what's your plan for the BLF LT1 Lantern?
140 posts / 0 new
Lexel
Lexel's picture
Last seen: 10 months 1 week ago
Plan is to check thermal properties, heat up and if there are some things to change for final production light
Prototypes should be sent out to reviewers by now as well
DBSAR
DBSAR's picture
Last seen: 1 day 11 hours ago
Lexel wrote:
Plan is to check thermal properties, heat up and if there are some things to change for final production light Prototypes should be sent out to reviewers by now as well
Thumbs Up
Marc E
Last seen: 5 days 10 hours ago
I have no plans as yet, once i have the lantern i’m sure opportunities will present themselves. And if not i will make some up.
dealgrabber2002
Last seen: 4 hours 21 min ago
teacher wrote:
Or…. you could just ‘fix’ the Coleman where it will not work & then you would ‘need’ a new lantern. Later… the Coleman could magically begin working again… if you wanted it to that is. Wink
Best advice E-V-E-R!
Nev
Last seen: 2 years 1 month ago
dealgrabber2002 wrote:
I am on the list for this lantern and the FW3A flashlight; wife said I can only get one… so I made my choice of getting this lantern. I most likely won’t get the version with all the bells and whistles. I just want a simple and reliable lantern. I have OCD, too many options give me headache.
How many pairs of shoes or bits of jewellery are you gonna allow her to have?
dealgrabber2002
She has a few shoes and jewelry. But then, I also have almost 20 lights/headlamps.
goshdogit
goshdogit's picture
Last seen: 3 hours 55 min ago
DBSAR wrote:
I just discovered this thread! Big Smile
I’m very much looking forward to the results of your tests with the latest prototype.
Do you have any upcoming trips that it’ll be used on? Smile
DBSAR
DBSAR's picture
Not yet, but possibility in May. it will depend on when the test sample arrives. ( i plan to do run time tests, heat tests, drop tests, water intrusion tests, output tests, amp draws, the charging circuit tests, evaluate the light diffusion, tints, just about everything i can to see if it passes everything, and talk with the others in the team & Barry (manufacturer) about any alterations & changes.
goshdogit
goshdogit's picture
I don’t yet own any LED lanterns. I’m more excited about the LT1 than any other BLF project I’ve watched develop since I joined about 3 years ago.
I hope the prototype’s arrival works into your trip schedule. I really enjoyed the photos from your other trips with your early prototypes.
I’m sure you’re hoping for excellent results, but be sure to do the water intrusion and drop tests toward the end! Party
dealgrabber2002
Only test missing is a blood test.
dekozn
Last seen: 3 weeks 5 days ago
I’m willing to sacrifice my time reviewing a prototype Evil
Idiot proofing something only creates improved idiots.
Blinded by the Light
Last seen: 1 year 9 months ago
I figure by the time I finally get my two lanterns, I’ll have my custom trailer ready for bicycle touring.
(Getting my middle-aged body ready, that’s a whole other matter)
dealgrabber2002
How long is the tour, blinded by the light?
f0xx
f0xx's picture
Last seen: 2 days 3 hours ago
I plan to use it for area lighting when I have to work nights on some cabling/construction jobs.. Right now my trusty BLF Q8 is doing a decent job (assisted by a Nitecore HC65 on my head):
The search for a better light started with the Nitecore once I broke my Walmart 3xAAA cheapie headlamp (or I’d probably have a Zebralight or Skillhunt up there instead), evolved into a Q8 (possibly paired with a diffuser), and then I found the LT1 and joined BLF.
I now have a Mini-mag nichia triple (built it myself), a 3D Mag with an XHP70.2 (also built by me), 2 Convoys, FW3A, Nitecore HC65, Wowtac A2 (WIP: driver and emitter swap. going to flash Anduril next), and the Q8…. I’m sure my wife thinks I’m a super dork. She has had enough of talking about drivers, CCT/CRI, and dogfarts.. I’m looking forward to throwing the LT1 on a tripod and lighting everything up on those long dark nights.
EDIT: Fixed picture
amishbill
amishbill's picture
Last seen: 1 year 1 month ago
I have a perfectly serviceable LED lantern at home.
It’s also perfectly annoying, as it’s cheap plastic and runs on 3 D cells. Who just happens to have an odd number of D cells on hand? And, for as often as it gets used, it’s probably going to suffer battery leakage before the current batteries are depleted.
I expect the LT1 to be a much higher quality thing that I don’t use enough to really justify having it. Smile
DIY LT1 battery wrap image. "PDF on Google Drive":https://drive.google.com/open?id=1IHIEOi1NXu868IYNCzIM7D2Ulpxchmww
Fresh Sanyo NCR18650GAs already wrapped "for sale HERE":http://budgetlightforum.com/node/69120 if you like.
BobG
BobG's picture
Last seen: 2 years 2 months ago
I’ll put one on top of my fridge for power outages and one in my preps so I can see what’s happening when the world ends. I just couldn’t bear to face the apocalypse in the dark.
JazzleSAURUS
Camping, a ‘get to the front door’ light during back yard bonfires, and having a quality power outtage option in the living room for the wife and kiddo.
FW3A XPL HI 3D 5000k w/TurboGlow
FW1A SST-20 4000k
SP32A
Maratac AAA Copper Rev 4 w/Peter Atwood copper knurled Mega 5 flute
Olight i3E Eos
Thrunite TH20 Cree XP-L
Streamlight Protac 2AA
FPV
FPV's picture
Never owned a lantern in my life, not sure if I would need one? I am not really into camping or stuff like that. But the BLF lantern is surely the most luxurious one out there?
Couchmaster
Last seen: 5 days 16 hours ago
My wife bought a couple of blowup solar LED lanterns for camping. They work well for background ambient light while camping, but reading is near impossible. This will be an adjunct to those lights, and also be backup lighting to our 2nd home where the electrical company can’t keep the electricity going regularly.
dealgrabber2002
Being doing BBQ almost once a week. Would be great to have it at the table when it gets dark.
DBSAR
DBSAR's picture
I been using the original V1 & V2 prototypes for exactly that too, and around the patio or backyard campfire after dark.
saypat
saypat's picture
Last seen: 54 min 19 sec ago
addition to my other ‘shelf Queens.’
aswang
Last seen: 2 weeks 4 days ago
Camping. Room lighting. I really want lots of optisolises on mine. Maybe we can start badgering clemence into making mcpcb for that.
Nev
I’ll be using it in me shed
& in me lean to.
TexasToasted
TexasToasted's picture
Last seen: 5 hours 51 min ago
Mine will mostly be my bedside table reading lamp, but I’ve been through 2 floods and 4 Hurricane’s so I’m pretty sure I’ll be using it for power outages too.
DBSAR
DBSAR's picture
This needs to be a Working King though and not a Shelf Queen. Big Smile
saypat
saypat's picture
aye aye sir Wink
Yacob29
Last seen: 6 months 3 weeks ago
Being in Florida, between our crappy power grid and hurricane season, I’ve been looking for a quality lantern for a while now. I also love camping and being outdoors, so it’ll get taken on trips frequently too. Also, I work backstage a lot during stage productions, so having a dimmable, controlled light with long run times could be really handy too.
Richp
Camping, work, and possibly portable home lighting charged off my solar array.
Propeak
Last seen: 1 year 3 weeks ago
Where to begin!
3-point lighting for photography & video – tint, intensity, directional and mounting options are endless!
Emergency lighting in brownouts and power failures
Day-to-day home use. I have two Zanflare lanterns I’ve used the $#17 out of and these LT1s will take over. I find tint-ramping lanterns have give such a pleasing light…
I plan on charging them with a 24w RAV solar panel and a 24 ah power bank just for the fun of it.
