List: standalone runtime graph maker/ lux loggers (for flashlight reviewers)
60 posts / 0 new
ChibiM
ChibiM's picture
Last seen: 3 days 5 hours ago
bmengineer wrote:
I'll be sure to make a post and link to here if it ever gets to a complete state :)
Awesome, thanks!
bmengineer
bmengineer's picture
Last seen: 1 week 1 day ago
I have a fully functioning proof of concept with a Raspberry Pi Zero W and my TSL2591 sensor. The code is a bit sloppy still, but it works.
Pros:
  • Output is fairly clean, no excess noise
  • Sensor quality is known unlike using an old Android phone (the one I'm using has a pretty low measurement resolution)
  • Includes an IR sensor, though I haven't added code to measure that yet
  • Extremely configurable
  • Cheap! The Pi Zero W and the sensor are less than $20. I've added some indicating LEDs to my build, and you'll need some wire, a microSD card, and probably a microHDMI adapter for initial setup
Cons:
  • Some assembly and soldering is required
  • To use this standalone you'll need a basic understanding of ssh and scp tools. If you're using Linux or OS X, it's very easy
If anyone is interested, contact me and I can send a copy of my script to test. If it works I may make it available somewhere in the future.
Find all my reviews of flashlights and more gear at www.bmengineer.com
Yokiamy
Yokiamy's picture
Last seen: 12 hours 18 min ago
Interesting, does it work as a stand alone product?
I still have a raspberry doing nothing for over 1,5 year
vulpes
vulpes's picture
I have been thinking of building the same, but using ESP32 insted of the Pi. Oled screen for quick readouts, web ui with configuration and graphs, logging to the real database are on the planed features list.
I take it you did it in Python? I’d be interested in taking a look.
gchart
gchart's picture
Last seen: 3 hours 3 min ago
That’s similar to what I use… an ESP8266 hooked up to a TLS2591
Cross post from the “What did you mod today?” thread from last February:
gchart wrote:
A year or so ago I built a lumen tube using a Wemos D1 Mini (ESP8266) running Arduino and a TSL2591 breakout board. Super small, USB powered, and feeds out results over WiFi via a built-in webserver. It makes runtime/output charts really easy.
bmengineer
Sort of. You could easily configure it to start on a button press, but I just start mine with an ssh command.
ChibiM
ChibiM's picture
For anybody interested. It seems like the following Lux Meters are actually the same, sold under different brands:
There seem to be actually 2 versions though
Reed Instruments SD-1128SD
Lutron LU-LX1128SD
PDF: http://www.sunwe.com.tw/lutron/LX-1128SDeop.pdf
General DLM112SDhttps://www.tequipment.net/GeneralDLM112SD.html
There is another version, which is the LX-1148SD
Lutron LX 1148SDhttps://inspectusa.com/lutron/manuals/lx-1148sd-manual.pdf
Sunwe LX 1148SDhttp://www.sunwe.com.tw/lutron/LX-1148SD.pdf
Voltcraft LX-2000https://asset.conrad.com/media10/isa/160267/c1/-/fr/001666060PI06/image.jpg
The obvious difference betwen these 3 (LX 1148SD) and the LX 1128 is the number of buttons.
Maybe this is another one:
Francaise-instrumentation LX 108 : https://www.distrame.fr/publicmedia/formatted/769/996/fr/LX108-luxmetre-face.jpg;maxh=400,maxw=470.jpg
Yokiamy
Yokiamy's picture
One thing i found out is that they look cheap but they are not cheap
gchart
gchart's picture
$210?!
jeff51
jeff51's picture
Last seen: 3 hours 30 min ago
Terry Oregon wrote:
Quote:
so need to figure out how to make that into clear data… starting from 0 minutes. Instead of the hours of the day
I could never figure that out either.  So . . . . .
In my Reed Instruments, I always zero the hours/minutes/seconds just before I start a runtime graph. I have to do this every time I do a runtime, but it only takes seconds once you figure it out. Excel then accepts this as starting at 12:00am.
I had the same problem with Excel.
I ended up adding a column starting at 0, and progressing at the sample interval. Using that as a time scale.
I like Libra Calc for the graphs, but could never get the darn thing to put a time scale on the graph correctly. It seemed to have a mind of it’s own as far as making the time interval on the axis.
But other than that, it worked well and is free.
I have been using one of the osram diodes that seem to be inside all of the reasonable cost lux meters.
In one of the circuits from Terry’s vast diode test. They are quite cheap.
I measure with PICO-Log software. But that’s not a stand alone option.
All the Best,
Jeff
bmengineer
All the Best,
Jeff
Python is your friend.
jeff51
jeff51's picture
Ha!, I’m too old, Python is your friend,
Fortran 4 was my friend…
Brute force in Excel. Never make an elegant formula, when 5 columns worth of obscure calcs will do….
All the Best,
Jeff
ChibiM
ChibiM's picture
I have the strange feeling that they might actually (close to) be the same as the Extech SDL series.
Alghough the buttons are placed differently, the rest looks pretty similiar.
Yokiamy
Yokiamy's picture
ChibiM wrote:
Although I already have 2 log meters, 1 being less than ideal and including some problems (Extech HD400) the SDL400 does a good job at what I want it to do.
But for the sake of other reviewers, a little bump to see if there are any other alternatives.
This looks like an upgraded GM1020?
Benetech GM1030
https://aliexpress.com/item/33010626789.html
Chibim
This looks like a very interesting meter, it can record 2000 data points with a selectable interval, and its cheap, so it might be useful.
It has bluetooth and usb (for retrieving only probably)
Please find the manual Here
bmengineer
I’ve added a short post with a bit of information about what I ended up doing. It works great for me, and I’ll keep working on it to clean it up if there’s interest.
Yokiamy
Yokiamy's picture
Very interesting!
I still have a raspberry pi catching dust on the shelf…
ChibiM
ChibiM's picture
bmengineer wrote:
I've added a "short post":http://budgetlightforum.com/node/73520 with a bit of information about what I ended up doing. It works great for me, and I'll keep working on it to clean it up if there's interest.
Nice!
If there is a nice read up on how to set it all up, that would be great!
bmengineer
ChibiM wrote:
Nice!
No write up yet, it’s still pretty alpha. But if you can figure out how to get a Pi up and running you can work this out too!
ChibiM
ChibiM's picture
bmengineer wrote:
ChibiM wrote:
Nice!
No write up yet, it's still pretty alpha. But if you can figure out how to get a Pi up and running you can work this out too!
Not really for me Wink I don't think I will dive that deep Smile But for other members.
gchart
gchart's picture
I’ve been meaning to post the details on my lumen tube build for some time, finally got a first-pass done.
https://github.com/gchart/luxmeter
bmengineer
!{width:600px;max-width:100%}https://github.com/gchart/luxmeter/raw/main/lux_meter_sensors.jpg!
That readout is snazzy
gchart
gchart's picture
Thanks bmengineer! It’s pretty basic but it’s great having immediate visual feedback. It also displays the IP address at start up (despite using a reserved IP) and diagnostics in case any sensors aren’t detected.
ChibiM
ChibiM's picture
Cool stuff gchart! Thank you for sharing!
gchart
gchart's picture
I just pushed a big update to my Lux Logger project.
Same hardware:
  • an ESP8266
  • a small OLED screen
  • TSL2591 lux sensor
  • MLX90614 IR-based temperature sensor
Instead of using an app or a batch script to log the readings, the ESP8266 itself is hosting a webpage that you pull up. That way you can use your phone, a tablet, or a computer to perform tests. And instead of polling data at set intervals, this keeps an open socket connection that quickly pushes new data any time there’s a sufficient change in the data. Oh, and I added a real-time graph.
Yokiamy
Yokiamy's picture
Fascinating stuff! You Rock Gchart!
Strange that there aren’t more manufacturers which incorporate this, and still work with relative ancient technology which are way overpriced
I actually built your specific project and it works amazing !
And the best part of it is that the parts are dirt cheap! (ok, it lacks a nice housing etc, but even that can be arranged for a few dollars more)
Some pics of my result here
gchart
gchart's picture
Awesome! Glad you got it up and going. It’s one thing for me to put one together (as I debug and such). It’s entirely better to see someone else successfully replicate it.
dthrckt
dthrckt's picture
This is a great post, so I’m dredging it up to see if there are any new logging light meters (or better apps) out there.
I find myself getting closer to choosing the light I will use in certain scenarios and want to be able to do long tests (instead of using the lights for a long time and guessing which is better).
gchart
gchart's picture
I haven’t heard of anything else new lately, but if you run across anything, please share! Or if you decide to put something together based on my project, let me know if you have any questions.
ChibiM
ChibiM's picture
Added the Triplett LT68 to the list
https://www.files.triplett.com/datasheet/lt68.pdf
This seems to be very similar to the Extech HD450
