Sofirn SP10 Pro (AA/14500/Andúril 2) - now available!
2194 posts / 0 new
Tendou
Last seen: 4 days 15 hours ago
SammysHP wrote:
A slightly shorter version with TIR and 1× 519a would be awesome.
I agree with this. There is not many competition for a shorter version with dual fuel AA/14500 lights.
supreme
Last seen: 3 days 12 hours ago
Anyone have a link to the source code? I can find the hex but don’t want to decompile just to look at the source and see if I can modify the code
SammysHP
SammysHP's picture
Last seen: 1 hour 25 min ago
Do you mean this here? https://code.launchpad.net/~toykeeper/flashlight-firmware/anduril2
supreme
I think so? This is my first attempt at editing code and compiling. Looking at the notes on the page it seems the latest revision would work for the sp10 pro.
MascaratumB
MascaratumB's picture
Last seen: 6 hours 21 min ago
Stupid question, but: is there a place in the SP10 Pro driver to which we can add some wires to control aux leds like the ones in the TS10 MCPCB?
Thanks in advance Thumbs Up
thefreeman
thefreeman's picture
Last seen: 17 min 44 sec ago
There are no extra pads, you can solder directly on the pins with thin magnet wire but it’s meticulous work. I’ve already done it while debugging drivers. Using a corner pin is less difficult.
Picture from r/flashlight
SammysHP
SammysHP's picture
Of course: the microcontroller itself. Just add a LED with a resistor to the appropriate pin. Well, soldering to it might be difficult. Wink
MascaratumB
Thanks for thre reply, thefreeman Thumbs Up
Hum, when you are said the pins, which ones should I be aiming at? Also, how thick/thin, show the wire be?
I am not sure if am fit for these adventures but…I guess I would try since I have some spare material!
thefreeman
Both pins on the bottom right corners (15/PC0 and 16/PC1) appear to be free.
Something like 32AWG or smaller, the enamelled wire I use is 36AWG
MascaratumB
Thanks SammyHP!
Hum, getting the resistor is probably harder for me (although I am not pro in mircosoldering Silly )
But, again, I might try it Innocent
MascaratumB
Thank you once again for the reply and “directions” Wink
I will see what I can get and do Wink
If I succed, I will post it here !! And if not…I will post it too Big Smile
contactcr
Last seen: 1 day 16 hours ago
A reference from the datasheet for those of us who are not intimately familiar with microcontrollers:
MascaratumB
This may be handy, thank you contactcr Wink
MascaratumB
Hum…well, when I got home I went to check the spare driver I have and…I guess I would fail completely to solder such thin wires there Shocked
That thing is tinier than I could remember and my skills and iron and not fit for the job after all Big Smile
So, I will pass this possibility ti have an SP10 Pro with aux leds. For now Evil
Thanks for your replies folks Wink
thefreeman
All pin 16 17 and 18 look free, so you could solder a wire without caring much about solder brides between those pins.
Sari33
Last seen: 3 days 14 hours ago
Yes, waiting for Tir version. Will be shorter and give better beam with dedomed 519A. Would be nice if they include a kit of 3 type degrees lens, like 15° 45° 90° pebbled.
zumlin
Last seen: 15 hours 58 min ago
I have actually tried added an aux led to the SP10 Pro like described above, by soldering a wire directly directly to a pin. It was very difficult but I got it working with a driver that was removed from the light. But the connection so was weak such that when I tested its strength by pulling on it gently, it got disconnected.
thefreeman
For example :
32AWG solid wire soldered on two pins, at first I used only one pin and it held well enough, but since the pins are very small it’s easier and likely more robust with on two pins.
MascaratumB
thefreeman wrote:
For example :
Oh man, that is thin!!! Idk, I may risk it. Gotta find the appropriate wire (abroad, local stores don’t have it Facepalm )
Thanks for the inspiration, thefreeman!
And thanks for the report on your experience zumlin !
thefreeman
The usual 30 AWG silicone stranded wire should do as well, especially since as previously mentioned there are 3 consecutive free pins and the wire can be soldered horizontally, soldering on a middle pin is another story. Just put a generous amount of flux.
The enameled wires I often use are those actually it’s 36SWG, which is aprox 33AWG. the solid green insulated wire picture was actcually 30AWG
They also have cheaper 30AWG non colored enameled wire (says 33 but specs correspond to 30).
Edit : with silicone 30AWG :
SammysHP
SammysHP's picture
I always secure the wire with some glue after soldering (but not directly on the solder joint).
@thefreeman
Do you know how these stranded enameled wires are called that are often used in headphone cables? I like to use them in some situations, but my stash of cheap earphones is almost empty. Big Smile
Scallywag
Scallywag's picture
Last seen: 4 hours 21 min ago
@thefreeman
“magnet wire”
SammysHP
SammysHP's picture
For “magnet wire” I find mostly/only thicker wires with clear enamel coating. But I’m looking for the very thin, colored ones.
thefreeman
The one I listed have colored enamel (they also have 38SWG), but solid wire, not stranded like headphones cables. Searching for stranded enamelled wire gives a couple of results but not colored.
Maybe you would have more luck stripping audio cables with stranded enamelled wires inside, This for example
Scallywag
Scallywag's picture
This is an example of what I get in the US, don’t know how different Germany is
https://smile.amazon.com/s?k=magnet+wire+36awg&sprefix=magnet+wire+36awg
Tendou
Anyone got the SP10S blue and SP10pro blue? Is the anodizing similar? I no longer have my old SP10S blue but I remember it being light blue while the SP10pro is darker blue.
I might be misremembering the color though.
editor
editor's picture
Last seen: 2 weeks 6 days ago
Hi, I have a ramp config question
  • 7H from ON has 3 ramp config options, while
  • 10H from OFF has 4 config options.
Did anyone discover this part? Does the option 4 has any meaning in the config simple mode ramp config menu?
I’m pretty satisfied with my SP10 Pro (version 2022_04_18), only this minor question remained. It took time for me to understand ramp speed (option 3) does not work for Simple mode, according to Toykeeper’s manual it’s inherited from Advanced. In some versions Option 4 (in the ramp config menu) is the speed parameter, but I learned that for SP10 Pro it is Option 3.
Small EDC enthusiast
SammysHP
SammysHP's picture
It’s explained in the manual:
Quote:
For the Simple UI mode, there are four menu options. The first three
are the same as stepped ramping mode.
1. Floor. (default = 20/150)
2. Ceiling. (default = 120/150)
3. Number of steps. (default = 5)
4. Turbo style. (default = 0, no turbo)
editor
editor's picture
Thank you very much for the help. I didn’t find this information in the manual, my fault.
zumlin
Good tip. I put glue directly on the solder joint after I soldered a wire directly to a pin on a ATTINY1634 to salvage the aux on a lume1 .
