Imalent MS18 with 100,000Lumen and R90TS with 36,000Lumen
503 posts / 0 new
ZozzV6
ZozzV6's picture
Last seen: 3 days 2 hours ago
DENGOH wrote:
Martin, can the fan on based on temperature too?
Automatic active cooling for 10k will be better compared to manual cooling.
Just made a test.
10K 15 minute run. It reached 81.8°C which is a lot! No fan kicked in. But it slowly decreased output in 1-2minute steps to about 85% in 15 minutes.
ZozzV6
ZozzV6's picture
M4D M4X wrote:
they said its temperature controlled…
But just above 10k levels.
DENGOH
DENGOH's picture
Last seen: 3 weeks 6 days ago
I think easier way is to include 10k or all other levels in the active cooling protection.
Manual fan on during light on is nice too.
cool i'll see you when you get there
ZozzV6
ZozzV6's picture
Started with full battery and the start temp was 21°C
And in the glass lens center I saw some condensation after test which disappeared after cooldown. You can imagine if the head outside was more than 80°C the leds could be easily above 100°C:
DENGOH
DENGOH's picture
That’s really nice tracking graph. It tells us how the output behave.
But I find it strange the output drop in steps, not smoothly declining. Is it due to light meter resolution?
Did the 22k lumens output level drop like that too?
ZozzV6
ZozzV6's picture
DENGOH wrote:
That’s really nice tracking graph. It tells us how the output behave. Did the 22k lumens output level drop like that too?
Now it is charging again to make that one too with full batteries. Wink
M4D M4X
M4D M4X's picture
Last seen: 1 year 1 month ago
something that need to be mentioned...
PLEASE NOTE
i do not work in "reviews, deals and codes" for the time being
maybe M4D M4X will return one day, but until then:
THANK YOU FOR YEARS OF YOUR SUPPORT AND FRIENDLY CONTACTS!
Brainsick67
Brainsick67's picture
Last seen: 1 year 11 months ago
M4D M4X wrote:
something that need to be mentioned…
I must have made you do this?
I'm ThatCrazyFlashaholic 67
M4D M4X
M4D M4X's picture
of course my friend! Big Smile
every reviewer / youtuber can / should help to educate the audience i believe.
the MS18 does not look as impressive in real because the tree is blinding and my eyes adjusted to the light in my garden surprised
PLEASE NOTE
DENGOH
DENGOH's picture
That’s crazy output for a tree to blind a flashaholic. Big Smile Cool
Brainsick67
Thought so, most Beam Shots dont look good, FLASHAHOLICS look the best to me, but ill try MANUAL TONIGHT.
ZozzV6
ZozzV6's picture
The hardest thing to set up exposure same as real life. Because your eye pretty much works as between locked and automatic setting. So if you lock exposure at a low level (like 100 lumens) the levels like 5000 and above will be burned. If you set 10000 then 1000 lumens will be lower than real life. So that is why you need to compare apples to apples like I tried the MS18 with my second powerful light the MT03 TA.
Brainsick67
It is hard, i made a MS18 vs X70 vid, will upload soon, i ised differnd Exposers in the vid.
ZozzV6
ZozzV6's picture
MS18 22000 lumen level runtime test with temperature measuring:
JordanZHP
ZozzV6 wrote:
MS18 22000 lumen level runtime test with temperature measuring: !{width:80%}http://img2.indafoto.hu/3/9/134029_e227dae7eadb61c0adb17748b381f0a8/2637...!
The manual says 22,000 lumens for 67 minutes. It looks like it doesn’t really hold 22,000 lumens at all and drops to ~10,000 lumens at 30 minutes? Also, did it turn off at ~45 minutes? A little disappointing if so. Would you be able to test their claim of 10,000 lumens for 3hr 40min with a similar graph?
ZozzV6
ZozzV6's picture
It blinked the empty battery signal. Showed 11,73V so I turned it off but I think it was about to heppen any time. Disappointing it not meet the specs but show me another flashlight that can hold output over 10000 lumens more than 30 minutes Wink
For 10K just roll up to post #402
It reached 82°C after 15 minutes in 10K because no fan activation in that level. Impossibble to hold in hand and I think it is not healthy for the flashlight to run more than that in that level. So impossibble to run it for 3 hours 40 mins in 10K If you make 10 minute runs and let it cool down maybe you can reach more than 3 hours if you add the runs up but not in continuous run.
grahambo0101
Anyone have the r90tc in hand for review?
M4D M4X
M4D M4X's picture
let me know if you need something special
PLEASE NOTE
ChibiM
ChibiM's picture
Last seen: 1 week 19 hours ago
JordanZHP wrote:
ZozzV6 wrote:
MS18 22000 lumen level runtime test with temperature measuring: !{width:60%}http://img2.indafoto.hu/3/9/134029_e227dae7eadb61c0adb17748b381f0a8/2637...! !{width:80%}http://img2.indafoto.hu/3/9/134029_e227dae7eadb61c0adb17748b381f0a8/2637... The manual says 22,000 lumens for 67 minutes. It looks like it doesn’t really hold 22,000 lumens at all and drops to ~10,000 lumens at 30 minutes? Also, did it turn off at ~45 minutes? A little disappointing if so. Would you be able to test their claim of 10,000 lumens for 3hr 40min with a similar graph?
Correct. The output has a decreasing slope in output. I also have my review up if interested: https://1lumen.com/21700-reviews/imalent-ms18/
Let me know if you have any questions.
JasonWW
JasonWW's picture
Last seen: 1 day 7 hours ago
I think I was able to clean up the above post.
Brainsick67
Great review, so your not the only one that has Turbo come on by accident.
ChibiM
ChibiM's picture
Great review, so your not the only one that has Turbo come on by accident.[/quote]
Yes..it happens frequently. Although less than the first day. What do you think about the UI?
Brainsick67
Well i said some think in my Beam Shot VID, but i think it should be a press and hold to turn on, just so its a bit safer, also after its ON, you should be able to SINGLE CLICK to change modes, and a PRESS AND HOLD to go DOWN in the modes, as it sucks to have to keep going up and up just to get back down, also i was thinking instead of a DOUBLE CLICK to TURBO, it might be nice to PRESS AND HOLD the button to get TURBO, but thats if they kept the SAME UI.
JordanZHP
M4D M4X wrote:
 i try to convince them to add “4clicks activate fans” also in ON
Do you think they will add this in future versions? Would be nice for 10,000 lumens so it doesn’t become too hot to hold at 15 minutes.
ChibiM
ChibiM's picture
Yes, I think these lumenmomsters should have a better UI. The UI is easy to understand, but not as useful for this high power flashlight. Now waiting for Acebeam to make a 101,000 flashlight.
M4D M4X
M4D M4X's picture
Imalent does listen to our suggestions...
PLEASE NOTE
ChibiM
ChibiM's picture
I hope they'll listen and improve their next one. I mean having 700 or 60,000 lumens at turn on is quite a difference. Without knowing what mpde it was in. Probably a physical lockout would work, but thats a workaround a $600 light shouldn't need to have.
Brainsick67
ChibiM wrote:
I hope they’ll listen and improve their next one. I mean having 700 or 60,000 lumens at turn on is quite a difference. Without knowing what mpde it was in. Probably a physical lockout would work, but thats a workaround a $600 shouldn’t need to have.
Me to man,
grahambo0101
Dude, these guys are doing things nobody else is doing. Heat pipes, improved active cooling (improved over ms12), 100,000 lumen, all this for under $600. From what I’ve seen they do listen to our recommendations. Sure Acebeam might follow up, but that’s chicken Sh@&, it’s easy to follow up on the heels of the innovator.
JordanZHP
Oh I agree! I own a DX80 which has been great. I think with a few minor tweaks like allowing fan control on any mode, less accidental turbo activations and maybe an easier to find button (which Martin mentioned to them before it even came out) this light would be even better.
Those are all minor issues though and my only real gripe is how excited I was for their listed runtimes at 22,000 and 10,000 lumens. It appears those runtimes were only theoretical.
