NEED a budget single 26650 flooder
31 posts / 0 new
Th558
Th558's picture
Last seen: 1 hour 16 min ago
So I’ve been looking for a 26650 floody light which can do about 1000 lumens continuous. So far I’ve found these:
JKK70
Sofirn SP33 XHP50.2
Convoy S11 XHP50.2
Probably gna get the sofirn but im confused about the color temps. First link says 6000-6500k. Second one says 5350k- 5700k. Third one says xpl and 5350k- 5700k in the description but XHP50.2 in the title.
https://www.aliexpress.com/item/Sofirn-SP33-LED-Flashlight-18650-Cree-XPL-High-Power-Lamp-Torch-Light-Powerful-Flashlight-26650-Waterproof/32825400637.html
https://www.aliexpress.com/item/Sofirn-SP33-Mini-Powerful-Led-flashlight...CREE-XPL2-LED-Mini-Handy-flashlight-6/32831075588.html
https://uk.gearbest.com/led-flashlights/pp_009563431686.html?wid=1433363
Is it actually warmer or did they just copy and paste the colour temp from the old XPL version?
Edited by: Th558 on 04/26/2019 - 11:15
Sidney Stratton
Sidney Stratton's picture
Last seen: 17 hours 18 min ago
Confusing as there are 3 versions: SP33 w/ XHP-50 (Gearbest) and may be 5300-5700º; Ali Store XHP-50.2 (flipchip, no bonding wires) to which Sofirn made an update to their ‘newer’ version (V.2) which is ~5700º K.
Best you deal directly with Sofirn Store
Sidney Stratton
I should add; have a JKK03 (same XHP-70.2 emitter – same driver/interface) but driven with 3 × 18650s and used as a power bank. Excellent machining and design. All the detailed nuances. The biggest difference is the Jin Heng does not step down in turbo mode. So much mass to dissipate the heat. The Sofirn has this redundant timed (2 minutes) step down regardless of their ATR (Advanced Temperature Regulation). The detailing and the overall look / feel of the JKK is better (my judgement).
If you plan on using outdoors, a higher CCT will give more ‘punch’. Again, subjective opinion. I tend to take out my 6000º + lights more often than the the 5000º
Lightbringer
Lightbringer's picture
Last seen: 8 hours 28 min ago
Jaxman Z1. Aspheric, wonderfully bright even blanket of light.
Th558
Th558's picture
I’m looking for something more compact though. It has to use a 26650 cause I’m gna have a spare one after I buy a pair for my FT03.
Edit: just had a look at the Nightwatch NS22. It’s a 21700 light but I think I might get it.
argi
argi's picture
Last seen: 1 year 6 months ago
Jaxman Z1 comes in 1 cell and 2 cell version.
Long live the side switch (Join the resistance!)
malkoff junkie
malkoff junkie's picture
Last seen: 7 min 52 sec ago
PM, sent.
Malkoff !
LarryLumens
Last seen: 9 months 5 days ago
I want to buy both of these lights. I am buying the Convoy 1st because Simon does not use glue and has interesting LED/Driver options. After I build the perfect Convoy, I will still get the Sofirn because of the side switch. Sofirn does a good job and is a must for any collection.
Give me thrower or give me pizza.
Th558
Th558's picture
Nightwatch NA40SE seems great. Lots of output and much higher regulated than the E07. Tint is quite cool tho.
Di_Joker
Di_Joker's picture
Last seen: 5 hours 30 min ago
In 1000Lm mode it will quickly heat up.
Sofirn SP33 XHP50.2 color temps: 6000-6500k. This is the official answer Sofirn. And this is confirmed by paired comparisons.
JKK70 It has a deep reflector, so hotspot will be wide but the side illumination is a bit narrower than SP33
S11 has an average mode of about 750Lm, but a rich selection of color temperatures. Perhaps a pill construction removes heat a little worse, but I have not seen direct comparisons.
Sofirn should hurry with the provision of a choice of color temperatures, it is an important competitive advantage.
Sorry for my poor english.
Th558
Th558's picture
Really? If my calculations are correct the SP33 and NA40SE should both be using a bit under 6 watts at 1000 lumens.
Di_Joker
Di_Joker's picture
I have not had the opportunity to test the Nightwatch NA40SE. I will give other results of tests, maybe they will give data for analysis: 24°C of the medium
Sofirt C8F 3*XP-L(990Lm) – 58°C 20 minutes later. And (650Lm) 50°C 20 minutes later.
Sofirt SP33 1*XHP50.2(1000Lm) – 41°C 20 minutes later and 47°C 60 minutes later.
BLF Q8 4*XP-L(~1100Lm “Group6-Mid2”) – 47°C 20 minutes later.
Acebeam EC65 4*XHP35HI (800Lm) – 52°C 20 minutes later and 65°C 60 minutes later.
YLP G180 9*XP-G2 (800Lm) 45°C 60 minutes later. And (1400Lm) 69°C 60 minutes later.
Th558
Th558's picture
How does the SP33 manage heat so we’ll compared to the other lights? I was thinking maybe it’s bad thermal paste so it doesn’t let the heat out but that would show after 60 minutes. Could it be the driver efficiency?
Di_Joker
Di_Joker's picture
XHP50.2
Look also at the lights of the 3*XHP70.2, how much better they cope with heat than multi-emitters 9*XP-G, 18*XP-G or 12*XP-L
Lightbringer
Gotta give it another mention… Jaxman Z1.
Better quality version of the revered Cometa, squeezes 1300 lemons continually without breaking a sweat. Big honkin’ chunk o’ metal…
Newer version (XHPwhatever) squeezes out 2000 or so.
malkoff junkie
I have a CRX Z1. !.
considering a sale.
Malkoff !
Th558
Th558's picture
I have a ft03. not really looking for a thrower. jaxman z1 xhp50.2 looks good but its out of my budget and cool white. sofirn sp33 seemed perfect until i realised it doesn’t come in neutral white. Looks like I’ll be sticking with larger LED’s as they seem to manage heat better. Also looking for a 21700 light to replace my L16.
Lightbringer
Ain’t interested in modding? The F13 can be had for cheap, even though it’s quite nice as a host, and easy to mod. 22mm driver, 20mm LED star. Go crazy…
rikr
rikr's picture
Last seen: 5 months 2 days ago
The Convoy M3 XHP70.2
 New Collection / Old Collection
Lightbringer
Wellp, if he wants floody, right there that means either a wiiiiiide-angle TIR lens or an aspheric. Or a coupla layers of diffusion film.
Spill (to me) doesn’t count as “floody”, nor a wide hotspot.
Gave a Cometa to the gf, and she loves the wide blanket of light. “Perfect” is how she described it.
High praise indeed, from a non-flashy.
I’m sticking with the Cometa/Z1, if we’re constrained to 26650 lights.
scosgt
ROFIS MR-70?
hasddie293
hasddie293's picture
Last seen: 11 months 1 week ago
Guys, isn’t this an interesting lights… THE JINHENG JKK70 30W 3600 Lumen Powerful 26650 Flashlight SST40 Strong Floodlight – 4000k. Dude, it has 4000k warm white and optional on 5000k and 6000k. Wow, isn’t that greats, huh?
Is Luminus sst40 led warm white 4000k exist or this one is dedomed?? Can anyone here on BLF confirm me. Anyone own this light pls share your thought. because my eye got strain on Cree xhp70.2 p2 6500k due too much bluiesh light harmful one. I had to wear polarised Specs that way I feel much better…
But, hey here are the link
https://www.banggood.com/JINHENG-JKK70-30W-3600-Lumen-Powerful-26650-Fla...LED-Torch-p-1476110.html
In search of the most ideal flashlight in town:
1. BRIGHTNESS
2. Durabillity
3. Design
4. Quality
5. Price$$$
hasddie293
1. BRIGHTNESS
2. Durabillity
3. Design
4. Quality
5. Price$$$
Yokiamy
Yokiamy's picture
Last seen: 3 hours 46 min ago
Kaidomain sells that JKK70 as well, but with xhp70.2
mortuus
mortuus's picture
Last seen: 6 hours 4 min ago
maybe wait some more for astrolux mf01 mini ? that should do easy i think 1000 lumens nonstop..
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
Yokiamy
Yokiamy's picture
Haikelite SC26
Emisar D4s ?
MascaratumB
MascaratumB's picture
Last seen: 1 hour 5 min ago
Not budget, but (Wuben T70):
Besides, it can also use a second tube for +1 26650. This is a good high performance flashlight that will probably hold on for a while on medium mode (1300 lumens).
upbeat
Last seen: 1 year 4 months ago
Finally a light with a futurictic and different design: SHUSTAR S-228 Cree XHP90 6200 Lm output (??) Would one of you pro guys please look into it: https://www.aliexpress.com/item/4000170779902.html?
mattlward
mattlward's picture
Last seen: 1 hour 23 min ago
But… there is no XHP90! At least not one that I am aware of.
EDC rotation:
KR4, SST-20 FA3 4000k (favorite!)
FW3A, Nichia 4000k sw40 r9080 (second favorite)
FW1A, LH351D 3500k (third favorite)
FW1A, XP-L Hi 3A
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
Emisar D4V2, brass E21A 3500k (night light of choice)
Funtastic
Funtastic's picture
Last seen: 2 hours 50 min ago
Output definitely would be much less as a zoom light
mattlward
mattlward's picture
If you are not married to the 26650, have you considered the Convoy S12 triple with 21700 support. Just got mine in, it is very floody with the 217C, tint looks pretty darn good and it does not require a high amp cell so a 5000mah would be fine for great runtime.
EDC rotation:
FW1A, XP-L Hi 3A
FW3A, LH351D 3500k
