Sofirn SP10 Pro (AA/14500/Andúril 2) - now available!
2148 posts / 0 new
jon_slider
jon_slider's picture
Last seen: 4 min 40 sec ago
thank you very much for the Hex file, it works! no more Ramping Blink! Crown
BruisedMonkey
Last seen: 22 hours 21 min ago
thefreeman wrote:
BruisedMonkey wrote:
thefreeman wrote:
Ok, I already ordered 15 boards and I’ll order some other necessary parts, I already have a few micro USB to TTL boards, maybe I should get some USB-C ones next.
gchart wrote:
PS – the page on Oshpark has the BOM
You mentioned that heartshrink is optional, but in any case some insulation isn’t since touching the RX connection can make the programming fail in my experience.
Did you end up making these and have any left? I’m interested [UK]. Thanks
I made a few, need to finish this batch.
I thought I had premade dupont wires but nope, only connectors and they’re a pain to make in such quantity so I soldered the TTL and key boards together, it might be better like this anyway. (3 solder pads were in front of each other and for GND I added a wire, next time I’ll get a key with proper pad placements for these boards). Ah I also didn’t have heatshrink of the right diameter Facepalm , that said about the thing I mentionned it’s not really problematic since with the 2 boards together it’s easy to hold it without touching UDPI.
These look good. I’m still interested whenever you have time to complete the batch. Thanks
contactcr
Last seen: 1 hour 20 min ago
Picked up a Red SP10 Pro now that they are on Amazon (US). I think this is the most threadlocker i’ve seen on a single light ever. Probably 90% coverage of every thread all the way around. I thought I was going to change the anodizing color with the amount of hot air I was applying.
jon_slider
congrats on getting it open.. what LED are you going with?
This SP10 Pro was super easy, no threadlocker at all:
Firelight2
Firelight2's picture
Last seen: 23 min 41 sec ago
Worst I’ve seen was on a Fenix light.
They used so much threadlocker that it filled 100% of the threads with excess squeezing out on both sides. It was red threadlocker too. Almost broke my pliers unscrewing the pill and this on a one AAA sized light.
contactcr
I was going to defer to you on this one. You are like the beam connoisseur after all. DUV/output changes aside what do you think has the cleanest beam? I suspect it will be a short range light so whatever has the least rings/artifacts I suppose.
jon_slider
I find the SP10 Pro reflector has a pretty fuzzy overall profile, and is very forgiving of LED size.. it works both domed and dedomed w 519a.. both have pros and cons, larger round hotspot, or tighter throwyer hotspot..
but dedoming creates not only warmth, it pushes the Tint DUV down to about -0.0040, whereas the Domed 519a is much closer to the BBL..
the two photos above show the domed and dedomed beam profiles, as seen by my iPhone, which makes them look worse than in real life
here is the stock LH351d beam, for reference, it is no better, on camera
they all have sort of a secondary brighter transition, between hotspot and spill, and a shadow ring before an outer boundary ring..
but in real life, I think if you look at your stock beam, any LED you choose will be as good or better.. our eyes are much more forgiving than the camera, in actual use, the SP10 Beam is not as varied across the spill as it looks in photos.
the SP10 Pro reflector is sort of short and wide.. not particularly effective at focusing a hotspot.. which makes it versatile, and compatible with both large domes or small..
The SC21 Pro has a Much better beam focus.. recommended.. for beam quality
I suggest you install a domed 519a, see for yourself, and then dedome it.. to know first hand.. bear in mind they drop about 20% in Kelvin Color when dedoming..
of the 517a Ive tried, the two standouts are the domed 5700K (super clean, not green daylight white), and the dedomed 4500K (makes a nice 3500K), but I recall you like neutral tint duv, so domed 519a may suit you best.. it is similar to E21a..
here are my domed and dedomed 519a pairs:
I get my 519a from azhu btw.. or there is a telegram based group buy from Clemence..
contactcr
Since it’s fairly good with either I will start with 519A 3500K dome on. In my test this was already below the BBL by a decent amount using a TIR.
Having followed in the footsteps of moderator007 and gchart by modding my old UTorch UT01 I feel like this light is the “Production light”/next generation of that. Truly a light that was ahead of its time. Very fine OP reflector, deep carry clip, super compact, fine knurling.
However, gchart’s brilliant work with this driver makes this light and I gotta support that.
jon_slider
using a Tir in an SP10 sounds nice.. hope you post a photo.. and DUV..
gchart’s work on the SP10 Pro driver is amazing, not only does it have AA compatibility, it has the lowest low of any Anduril light I know..
plus he offers a flashing Kit, and updated Hex files.. just amazing support Beer
thefreeman
thefreeman's picture
Last seen: 4 hours 24 min ago
I sent PMs to the people who mentionned interest in the T1616 programmer.
If I forgot anybody please send me a PM.
Edit : for people in the US please ask Gchart first if he has programmers available.
contactcr
Here’s my SP10 Pro with 519A 3500K (from Convoy site)
Beam
Beam
Left: SP01 Pro w/ 519A 3500K / Right: UT01 w/ LH351D 3500K
I really like the well defined hotspot of the UT01 reflector but the SP10 Pro is fine too.
Spectro (High with NiMH Eneloop)
jon_slider
nice strawberry color and -duv Thumbs Up
glad the beam works for you too..
Firelight2
Previously my favorite color temp was 4000-4500K.
But now that I’ve tried dedomed 519a, I think my favorite color temp is around 3500K.
jon_slider has gotten me to like warmer tints!!!! LOL Big Smile
Dangit… now I have to swap emitters in a ton of lights! Cash
jon_slider
LOL!
choices are good Beer
longuylander
longuylander's picture
Last seen: 3 hours 43 min ago
I just got a green SP10 Pro in the mail today. I wasn’t going to get one, as I have three SP10s’s. Getting to pick it up for just under $23 all in with battery/charger pushed me to go for it.
I do like the older host better. As has been said before, it’s a little shorter and has a better tail cap. The new clip isn’t great, but it is better than the old one.
Anduril 2 was actually a deterrent at first, as I didn’t want to learn all the new procedures compared to Anduril 1. But the few extras it has are worth it (I dig the timer on the hybrid memory and the ultra low moonlight). What blows me away is this thing’s performance on NIMH. I don’t know how long a battery would last, but its output is pretty amazing. It’s decent with a 14500 too, though it doesn’t outshine the competition (sadly, pun intended) like with NIMH.
It will definitely be my EDC for a few weeks to see if the happiness of the honeymoon phase fades.
Sidney Stratton
Sidney Stratton's picture
Last seen: 3 weeks 6 days ago
shirnask wrote:
Correllux wrote:
daogiahieu wrote:
Firelight2 Limsup; Thank you guys, that picture help to see very clearly.
These are not square cut threads – photos above are not sufficient to really tell, though. They are trapezoidal threads with the crests maybe a little flatter/wider than some. Not all that different than what’s on the Convoy T2/T3 and many other lights.
It can be tricky to see these clearly sometimes especially if they are shiny from grease or have direct light on them. Mildly backlit against a light background and with a low power magnifier you can clearly see that they are not true square cut at all. But that’s fine…they’re well machined and finished, feel great and work very smoothly, cap goes back on effortlessly, which is what’s important.
Well, this is the best picture I can get with my old busted not so tough camera, but I still can’t really see these as trapezoidal threads…..
Those threads I’ve seen elsewhere (can’t recall which post/thread) and seems a hybrid of Trap/Square. An album of such and the nitty-gritty of thread form from Machinery’s Handbook.
Trapezoidal threads
It would seem like a stub Trapezoidal thread with a wider root than the standard (cutting tool plunged deeper than the 1/3 pitch). Perhaps to accommodate a square thread also (wouldn’t that be clever?) or some flashlight designer rewrote the book on thread form (the handbook is the definitive author on machining standards – else of special in-house needs).
I don’t have an SP10 Pro but my SP10S and the SC21 have square threads. Sofirn’s machining is correct on those 2 lights. So I might deduce some voluntary screw thread form was made or they allowed more clearance than what is standard.
Acme threads have been superseded for many years now. Same as the Whitworth. (29º and 55º respectively; inclusive angles). The term Acme is a misnomer for Trapezoidal as simpler to remember and write. Some artifact items are still made BSW (British Standard Whitworth).
That ACME company is vintage. Wonder if Chuck Jones was inspired when creating the popular Wile E. Coyote character? (wiki)
Unheard
Unheard's picture
Last seen: 10 hours 19 min ago
So, thanks to thefreeman (nice adapter) and gchart, I was finally able to reflash my SP10 Pro Big Smile .
This light will get a 5000K 519A if I can get one. Installed gcc-avr und the Atmel files on my Pi, hopefuly I can get Andúril to compile on this system. One thing to do: Kicking out the reversed direction after ramping up.
Spitzbube.
TimMc
TimMc's picture
Last seen: 43 min 13 sec ago
Thanks for the pogo adapter gchart!
I finally got around to updating Anduril on my SP10 Pro and TS10 using a CP2102 USB adapter and pogo adapter.
Here are my notes for using gchart’s adapter with Ubuntu 22.04 LTS to build Anduril 2 and flash an SP10 and TS10 with avrdude:
https://gist.github.com/TimMcMahon/22d7a3895988b627187bde3cf344d126?perm...
starryalley pointed out that v1 of the attiny dfp pack works. I had a compilation error with the SP10 Pro when using v2 of the pack.
Has anyone got ZFlasher AVR working for Android?
Unloco
Unloco's picture
Last seen: 5 hours 45 min ago
Thanks!!! Thumbs Up
Flashbug
Flashbug's picture
Last seen: 57 min 4 sec ago
Have anyone done a runtime on moon mode ?
Just curious how long it last
SammysHP
SammysHP's picture
Last seen: 25 min 14 sec ago
Parametrek or Bob_McBob could make a synthetic runtime test…
newbie74
Last seen: 3 weeks 2 days ago
This forum rocks.
Lost my Convoy AA and it took less than 5 minutes reading to decide on buying the SP10.
Thanks for all the info!
Venom
Venom's picture
Last seen: 7 hours 15 min ago
What’s everyone using for a 14500 cell with the SP10 Pro?
Protected or Non?
It’s a long thread to read through everything. I figure I’ll ask.
SammysHP
SammysHP's picture
The unprotected one from Sofirn.
Venom
Venom's picture
Anything in the U.S.?
I have a Sofirn headlamp with 14500 & charger. Will the charger charge any 14500 or any size cell?
contactcr
https://www.illumn.com/batteries-chargers-and-powerpax-carriers/batterie...
https://liionwholesale.com/collections/batteries/products/vapcell-14500-...
Unheard
Unheard's picture
There’s not much space in the battery tube. None of my 14500 fits. They’re all protected, Olight, Klarus, and Wuben. So I’m stuck with Eneloops. Could be worse.
Spitzbube.
Venom
Venom's picture
Will the Vapecell fit the tube?
I have a local Vape shop that sells Vapecell.
Venom
Venom's picture
You could be stuck using alkaline.
contactcr
Yes I use them. Make sure you get the button tops though (unprotected). I think the positive side requires it since there is no spring if i recall.
