Sofirn SP10 Pro (AA/14500/Andúril 2) - now available!
2194 posts / 0 new
river345
Last seen: 1 day 2 hours ago
jon_slider wrote:
The lowest mode on SP10 Pro is 0.01 lumens
I’m so excited about the new low. Any idea how much current it uses? Is it low enough to be an indicator light?
SammysHP
SammysHP's picture
Last seen: 4 min 16 sec ago
No, the MCU needs to be running, so it still consumes some mA. It might work for a day, but probably not much longer.
pc_light
pc_light's picture
Last seen: 27 min 49 sec ago
Mine appears to only draw ~1.3mA at lowest moonlight mode, so it would probable run several weeks. Not as long as Aux though.
On the light side.
mhs
Last seen: 5 days 22 hours ago
Sticking to lowest ramp floor, with multimeter I get current draw:
3.5 mA with 1.2V cell
3 mA with 1.5V cell
1.3 mA with 3.7V cell
So in any case it would take few hundreds of hours do drain the cell. IMO still not long enough for always-on indicator light, but ocassionally I wouldnn’t hesitate to leave it on as a night light, as it won’t impact whole runtime too much.
jon_slider
jon_slider's picture
Last seen: 2 hours 28 min ago
thanks for the data
1900mAh/3.5mA per hour/24 hours per day= 22 days.
IF the LiIon is an 800mAh cell:
800/1.3/24 = 25 days
fwiw, a Zebra AA claims 100 days on its lowest mode
editor
editor's picture
Last seen: 3 weeks 1 day ago
Are there modes in which MCU doesn’t need to run? If yes, which are those?
Small EDC enthusiast
SammysHP
SammysHP's picture
When the flashlight is off the MCU can sleep as well.
contactcr
Last seen: 15 hours 38 min ago
The good ‘ol 0.00 lumen mode, what other flashlight has a mode this low!?
Correllux
Correllux's picture
Last seen: 1 hour 15 min ago
Only the one that adds four more zeroes. It’s the top secret one that the military doesn’t want you to know about. You’ve probably heard about it on youtube….
Tendou
Last seen: 19 hours 17 min ago
What is the different between the current batch SP10V3.0 and SP10pro? Do they use diferent driver? or any other thing to be aware of?
SammysHP
SammysHP's picture
Pro uses Anduril, V3 has Sofirn’s own UI.
Tendou
I know that they use different UI/OS.
But what hardware driver did they use? Efficiency? Lower and highest mode differences?
I heard that there are problems in the early batch of SP10V3.0. Is the SP10V3.0 problem rectified? Is there a ny new problem surfacing?
youmansk
I cannot find if this was mentioned, but the vapcell H10 flattop does not seem to work with my Sofirn SP10Pro. I just got one from Amazon. Maybe only button style 14500 work? there seems to be three gold conductors on the battery post of the positive terminal and they are close together. I may be missing something.
SammysHP
SammysHP's picture
The outer two contacts are not connected electrically. They are a mechanical reverse voltage protection. A flat-top battery won’t make contact with the center contact, only the button of a button-top.
thefreeman
thefreeman's picture
Last seen: 26 min 1 sec ago
BTW where to find button top H10 shipped to EU ? Nkon and Vapcell ali store only have flat top.
iamlucky13
Last seen: 1 day 13 hours ago
The hardware is supposed to be the same, except the microcontroller was swapped for an Anduril-compatible model, so the efficiency at a given output level should be the same.
The max brightness is the same, but gchart figured out tweaks to make in Anduril to allow the the minimum brightness to be much lower.
Tendou
Thank you. So the sp10pro seems to be the better choice for me. I already got an sp10pro. Thinking of getting v3.0 bit sp10pro can be simplified enough using the simple mode.
kokosnh
Last seen: 8 hours 25 min ago
how does the LVP looks like?  From my testing, it is just stepping down quite fast and that's it, you can still force it to go up for short time. Is that it?
jon_slider
LVP will turn the light off completely, after repeated step downs.
chart from page 1:
however, batteries will rebound and the light can be turned on again, not for long though, it will turn off again more and more quickly, the more you try to drain the already empty battery.
kokosnh
So there's no blinking warning, and so on?
I just took out a 2.5V 14500, because I thought I just had not calibrate the thermal sensor, and that's why it was stepping down. And I was just forcing it to go up...
When I did 3C it just blinked 7 time, and that was not what I was expecting, so took out the battery to see the voltage...
I thought It would just turn off, and then not turn on under 2.75V or so.
I know the 1.5V Ni-MH don't have the LVP, but the Li-ion mode should have one, right?
Do I just need to buy a protected 14500 cell?
jon_slider
stepping down can happen due to heat, or also due to low battery
here is how the LVP Step Down and Thermal Step Down, is described in the Anduril 2 Manual:
“Anduril includes low voltage protection (LVP) and thermal regulation.
LVP makes the light step down to a lower level when the battery is low,
and if the light is already at the lowest level, it shuts itself off.
This activates at 2.8V. LVP adjustments happen suddenly, in large
steps.
Thermal regulation attempts to keep the light from overheating, and
otherwise adjusts output to stay as close as possible to the
user-configured temperature limit. Thermal adjustments happen
gradually, in steps so small they are difficult for humans to perceive.”
not a good habit, as this defeats the step downs by repeated use
good thought, but if you turn it on after it shuts off, you are defeating the protection system
Learn to check battery voltage sooner.. Recharge any time the battery goes below 3.6V. Do not wait for LVP.
you could, but, that creates a slightly different problem. With a protected cell, it can shut the light off suddenly and completely, even if the battery is not empty, if you try to use too high an output. I consider sudden darkness very UnDesireable, so I dont use protected batteries.
fwiw there IS also LVP for AA..
https://budgetlightforum.com/comment/1765534#comment-1765534
TIFisher
Last seen: 1 day 4 hours ago
I have been on vacation with my SP10 PRO as my sole torch for the last week. I’m running a standard eneloop straight from the package. The performance has been beyond my expectations. I have run the light as a ceiling bouncer, shuffle to the loo illuminator, and rigging out pre-dawn fishing gear. I have well over 3 hours on the cell with no discernable loss of output. What a great combo.
Kudos to jon_slider for pointing out all the good things low and slow with this light.
jon_slider
Yay! Beer
kokosnh
little update, on my SP10 pro magnetic tail drama.
Contacted the ali store, they refused to send a good one for free
(had to pay 0.8$ for shipping with tracking, well i can understand that, and it was comparable, to getting the old one refunded, and buying new one, so I accepted it)
after 3 weeks I got it, and well this one surely won't work.
Yes that's the 18650 one, for SC31 pro and so on, not the 14500 for SP10 pro.
Ps. I do have SC31 pro, but I have black one, and I already bought a magnetic tail for it, so this one is useless for me, at this time.
smurcod
Last seen: 6 hours 2 min ago
I ordered the SP10 Pro and magnetic tail cap direct from their Chinese store (not AliExpress.) The correct one arrived luckily. I’ve had similar experiences on AliExpress with other sellers- they refuse to replace faulty/ incorrect goods and want you to pay postage when it’s their fault. Angry I just don’t buy anything else off them ever again.
editor
editor's picture
roostre wrote:
The magnet in the Lumintop “Tool AA 2.0” optional twist tail cap is mounted under a removable tail cap battery spring and replacing the magnet with a spacer is easy (I used a button from an old shirt for the spacer).
The “removable spring design” while not ideal for high current lights would most likely function adequately in the proposed AA/14500 compatible “Sofirn SP10S BLF edition with Andúril”.  I do not have access to a Sofirn SP10S and do not know how the tail cap is currently constructed.
Is the Lumintop Tool AA tailcap mechanically compatible with the Sofirn SP10 Pro? Can I use a Lumintop magnetic tailcap on the SP10 Pro?
pfuender
Last seen: 11 hours 2 min ago
No, the SP10 is slightly wider than the Tool-AA.
editor
editor's picture
Thank you very much for the quick and accurate answer. Have a very good day.
Sari33
Last seen: 5 days 15 hours ago
Does blink during ramp still present or was removed on this batch?
jon_slider
yes, no
but if you are set up for reflashing, there is a Hex from gchart without the blink
