Test/review of 3-Port USB 4.2A Car Charger with QC
1 post / 0 new
HKJ
HKJ's picture
Last seen: 1 week 5 days ago
DSC_6325
Official specifications:
  • input: 12V-24V
  • Frequency: 50-60Hz    A car do not have any frequency
  • the output voltage: 5V
  • output current: 2400mA IC with protection scheme
  • the output interface: QC3.0 fast charge, three USB, with digital display
I got it from ebay dealer: xinyuancompany
DSC_6320
The charger was packed in a plastic bag inside an envelope, very common for Ebay.
DSC_6321 DSC_6324 DSC_6325
DSC_6322
DSC_6323
Measurements
  • Regular USB outputs (2&3) is coded as USB charger (DCP)
  • The two regular USB outputs are in parallel.
  • QC USB output is coded as Apple 2.4A, Samsung, DCP, QC3, Samsung-AFC, Huawei-FCP
  • Input voltage display will show lower voltage when output is loaded.
  • Power consumption when idle is about 25mA on 12V and 33mA on 24V
  • Minimum QC3 voltage: 3.7V
  • Weight: 38.8g
  • Length: 86mm
  • Front: 51 × 29.9mm
Voltage
The voltage display shows battery voltage, but its on the low side and will go even lower when a output is used.
Load%20sweep%2011.6V%20%232
The first regular USB output can deliver about 3.5A
Load%20sweep%2011.6V%20%233
And the same with the second, they are in parallel and the total current is also 3.5A
Load%20sweep%2014.6V%20%232
Higher input voltage do not change the current.
Load%20sweep%2024.0V%20%232
Even at 24V it is about the same.
Load%20sweep%2011.6V%20%231
The QC output can deliver more than 4A.
Load%20sweep%2024.0V%20%231
At 24V input it can deliver nearly 4A.
Load%20sweep%2011.6V%20QC9V
With 9V QC it is also more than 4A.
Load%20sweep%2014.6V%20QC12V
And also at 12V QC
Load%20sweep%2024.0V%20QC12V
With 24V input the output current is limited to about 3.7A.
Voltage%20sweep%202.4A%20%232%20input%20current
The regular USB outputs works down to about 7V input.
Voltage%20sweep%203.0A%20QC5V%20input%20current
The QC input works down to about 6V with 5V output.
Voltage%20sweep%202.0A%20QC12V%20input%20current
With 12V QC output only 13V is needed.
No%20load%20voltage%20sweep
Current consumption varies a bit with input voltage and display reading.
Load%20test%204.4A
Without any real good specifications I decided to use 2.4A load for regular USB and 2A load on QC9V.
The temperature photos below are taken between 30 minutes and 60 minutes into the one hour test.
Temp6724
M1: 53.2°C, HS1: 58.1°C
Temp6725
M1: 49.3°C, HS1: 63.7°C
10ohm
Noise at 0.5A output is 45mV rms and 251mVpp
5ohm
Noise at 1A output is 68mV rms and 375mVpp
2ohm
Noise at 2.5A output is 68mV rms and 251mVpp
10ohmQC5V
Noise at 0.5A output is 32mV rms and 115mVpp
2ohmQC5V
Noise at 2.5A output is 48mV rms and 186mVpp
10ohmQC12V
Noise at 1.2A output is 22mV rms and 99mVpp.
Tear down
DSC_6344
Mounting the front in my vice and I could break the back loose.
DSC_6345
This charger has a common mode coil (L3) at the 12V input, this is very uncommon. There is also a fuse (F1).
The circuit has two switchers, a regular (U2: HC2006) and one for QC (U1: HC1002) with their inductors (L2 & L1) and smoothing capacitors (EC4 & EC3). The two input capacitors (EC1 & EC2) are in parallel.
Here is also the explanation on the voltage displays load dependency, it is connected after the common mode coil, i.e. it sees the voltage drop in the fuse, coil and spring.
The spring looks fairly solid.
DSC_6347
DSC_6348 DSC_6350
DSC_6349
DSC_6346
There is nothing on the other side of the circuit board.
DSC_6351
There is a few parts on the front, the QC controller (FT4), a empty space for a automatic protocol id and the unmarked voltmeter IC (U5)
DSC_6353
Being a 12V device there is no need to test with high voltages.
Conclusion
For a cheap car charger is a fairly good, but I would have liked the missing protocol IC and better overload protection.
The voltmeter is not that useful due to the error.
Notes
Read more about how I test USB power supplies/charger
Compare car chargers and other DC supplied chargers
