Opus BT C3100 Erratic Behavior - Fan Gone???
32 posts / 0 new
Witterings
Last seen: 1 year 1 month ago
I put one battery in to charge and it was fine, tried to put a 2nd battery in one of the other ports and it just showed Null so tried it in the other ports and it was the same.
I pulled the plug out and tried again and it initially seemed to be working fine with both batteries, within about a minute it had changed so the display was totally corrupt and randomly switching from one illegible display to the next.
I unplugged and left it off for about 30 seconds and tried again and seemed to be absolutely fine but the fan doesn’t appear to be cutting in, I may be being overly cautious and not leaving it long enough as if it’s just the fan that’s a cheap part to replace and don’t want to kill the unit by leaving it and overheating it.
If I unplug it, when I plug it back in the fan fires up for about 1 to 2 seconds and then stops.
Anybody any ideas what it may be and if the fan’s gone although why would it kick in when I plug it in if that is the case, it almost seems more like it’s the temperature gauge and when I left it charging for a while and the display went random maybe it was overheating at that stage???????
wolfdog1226
wolfdog1226's picture
Last seen: 2 years 7 months ago
The fan comes on automatically in a few seconds after plugging in. The fan will NOT come back on unless it is necessary[3 or 4 batteries in slot, discharging batteries, ect.]
As far as “Null” goes. That can be for a few reasons. Battery is not making Full contact.Battery may be incompatible? For some batteries I had to use magnets to get proper contact.
When you put battery in are you selecting the proper settings? Charge/Charge test/discharge ECT.?
Is the charger new?
If you continue to have problems send it back.
I have had mine Two years with no problems ONCE I put a new fan and More powerful power supply,,,,,,,,,,,those were separate issues!
http://budgetlightforum.com/node/54728
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
JakeDjanitor
I hope you never accidentally put a battery in backwards. I did that one time and it was a huge mistake it destroyed my entire charger. I then redid it on video and sure enough there’s no reverse polarity protection and it fried.
If I remember correctly on power up the fan self-test maybe twice and then goes off it will only kick back on if charger is warm enough inside
wolfdog1226
JakeDjanitor wrote:
I hope you never accidentally put a battery in backwards. I did that one time and it was a huge mistake it destroyed my entire charger. I then redid it on video and sure enough there’s no reverse polarity protection and it fried. If I remember correctly on power up the fan self-test maybe twice and then goes off it will only kick back on if charger is warm enough inside
I certainly would Not recommend putting them in backwards.
However, I have the BT-C3100 2.2 Version. On a few occassions I put them in backwards and Nothing happened,,,,,,,,,,no damage/no explosion!
        WOLFDOG
JakeDjanitor
That’s what I had?!! Mine literally sizzled and smoked inside.
I loved that charger, until it died.
JakeDjanitor
Here is video, this is after I accidentally put in a cell backwards, and ruined bay 1
I wanted to confirm what happened on bay two https://youtu.be/KtBZZFSLUKk
fluke
Last seen: 16 hours 23 min ago
wolfdog1226
fluke wrote:
 Much quieter and more powerful.
https://uk.gearbest.com/diy-parts-and-tools/pp_122241.html
PERFECT user name for your fan,,,,A FLUKE!!! LOL! And I am not talking about the DMM By Fluke!
Quieter.Yes. More powerful? Not a chance! The reason it is quieter is because of its inability to MOVE air as well[CFM]. The specs and difference in performance have proved it.
The reason mine is a little louder is because it has a much, much better ability to MOVE air[CFM] which keeps the charger cooler and operating better.
There is NO comparison b/w the fan you listed which is similar to the STOCK fan and my TOP TIER DELTA fan that I have been using for almost 2 years.
No more stoppages during discharge tests which gave inaccurate capacity readings and no more RESETS at the transition from discharge to charge. Believe me, read my thread, I did extensive testing to come to these conclusions!
Specs. for fans: DELTA: 25mm X 25mm X 10mm——————-ADDA:25mm X 25mm X 09mm. The only difference is 1mm in depth.
Stock[ADDA] fan- 5v/0.13a/0.65W,,,In terms of specs, basically the same fan as you posted.
Delta fan- 12V/0.12A/1.44W,,,,,,,MORE than Double the Watts to power the fan!
SPECS for delta fan. CFM [Air Volume] is the key,,,IT is superior to the stock fan and the replacement fan you posted. iirc their CFM is about half!
There are several factors. My DELTA FANS HAVE 5 blades,,,the stock fan and yours have 7 or 8 blades,,,quieter,and again,,,does not move air as well.
My fans,,more expensive but well worth it. I got mine for FREE2 from a dealer in California who was following my thread and wanted me to test his.This is another source.
https://www.ebay.com/i/183142961569?chn=ps
        WOLFDOG
fluke
PERFECT user name for your fan,,,,A FLUKE!!! LOL! And I am not talking about the DMM By Fluke! Quieter.Yes. More powerful? Not a chance! The reason it is quieter is because of its inability to MOVE air as well[CFM]. The specs and difference in performance have proved it. The reason mine is a little louder is because it has a much, much better ability to MOVE air[CFM] which keeps the charger cooler and operating better. There is NO comparison b/w the fan you listed which is similar to the STOCK fan and my TOP TIER DELTA fan that I have been using for almost 2 years. No more stoppages during discharge tests which gave inaccurate capacity readings and no more RESETS at the transition from discharge to charge. Believe me, read my thread, I did extensive testing to come to these conclusions! Specs. for fans: DELTA: 25mm X 25mm X 10mm——————-ADDA:25mm X 25mm X 09mm. The only difference is 1mm in depth. Stock[ADDA] fan- 5v/0.13a/0.65W,,,In terms of specs, basically the same fan as you posted. Delta fan- 12V/0.12A/1.44W,,,,,,,MORE than Double the Watts to power the fan! !{width:37%}https://i.postimg.cc/HnxSPp6d/comparison2.jpg! SPECS for delta fan. CFM [Air Volume] is the key,,,IT is superior to the stock fan and the replacement fan you posted. iirc their CFM is about half! !{width:38%}https://i.postimg.cc/3NRBr9Mh/delta-fan-specs.jpg! There are several factors. My DELTA FANS HAVE 5 blades,,,the stock fan and yours have 7 or 8 blades,,,quieter,and again,,,does not move air as well.
I stand corrected.
wolfdog1226
Thanks for being honest.
I did not know any of this until my Opus gave me problems 2 years. Dr. Gauss and others helped me understand it and suggested the DELTA replacement fan and the LITE-ON Power supply. Between the Two it is like a brand new charger. Thumbs Up
        WOLFDOG
fluke
I got one of the gearbest ones, my Opus runs better and a lot quieter.
But I will get one of those you listed but shipping to UK is a ransom.
wolfdog1226
If it works well and you are not having problems with your STOCK power supply, you probably do not need to.
In this thread,,,a very comprehensive one, you will see how I and others had multiple problems with the STOCK power supply.
The meat of the discussion starts around page #4 post #120
http://budgetlightforum.com/node/34663?page=3
        WOLFDOG
wolfdog1226
A look with my DELTA fan installed. It is slightly bigger[1mm] in Depth so it protrudes a bit.No issues, been working like a mule for 2 years! Thumbs Up
Set up w/ my Lite-On SMPS
CLOSE UP
        WOLFDOG
ChrisGarrett
ChrisGarrett's picture
Last seen: 7 hours 58 min ago
I’ve got a BT3400 v. 2.2 and its OEM fan has been quiet, but I bought two of the Delta fans off of Ebay just to have as spares, as Wolf has suggested.
I also bought the LiteOn 5.5A 12v power brick and while I don’t use it regularly, it was fairly cheap to get ($12 shipped?) My inner hole on the barrel connector is slightly over sized, so if I jiggle it when the charger is running, it’ll disconnect, but I just don’t move the charger once things are charging.
Chris
wolfdog1226
Chris
The barrel connectors are slightly different. I got adapters for a few dollars and they are snug.
I like the 90 degree one. That is the one I have been using since spring of 2017 when I made fan/SMPS changes. Thumbs Up
        WOLFDOG
ChrisGarrett
Chris
!{width:44%}https://i.postimg.cc/Zn5MKbdG/90-degree-opus.jpg!
Thanks for the advice, as always. Do you recall the specific size(s)?
Thanks, Chris
wolfdog1226
ChrisGarrett wrote:
Chris
Thanks, Chris
I will have to search through the that old thread……….I will find it either b/4 I leave for trail or when I get back!
        WOLFDOG
wolfdog1226
wolfdog1226 wrote:
ChrisGarrett wrote:
Chris
Thanks, Chris
VERY IMPORTANT NOT TO REVERSE THESE NUMBERS.
It needs to be 5.5mm X 2.5mm MALE TO 5.5mm X 2.1mm FEMALE
here is thread where we talk about the adapters and show a few pics.
http://budgetlightforum.com/node/34663?page=11
If all else fails I have a few extra ones!
        WOLFDOG
ChrisGarrett
wolfdog1226 wrote:
wolfdog1226 wrote:
ChrisGarrett wrote:
Chris
Thanks, Chris
I am not sure where the link for the “angled ones are”. Your resourceful! If you google the numbers you could find the “angled ones.
link:
https://www.ebay.com/itm/7-9-5-5mm-DC-Male-to-5-5-2-1mm-DC-Female-Power-...IBM-Laptop-Adapter-/253600326860?oid=142340377628
Thanks Wolf. I’ll take a look, but it’s more of a minor nit. My 2A wall wart works fine, although my first one from Rdana crapped out on me @ 4×1000mA. charging.
Chris
Nev
Last seen: 2 years 5 months ago
I’m still using my original fan ,it got noisy once and I just gave the housing next to the fan a few flicks & it’s never done it again.
I have opened my opus a couple of times & while it was open I took the fan out & took all stickers off it & sprayed it including the windings with spray on 3 in 1 oil.
Hey wolfdog you sent me link in the other thread for the adaptors from alixpress, they fit good & are right angle.
SIGShooter
SIGShooter's picture
Last seen: 6 hours 4 min ago
My fan also started making noises last year but a squirt of Tri-flow after I took it out fixed that right up Smile
Nev
Is triflow an oil?
wolfdog1226
Glad to hear that. I did not have time to search the thread because I was on my way to the trail. I am curious,,,where is the link to those?
I thought I got them all on Ebay.
        WOLFDOG
wolfdog1226
Where is OP at?!! He started the thread and has not been seen since!! LOL
        WOLFDOG
wolfdog1226
@Chris DISREGARD THAT link I posted below for the Barrel connectors! The listing ended and the ones they posted are WRONG!!
oid=142340377628
I have Two spares I can send you if you want. send me PM w/ your address
        WOLFDOG
SIGShooter
Nev wrote:
Is triflow an oil?
Yes. I use the spray-on can but you can get it in squeeze bottles, etc. To be honest I haven’t notice much difference in light oils and I think there’s a lot of marketing hype regarding them.
Nev
These are the ones I got a while back , they were just over £3 but now they’re only £1
With these I can pick the opus up & move it around with no loss of connection.
Look what I found on AliExpress
http://s.aliexpress.com/IFfMVbqa
Witterings
Apologies …. I got crazy busy at work as soon as I posted and then had friends come to stay over the weekend …. I kept meaning to check it but just haven’t had a chance.
I left it unplugged and have tried again and it seems fine now which is really weird, I got 4 × 18650’s and put them all in at the same time and the fan cut in as it should.
I hadn’t put the battery in the wrong way and did try using magnets on the ends before I posted this thread.
Think I may oil the fan anyway as it’s always been noisy, is there any oil I should use … is 3 in 1 OK or silicon spray any better????
I’ll also look at the fan upgrade that’s been mentioned although I just want to make sure the unit’s OK before I spend the money on that and find the issue I had was the start of it breaking down and don’t see what else I can do but keep using it for now and see if the error occurs again.
SIGShooter
I used Tri-flow oil on mine last year and it’s been running quiet since then. I think for the most part that any oil/grease would work effectively for this particular purpose.
Nev
I use 3 in 1 spray , it’s a little thinner than the caned 3 in1 oil.
Witterings
Just charged 4 x AA’s with it with no problem … took them out and went to replace with the next 4 and it just said Null on each slot …. definitely not a happy charger it seems Tired
