 DSC_4869
DSC_4871 DSC_4872
DSC_4873
DSC_4874
DSC_4875
TrustFire%20IMR26650%204200mAh%20(Red-gold)%202019-Capacity
The two cells are not perfectly matched, but they can easily deliver the rated capacity. One cell died during a 30A discharge, I stopped the other due to temperature.
TrustFire%20IMR26650%204200mAh%20(Red-gold)%202019-Temp-15.0
TrustFire%20IMR26650%204200mAh%20(Red-gold)%202019-Temp-20.0
TrustFire%20IMR26650%204200mAh%20(Red-gold)%202019-Temp-30.0
TrustFire%20IMR26650%204200mAh%20(Red-gold)%202019-CapacityTimeHours
TrustFire%20IMR26650%204200mAh%20(Red-gold)%202019-Energy
TrustFire%20IMR26650%204200mAh%20(Red-gold)%202019-PowerLoadTime
TrustFire%20IMR26650%204200mAh%20(Red-gold)%202019-TripCurrent
TrustFire%20IMR26650%204200mAh%20(Red-gold)%202019-Charge
Conclusion
The batteries are not perfectly matched and cannot deliver the rated current, it is probably a good idea to stay below 20A, but they do have the rated capacity.
Notes and links
The batteries was supplied by Trustfire for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
ChibiM
ChibiM's picture
Last seen: 6 min 48 sec ago
Thanks for the test HKJ..
Does that mean that 1 battery actually can't be used anymore? Like.. really dead?
HKJ
HKJ's picture
ChibiM wrote:
Does that mean that 1 battery actually can’t be used anymore? Like.. really dead?
Yes. This sometimes happens and shows the battery has some sort of build in protection. I have also seen batteries vent and working fine afterwards (But probably not for months).
Nev
Last seen: 2 years 5 months ago
How come in the chart the 2 amp test only has 2805 mah but the the 1 amp &3amp say nearly 4500mah , is that a typo?
HKJ
HKJ's picture
Yes and no. The problem is my test station stopped during the 2A test on the A battery and did record a full discharge curve. I.e. the number is what my logfile says, but is not for a full discharge as can also be seen on the curves.
I have “fixed” it by using only the values for the B cell in the table (of course only for the 2A discharge).
Nev
Thumbs Up
