BLF Interest List: EX3 High Current Beryllium Copper Silver Plated springs - Still selling my springs :)
613 posts / 0 new
BlueSwordM
BlueSwordM's picture
Last seen: 1 day 23 hours ago
OK guys, I received a notification that I got the springs.
Once I come home, I’ll take pics and physical measurements to make sure everything is OK.
iamlucky13
Last seen: 3 min 49 sec ago
BlueSwordM wrote:
@Dlux, excellent.
As expected, European customers get their packages first. Smile
Indeed. Still looking forward to seeing mine arrive in the US.
No hurry though. I look forward to hearing from others how theirs look while I wait.
Dlux
Last seen: 1 week 1 day ago
@iamlucky13, they are very shiny, a real piece of jewelry.
To see how they perform i am going to need some time, as i am a bit busy now.
iamlucky13
Dlux wrote:
@iamlucky13, they are very shiny, a real piece of jewelry. To see how they perform i am going to need some time, as i am a bit busy now.
I was thinking mainly of how the SST-20’s I ordered look, but true, the springs, too. Some very shiny pictures were shared upthread.
I’m not sure yet what my first project will be with the springs – I already have bypasses on some lights, but I knew I’d better have some good springs on hand for future projects.
BlueSwordM
Say, iamlucky13, why did you only order springs?
I thought people here mostly wanted the LEDs, no?
iamlucky13
Uh oh… a joke, I hope?
I guess I will find out when the package arrives whether it has both springs and SST-20’s.
Shocked Blushing Wink
Barkuti
Barkuti's picture
Last seen: 6 days 23 hours ago
http://www.lineblog.co/road-runner-coyote-gif.html
Sooo, how are those brand new springs doing?
Smile
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
BlueSwordM
Did a quick preliminary test on them.
1. The overall package was heavier than usual. Must be all that copper goodness.
2. The spring deformation is about what expected: barely any for the large spring, the usual stuff for the small spring.
3. T H I C C.
No pics or tests on them for now.
Barkuti
Barkuti's picture
3. T H I C C.
What does the usual stuff for the small spring mean?
T H I C C = To be Honest I Can't Complain?
Dlux
Oh right! the LEDs.
I have never used a high CRI nor NW one before, so better someone with more experience describe them.
thisnameisvalid
thisnameisvalid's picture
LEDs arrived today! Big Smile Into my FW3A they go…
What can I say? They’re awesome! Not rosy on low modes, but 100% neutral. Way better than the nasty green FB4. On turbo it does get rosy.
(I know the wires are the wrong way; I mistakenly reflowed the emitters in reverse)
contactcr
Last seen: 12 hours 26 min ago
More importantly get that solder paste and solder balls off there
BlueSwordM
Yeah.
Because if something bad happens, then shorts could be possible. :/
jasontheguitarist
Last seen: 3 hours 12 min ago
I got my LEDs today. I had two MCPCBs laying around. One brand new, and one was used before.
The LED I reflowed on the new MCPCB is fine, but the one on the used MCPCB didn’t work. I tried reflowing it a few more times. I used a copper braid to clean as much solder as possible from the old MCPCB and applied new solder paste. Still nothing. I tried a second LED and no dice. Third, same.
The odds I have three bad LEDs are pretty slim, so logic tells me the MCPCB has to be the problem, even though checking continuity with a multimeter works fine.
I can’t get the pads on the MCPCB back to being copper colored, no matter how much I tried they are still tinned. They test fine for continuity but I’ve reflowed to this board like 10 times now across three LEDs and it’s not working.
I have some more MCPCBs on the slow rowboat from china, when those arrive hopefully I’ll find out that using a new MCPCB will do the trick.
For now it’s beer time.
The LED I did manage to get reflowed went into my S2+ with a 7135×8 nangj 105c running a customized version of Gchart’s Babka firmware. Still greenish on low, but the higher settings look much better than the one that came in this S2 from Simon.
BlueSwordM
Excellent Jason.
You’re unlucky that the MCPCB doesn’t work.
I actually tested 1/10 SST-20s to check if every one of them were working, and everything did.
That’s actually why it took me a week to start shipping out the LEDs: additional QA is required, since bad LEDs could spell disaster for me and others.
Could you post some beamshots if possible?
jasontheguitarist
I’ll take some pictures when it gets dark here. How do you test bare LEDs? I attempted to test two of them by holding the LED in tweezers and using one of the alligator clips on my helping hands to hold the tweezers, then touching the pads with my multimeter. I couldn’t get it to light up, but it’s a crappy test setup so that’s probably it.
jasontheguitarist
I can’t get photos to represent what my eyes see. Maybe I’ll work on that and post some later.
I’ve attempted many times to reflow 4 of these LEDs to the one MCPCB I have left. The MCPCB checks out perfectly with a multimeter, there’s continuity between the three pads to where it’s supposed to be. I’ve cleaned up the pads countless times and retried and retried.
Solder paste, place LED with notch towards negative like the datasheet says, wait for it to flow, bouncy bouncy LED, tap to eject excess solder. Remove heat, wait for it to cool, check with multimeter, zilch, no light. I keep checking another LED I have with the meter to make sure it’ll light it up and it does. I used Matt’s video as a guide when I did 5 LH351Ds a couple months ago and they all worked without a hitch. My troubleshooting brain says the MCPCB has to be the problem since it’s the common element and it was used once before, however it passes every test I can think of.
After reflowing I’ve checked for shorts and nothing.
This is driving me stupid since it has no reason not to work, yet it still doesn’t. Has anyone had a once used MCPCB just not take a reflow no matter what?
I only opened one strip of 5 LEDs. The other is still wrapped in tape, and I’m going to leave it that way until I get my brand new MCPCBs from the slow boat.
BlueSwordM
Ah damn it.
This is making me remember when I tried to reflow on the Astrolux S42 MCPCB at one point.
It just wouldn’t work.
It never did work, until the person I sold it to got the same LEDs working fine…
I really hope it’s not the LEDs that are DOA, as it would cost me a pretty penny to get them replaced, and then I would have to get refunded from the supplier.
I mean, I actually sampled some LEDs, and they worked fine. Crushed them with my foot in their packaging, and all of them worked fine and lit up.
I mean, others have received their LEDs and are working fine, which has me worried a lot.
BlueSwordM
This is making me stressed a bit, as the last GB with the SST-20s went well without any problems.
jasontheguitarist
I tend to get obsessively worked up over stuff due to ADHD. I just need to wait for my new MCPCBs to arrive and try again.
The LEDs didn’t appear to be damaged in shipping. They were wrapped in a metric ton of tape.
I’ve only done 6 working reflows in my life at this point, so I’m still a noob. It’s entirely possible that even though I think I’m doing everything right that I’ve still managed to screw something up.
iamlucky13
The datasheet shows the little black dot on the same side as the anode, which for connecting LED’s should be positive.
There’s something to do with basic electronic theory such that anode denotes a positive terminal in some cases and negative in others. I don’t understand it, but several online sources say LED’s should be connected with the anode to positive.
Try swapping your power supply leads to the PCB and see if you get light.
jasontheguitarist
Right, on the top of the LED the dot in the corner is positive. But on the bottom pads the notch in the center pad is the negative (cathode) side. I have one working, and I’ve been trying subsequent reflows just like I did the first one that worked.
shirnask
shirnask's picture
Last seen: 4 min 51 sec ago
jasontheguitarist
Yea I have it on the correct way. Even if I had it backwards, I tried swapping the multi meter probes too and it didn’t make a difference.
DavidEF
DavidEF's picture
Last seen: 8 months 3 weeks ago
Did you try testing each LED by sticking your probes into the solder overflow areas on the sides of the emitter pads instead of the wire connection points?
- The YKK Philosophy
thisnameisvalid
I’ve had issues a couple times with reflowed SST-20s not working. Doing it for a second time seems to fix it. Never had it with any other emitters.
jasontheguitarist
Actually yea and still nothing. I also tested for continuity between the solder sticking out there and the main wire terminals and it passed. I probed just about everything that I can with the multi meter. I don’t know, maybe one of the pads on the LED just won’t get a good connection on this board, but I have no idea.
I’m trying to rule out dead LEDs since that seems pretty unlikely. Either DOA or maybe I damaged them somehow without knowing.
I need a fresh freaking MCPCB to try since I’m getting tired of screwing around with this one. I have a bunch coming from the Convoy store but the tracking stalled like 12 days ago and I have a feeling the stuff will just show up randomly and the tracking will never update.
I’m done for now. When my new boards show up I’ll try again.
Between these and a defective driver I got from KD I’m not having much luck lately.
jasontheguitarist
maybe I’ll get it to work eventually, I’m just waiting for some brand new MCPCBs to try again.
jasontheguitarist
So patience is not my strong suit at all. I opened the second strip of 5 LEDs that was still taped to oblivion and reflowed one to the same MCPCB I’ve been reflowing all the others to, and it worked perfectly first try.
After that I went back to holding the bare LEDs in tweezers by the sides, then clamping the tweezers in my helping hands so I can test them directly with my multimeter. I did this before and didn’t get anywhere, this time I tested the last 4 LEDs and 3 work perfectly, one doesn’t do anything.
So at this point after testing them directly I’m sure which ones work and which ones don’t.
Final tally is 5 dead 5 working.
I don’t know if they were factory defects, damaged in shipping, or what. The first strip of 5 I opened had 4 dead ones in a row, this makes me think factory defects since they were all together. The second strip of 5 only had the one bad one.
Still, these are good tint bin SST-20s, so at the price I paid I ended up at about $4.00 for each of the 5 working ones. Normal price for the lesser tint binned ones is often around $3.
Hopefully it’s just me and no one else has issues.
trakcon
trakcon's picture
Last seen: 10 hours 54 min ago
Hopefully.
