[Review] Airpro DC7
83 posts / 0 new
weklund
weklund's picture
Last seen: 2 hours 18 min ago
Tom E wrote:
weklund – thanks for the info! Could you take a pic of the contact ring, driver side facing the batteries? Wondering if it’s screwed down, glued, etc.
For under $45, I’d buy one, but at $75 – little pricey… Ohh wait. I see a $25 coupon right on the page, interesting…. So $50
Easy access … screwed not glued. I loosened the screws on mine and the contact plate is free.
... Happy Landings ...
Tom E
Tom E's picture
Last seen: 2 days 13 hours ago
Ahh, that's cool then. In the upper left I see a board mount, probably for the USB-C connector.
If you got it loose anyways, is it loose enough to pull out and take a pic of the other side? Don't try unless you are comfortable with it - don't want you to risk messing anything up. Ohh, do be carefuly with those screws. They tend to strip easy, usually...
weklund
weklund's picture
Tom E wrote:
Ahh, that’s cool then. In the upper left I see a board mount, probably for the USB-C connector.
If you got it loose anyways, is it loose enough to pull out and take a pic of the other side? Don’t try unless you are comfortable with it – don’t want you to risk messing anything up. Ohh, do be carefuly with those screws. They tend to strip easy, usually…
Here you go …
Tom E
Tom E's picture
Ok, thanks again! It's clearly our FET+1 design with the good 7135, just not sure of the MCU - can't make out the labeling.
ToyKeeper
ToyKeeper's picture
Last seen: 3 days 12 hours ago
Location: (469219) 2016 HO3 // I get way more privmsgs than I can respond to, so please ask in a public thread if possible, for a faster answer.
Tom E wrote:
Ok, thanks again! It’s clearly our FET+1 design with the good 7135, just not sure of the MCU – can’t make out the labeling.
Yeah, I can’t tell either. With the USB port pointing south, it looks like there’s a FET and a 7135 to the west, a 14-leg MCU in the center, and some other 8-leg chip to the east. I can’t tell what the center or east chips are. It looks like the 14-leg chip is probably in control though, since it has traces going to the FET and 7135 chips… so either it’s not running a derivative of Narsil, or they did some work to port it to another MCU.
Lightbringer
Lightbringer's picture
Last seen: 2 hours 49 min ago
Just got mine today, pretty nice. Only tried it with 1 cell from my MH20, so didn’t crank it up to 11 or anything, but the basics seem to work.
Curious, what’s different about the UI, that Airpro wanted to “simplify”, vs the Q8?
Just ordered another as a spare Facepalm , and would’ve gotten yet another to gift if I could’ve snagged ‘em at 43 vs 51.
Still, build quality looks nice, threads are nicely lubed and gliiiiiide nicely, tint/color is pretty good… all in all, I’m happy. Smile
flightless22
flightless22's picture
Last seen: 12 hours 10 min ago
A Q8 with USB charging would make a perfect gift Thumbs Up
But this is in dire need of experts opinion of quality of the changes, for example a “breathing” led button did not seem necessary and may introduce unnoticed problems.
Quote:
Q: This looks like a sofrn q8 copy, adding charging and slight style changes. why did you copy the sofirn q8?
Quote:
A: Thank you for your questions. Yes it is a little similar with Q8. But we updated the programe which had simiplified the operation by users. Target market is different, it is aimed for daily use at home or outside. And designers make many changes inside and outside of the flashlight. But quality is without change. What we can say that we have NO PROBLEM with sofirn Q8. So, feel free to buy and we offer 1 year worry-free guarantee
weklund
weklund's picture
I dig the Green Eye that never sleeps … great for the nitetime locator. I am very pleased with mine so far.
Lightbringer
That’s my only gripe. I hate “breathers”. Constant-on, or beacon, great. Breather, nope. Turned mine back off again.
Nighttime, that “movement” would just be too distracting. Even the “beacon” on my MH20’s switch is too distracting.
Constant-on tailcap of my Cometa (or Q8)? Just fine. Go figure…
Muto
Last seen: 9 hours 24 min ago
They “Simply” didn’t want to give credit due for license of software so they pretended to have changed it Smile
The difference between Hoarding and Collecting is the illusion of Organization
.“I will get one of flashlight from patrol car”
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
Lightbringer
Wellp, it’s got a “breather” sideclicky instead of constant-on like the Q8, and I don’t recall any battery-check option. I found some narsim “cheetsheets”, and yeah, it looks like a PhD dissertation vs the DC7’s manual/options.
Frankly, I managed to get it into stepped modes (vs ramping), and could only manage to go backwards with a long-press. Too short, and it just shuts off (duh). So back to ramping…
Hate “breathers”, so the only other option was to keep the sideclicky turned off. Oh well…
So… quick braindead ramp-up/ramp-down seems fine to me. Shortcuts to lowest/highest are great, too. Probably all the other stuff was edited out for the “simple” version of the UI.
BlueSwordM
BlueSwordM's picture
Last seen: 15 hours 11 min ago
Seems like they tried to copy NarsilM, but couldn’t do it perfectly.
Lightbringer
If it’s all freely available in source, wouldn’t it be easier to just pilfer it as a whole, than to try diddling with it trying to copy it one feature at a time?
If they did start with narsim, they might’ve just lopped off parts they didn’t want to bother with, to muggleify it.
Anyhoo, up/down/lowest/highest is fine with me. That’s pretty much all I ever do with my real Q8.
Tom E
Tom E's picture
Sounds like they went with one simple mode set rather than the 8-12 or so Narsil supports. It's simpler in that way I guess...
Yes, they did the mimicking in a pretty bad way. Probably used the source code, simplified couple things, maybe ported to a different MCU, not sure.
It's a real, true violation of the principle the source code was released under.  I suppose mimicking is honoring, and can't blame them, but they could have thrown us a bone - mentioned it's based on the BLF users, contributions, etc. - even not me personally, but to at least mention our forum...
Funny - Amazon did publish my question, quoted earlier...
This was me: This looks like a sofrn q8 copy, adding charging and slight style changes. why did you copy the sofirn q8?
Don-cha just luv it? We are famous and good enough to be cloned! smile  Wait, didn't we clone the SRK or SupFire M6 with the Q8? Well.........
BlueSwordM
This is why we have to take this matter into our own hands.
We’ve worked with Chinese manufacturers before, and we have the proof some of them are very willing to work with us.
The next step would be to make a true BLF flashlight.
One with components from members all around the world, built with BLF standards and excellent quality control.
We need to show manufacturers that we are a powerful force to be reckoned with.
Maybe I should do a post about my plan… But that is something completely different.
Just complying with the GPL V2/V3 would be fine.
Tom E
Tom E's picture
You know, that's do-able. For that we need direct contact with the fabricators in China, or even elsewhere. But basically, lot of these manufacturers simple contract out the work. You could probably contract out at different levels (full soup to nuts or just parts), different levels of quality too. Of course not many here speak Chinese and have the contacts - this is why you can use a go-between.
Lightbringer
…and you’ll have a GoPanda or ElfLion knockoff of the light hitting BG/GB/etc. before the “real” version’s even announced.
Tom E
Tom E's picture
True... Hhmm, kind of like Manker? smile
BlueSwordM
That’s why you manufacture the parts, and then assemble them somewhere else.
fluke
Last seen: 2 days 20 hours ago
Is this flash able with Narsil?
Might get rid of the breathing light switch.
Lightbringer
Would be nice.
Imagine if it’s a narsim knockoff, the µC is the same, but I’ve got no idea if anyone’s compared.
Tom E
Tom E's picture
Think earlier I here I asked bout the driver, and someone posted the driver pics and appears to be a PIC controller, not ATMEL. Very rare to find ATMEL in production lights. In fact early on in the Q8 development, the ThorFire engineering team decided to implement our UI on a PIC, totally re-wrote our/my provided firmware, and really messed it up. They ended up firing the engineers, started over from scratch with out ATtiny85 and our firmware.
 On this one they probably did like a true port of the code to a PIC because they seemed to dupe the UI pretty well.
fluke
Thank you.
So No?
weklund
weklund's picture
Five quick clicks of the switch and the breathing switch light is disabled. I am very pleased with the two I purchased. I am also the proud owner of two Q8’s as well. Gotta love the built in charger on the Airpro DC7. I prefer the eye that never sleeps for ease of location in the dark.
fluke
Not got the DC7 yet.
Can’t stand the PWM on My Astrolux FT02 breathing light.
Tom E
Tom E's picture
fluke wrote:
Thank you. So No?
Yes, no... Not the same MCU therefore not compatible.
fluke
How about a Q8 driver board install?
Would it be as easy as that ?
Tom E
Tom E's picture
possible but I don't know for sure.
RobertB
RobertB's picture
Last seen: 6 hours 34 min ago
I asked Barry if Sofirn was making these, and he said no, and didn’t know who Airpro was.
fluke
Thank for the reply.
