Test/review of AIFECT 5V1A Mobile phone charger WHA-1U-5W
1 post / 0 new
HKJ
HKJ's picture
Last seen: 1 week 4 days ago
DSC_4442
Official specifications:
  • Input: 100V – 240V
  • Output: DC5.0V 1A (5W)
I got it from ebay dealer orico_daily_deal
DSC_4438 DSC_4439 DSC_4440 DSC_4441
DSC_4443 DSC_4446
DSC_4444 DSC_4447 DSC_4448
DSC_4445
Measurements
  • Power consumption when idle is 0.07 watt
  • Usb output is coded as usb charger (DCP)
  • Weight: 29.8g
  • Size: 76.2 × 37 × 21mm
AIFECT%205V1A%20Mobile%20phone%20charger%20WHA-1U-5W%20120V%20load%20sweep
The charger can deliver 1.1A, the voltage drops slightly before the 1A, but still within tolerances.
AIFECT%205V1A%20Mobile%20phone%20charger%20WHA-1U-5W%20230V%20load%20sweep
At 230VAC it is more stable.
AIFECT%205V1A%20Mobile%20phone%20charger%20WHA-1U-5W%20load%20test
Running the charger with 1A for one hour worked fine.
The temperature photos below are taken between 30 minutes and 60 minutes into the one hour test.
Temp6426
M1: 47.1°C, HS1: 63.1°C
HS1 is the mains transformer.
Temp6427
M1: 50.8°C, M2: 44.0°C, HS1: 52.6°C
Temp6428
M1: 58.0°C, HS1: 61.4°C
Temp6429
HS1: 56.0°C
Temp6430
M1: 43.0°C, HS1: 62.1°C
10ohm
At 0.5A the noise is 24mV rms and 197mVpp.
5ohm
At 1A the noise is 29mV rms and 184mVpp, this is low noise
Tear down
DSC_4758
Some pressure with my vice and a bit breaking with a screwdriver and the lid was off.
DSC_4759
There is a fusible resistor (FR1) as fuse, two mains smoothing capacitors (C1 & C2) with a inductor (L1) between. Between mains and low volt side is the usual safety capacitor. The transformer has extended leads on the low volt side to increase creepage distance.
DSC_4761
DSC_4762 DSC_4764
DSC_4763
DSC_4760
On this side is the bridge rectifier and the switcher (U1: OB25133 5W). On the low volt side is the rectifier diode (D3) and for some reason somebody has cut into it (May have been the pressure when I opened it). This diode is not very large and do not need to be on a 1A power supply.
DSC_4765
DSC_4768
The isolation distance is nearly 6mm, this is slightly low, but nothing serious.
Testing with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems.
Conclusion
The charger can deliver the rated current, has a good coding and low noise. Safety is acceptable.
Notes
The charger was supplied by a reader for review.
Index of all tested USB power supplies/chargers
Read more about how I test USB power supplies/charger
How does a usb charger work?
