FW3A Troubleshooting / FAQ
1656 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 2 weeks 14 hours ago
Firelight2 wrote:
Interesting.
On the FW3A driver the inner ring connects to the switch sleeve and the outer ring connects to ground.
In the FW3E they must’ve reversed that. The outer ring connects to the switch, while the inner ring connects to ground. It works without the sleeve, because both positive and negative battery terminals are on the top of the cell. The circuit through the body tube to the tailcap is not used for main power at all… it just carries the switch connection.
Pretty simple solution. And this light could be good for people who don’t have a charger or don’t want a fiddly sleeve.
That said, it’s not for me. I prefer being able to swap cells in my light unless there is no other option.
This is my first time hearing about it, but I think your correct. Here’s a diagram.
Rayoui
Rayoui's picture
Interesting, though not novel. For example, Olight uses this setup with proprietary cells where positive and negative contacts are both on the top of the cell and a single negative contact at the tail facilitates charging as well as signaling for the tail switch.
JasonWW
JasonWW's picture
You’ve seen olight make tail e-switch?
I’ve only seen them use the special batteries to facilitate the magnetic tail charging. It used an e-switch by the head.
Granted, I don’t know all the olight models, but I’d like to know more about any tail e-switch model lights.
Rayoui
Rayoui's picture
Yep, the newer 21700 models use this design. Warrior X Pro has a two-stage tail e-switch and M2R Pro uses the same tail switch in addition to the e-switch on the head.
There are some older models that also use a tail e-switch but have the tube-in-body design.
caramba
caramba's picture
I am not sure if this has been answered anywhere but my FW3A is going berserk. After lending it.
I can’t configure or reset anything. I sort of recognize that while ON and holding the e-switch it is doing step ramping but that’s about it.
I can’t find any hint how to reset the settings to default.
JasonWW
JasonWW's picture
I can’t configure or reset anything. I sort of recognize that it is doing step ramping but that’s about it.
If it’s an older model it won’t have a reset. Just change one thing at a time. Is it in muggle mode? Get out of that. Then change to smooth ramping. After that you might need to reset your ramp levels.
If you have a newer model which does have reset, loosen head to cut power. Hold down button while tightening head and keep it pressed. I think it should blink or something to tell you it’s reset.
caramba
caramba's picture
I can’t figure out if it’s an older model. I got it a year ago. The loosening head reset didn;t seem to work. Tom E posted recently that there is no way for you to figure out what version of Anduril you have on you flashlight. Maybe I will make a suggestion.
hodor
hodor's picture
Last seen: 4 weeks 17 hours ago
ToyKeeper
ToyKeeper's picture
Last seen: 4 days 18 hours ago
Location: (469219) 2016 HO3 // I get way more privmsgs than I can respond to, so please ask in a public thread if possible, for a faster answer.
sochi111 wrote:
I stumbled upon a “new” version called FW3E
Quote:
which is an answer to the “inner sleeve issue” that some of the FW series lights have had. It has no inner sleeve!
The only information I found was:
https://zeroair.org/2020/06/04/lumintop-fw3e-flashlight-review/
Interesting. Before production, we tried to get Lumintop to fix the inner sleeve issue… by improving manufacturing tolerances enough to match what Fritz made. Getting all the right parts consistently in the right place is generally sufficient to fix the issues. However, they were unable to do that, so it ended up being common to have things out of alignment or even have a driver shelf which wasn’t big enough for the driver.
So I guess this was one way to solve it. The proprietary cell is a deal-breaker though. Also, the clip wasn’t adjusted to fit the new length… and if there’s no inner tube, the entire light’s diameter could be reduced.
In any case, would be nice if they’d update the firmware. From zeroair’s review, it looks like it’s running a pretty old version. Sad
JasonWW
JasonWW's picture
A year ago is probably the older version.
Follow my advice. If you dont know how to do those things, just ask.
You can also make a video showing what it’s doing.
ToyKeeper
ToyKeeper's picture
It probably doesn’t have a factory reset function… but if it does, it would be accessed by a “13H” action. In other words, click the button 13 times, but hold the last one for a few seconds.
But it probably doesn’t have that, because the factory reset function was added a month or two after the FW3A was launched, and Lumintop rejected the firmware updates I sent.
JasonWW
JasonWW's picture
The 13 clicks thing is unique for the FW lights, right? The “hold the button while connecting power” is for more conventional e-switch lights, right? I’m always getting these mixed up. Lol
ToyKeeper
ToyKeeper's picture
The 13H thing is currently only used on lights with tail e-switches… because on those, it’s usually impossible to hold the button while connecting power. For the FW3A in particular, power is connected long before the button.
I’ve been thinking of adding 13H as a standard thing on all lights though, for consistency.
JaredM
JaredM's picture
Last seen: 7 months 1 week ago
If they were smart IMO, they’d make a proprietary 21700 standard, and then an adapter sleeve to make an flat top 18650 work
https://fundrazr.com/osturaband
No affiliation, just a fan.
JasonWW
JasonWW's picture
There is no way to physically make an adapter sleeve work with the FW3E. It is a very unique driver layout.
christoph
Last seen: 2 days 16 hours ago
I have read thru the majority of this thread I have three FW3a’s I have taken them all apart and put them together again and they all work. Today I received a 18350 copper tube and inner tube the from Neal and I cannot get it to work. With any of the switches. The o ring is in place I put on the tail cap first tight and then screw on the head sometimes I get the connection flash others not. The switches all work on each other but not with the short copper tube. I dont know what to try next any ideas ?
Chris
Chris
richbuff said “Sometimes, I feel depressed about my spirit having been cast down to the hostile surface of this one-star planet, without my asking God first, and without God asking me first. I have found that a brief burst of maximum light from what is currently the smallest size flashlight per power makes it all ok/fine for a while, until the next time I feel the need to repeat.”
JasonWW
JasonWW's picture
Chris
I don’t know much about the short copper tubes but you might want to verify they are designed to work with your particular tail switches. There was a design change when they added a retaining ring to hold the switch assembly in place. They had to alter the battery tube threads in order to get them to work.
You can test if your tail switches are making contact. Check this vid at the 2 min mark.
https://youtu.be/kjtaQI4XDYs
christoph
Still no luck both short tubes I have,al and cu look identical. The al one works the cu not. Dimensions are within .001 of each other in length and all.
Chris
Chris
shirnask
shirnask's picture
Last seen: 2 hours 20 min ago
I have two short copper tubes – one works fine the other does not work.
EDIT – The one tube works one any FW3 the other does not work on any light.
christoph
Are they identical? can you swap out parts and make the other work? Pulling my hair out here -_^
Chris
treellama
Last seen: 16 hours 24 min ago
I have a short alu tube I could never get to work right. Maybe due to tailswitch change—I’ll have to get it out and try it again with various iterations of tail switches.
christoph
None of my switches has the lock ring in it.
Chris
MtnDon
MtnDon's picture
Last seen: 2 hours 24 min ago
Am I the only one who has never had the tailcap off of either of the two FW3A’s that I have?
shirnask
shirnask's picture
Could be – can’t do any of this without taking off the tailcaps
JasonWW
JasonWW's picture
Chris
Are the thread lengths and inner tube lengths the same?
Also, did you try without the clip? Sometimes the thickness of the clip is too big preventing the cap from screwing down all the way.
christoph
The clip is not on it. The threads are the same. After fiddling with it some more I have come to the conclusion that the inner tube is not making good contact with the switch ring in the head, I can’t make it longer so I am sol I guess.
C
thanks for the help guys.
Chris
shirnask
shirnask's picture
If no other way, buy a (cheaper) aluminum short tube and use the inner tube out of it
christoph
I tried changing the tube I have, no joy.
C
Chris
JasonWW
JasonWW's picture
C
You can make the inner tube longer by making the outer tube shorter. Did you test for continuity with the head removed like in the video I showed? I’m guessing that the switch does work and that’s why you’re thinking the inner tube not making contact with the driver ring? Assuming you have a little bit of a gap between the head and the battery tube when they are fully tightened you should be able to remove a little of the battery tube length on the head side.
Get you some sandpaper that’s about 400 to 600 grit and put it on a flat surface and then you can hold the battery tube on top of it and slide it back and forth making sure to rotate the tube every now and then so that it takes material off evenly.
Blackbeard
Blackbeard's picture
Last seen: 3 weeks 19 hours ago
Do I need to calibrate the temp(ambient) on the EDC18 like I did on FW3A? Just checking cause it’s a little harder to do the multiple clicks with the side switch & not sure if these are set up already.
