XHP-50 P60 Drop in AliExpress
39 posts / 0 new
Andybibbville
Andybibbville's picture
Last seen: 8 months 5 days ago
Does anyone know anything about this, like is this a real genuine XHP-50?
US $13.28 | 26.5mm XHP50.2 3V 2600 lumens LED bulb drop-in for Surefire C2 Z2 P60 P61 6P 9P G3 S3 D2 Manta Ray M5 M6 WF-501B WF-502B torch
https://s.click.aliexpress.com/e/bPtZpGEc
John 12:46 “I have come into the world as a light, so that no one who believes in me should stay in darkness.” Genesis 1:3 And God said, “Let there be light,” and there was light.
MascaratumB
MascaratumB's picture
Last seen: 6 hours 29 min ago
They seem to sell genuine materials! I normally keep this store under sight as they normally have good prices and nice materials. I’ve been tempted to get their drivers and LEDs.
4492011
I would say yes, I have purchased many items from this seller. although not this item. Pretty low current but probably suitable for that small of a host because of the heat produced by that emitter.
Andybibbville
I bought one so in about a month we should know something. I know a lot of people probably will not like the tint at 6500k, I don’t have a problem with that tint at all.
BlueSwordM
BlueSwordM's picture
Last seen: 2 days 14 hours ago
Huh, not bad, not bad at all.
It’s a very smart choice to use a 3V XHP50.2 with a 3A driver.
That means efficiency will be absolutely top notch.
At 3A(0,75A per LED), it should be producing 1500 LED lumens, and around 1300 lumens OTF, which is very good.
texas shooter
Last seen: 1 hour 19 min ago
It looks good. You may, if your soldering skills are up to it buy 4 more 7135 or 7138 chips to stack on. 2.8 amps on that 3 volt Cree XHP50.2 LED is nice but 4.2 amps and it’ll bring out more and still be in the very efficient sweet spot of that LED. And yes I’m ordering one now and doing the same. First 2 products http://www.mtnelectronics.com/index.php?route=product/category&path=25_76
Long live the P60.
Andybibbville
Texas shooter that sounds like a great idea. I may have to try my skills.
Andybibbville
BlueswordM are you saying that this drop in will produce 1500 lumens and not 2500?
Rusty Joe
Rusty Joe's picture
Last seen: 5 hours 5 min ago
Really cool…but how’s this thing gonna manage the heat?
BlueSwordM
With a 3V XHP 50.2, at 3A, it’ll only make 1500 lumens at max.
Andybibbville
Okay thank you BlueswordM, I don’t know these kind of things.
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 4 hours 43 min ago
This is a new 3 volt edition of the XHP50.2 so it runs at 3v and this driver is a standard 3 amp driver and should produce around 1000+ lumens probably higher maybe 1400? .
If it was the 6v XHP50.2 LED at 3amps it would do over or around 2500 lumens but then it would be using a boost driver not a 7135 driver. I have bought a few driver from this store and they are decent/good. Good build quality and decent parts used but i found the 7135 driver i bought was not using an Attiny chip.
If you bought one of these drivers you should get around 2500 lumens its got 6 extra 7135 so about an amp and half extra.
https://www.aliexpress.com/store/product/22mm-3-7v-4-2v-1-cell-14xAMC713...LED-Driver-Circuit/707941_32839274202.html?spm=2114.12010612.8148356.18.7ead15f1YGRLPI
Andybibbville
Thank you everydaysurvivalgear. I’m glad to hear that you have bought their drivers before, I’m glad I bought this one now. Especially if it can achieve 2500 lumens.
chooma
Last seen: 3 min 8 sec ago
Ordered…thanks Andy
BlueSwordM
@Andybibbville, it won’t reach 2500 lumens.
2500 lumens is what the XHP50.2 does at 18W.
The drop in only works at about 10W, only producing around 1400-1500 lumens.
texas shooter
I pulled up the Cree charts. At 3 amps with next to the very brightest rated bin 1335 lumens, at 4.2 amps 1748 lumens. Still very good output.
Agro
Agro's picture
Last seen: 3 weeks 3 days ago
Andybibbville, could you provide a link without click tracking?
Marc E
Last seen: 6 days 23 hours ago
I think this is the straight link:
https://www.aliexpress.com/item/33018362830.html?storeId=707941&spm=2114...
Andybibbville, with enough power the XHP50.2 LED is capable of 2500 lumens but that driver will only provide enough power at max to produce 1500ish lumens, or as Texas Lumens points out 1335ish lumens.
A P60 drop-in by default does not make good contact with the P60 host body so it doesn’t transfer heat away from the LED too well, more power means more heat so if you were to use a driver that provided enough power to produce 2500 lumens you would need improve the heat transfer path between the drop-in and the body or the LED and drop-in would very quickly get hot enough to damage components.
There are 2 possible reasons why the description states 2600 lumens when it should say 1500 or less. The first is that the seller is exaggerating the performance of their product, it’s common for sellers to do this but with no experience of this seller i can’t say whether this is the case or not.
The second reason is that they have confused the 3V XHP50.2 output with the 6V XHP50.2 output.
Lumens are a product of power, the more power the more lumens (within the LEDs working range).
Power(measured in watts(W)) is a product of voltage(V) and current (A). W=VA. This means that if you double the current from 3A to 6A while keeping the voltage the same you get double the power. It also means that if you double the voltage from 3V to 6V while keeping the current the same you also get double the power.
So, with a 3A input, a 6V XHP50.2 will get double the power of a 3V XHP50.2 and will therefore produce more lumens. Most information online relates to the 6V XHP50.2 so it’s possible they have quoted the expected lumens from a 6V XHP50.2 running at 3A rather than a 3V XHP50.2 running at 3A.
Andybibbville
Thank you Marc E for explaining that so eloquently, that makes sense for them to do that. Even with 1300 to 1500 lumens it’s still going to be a great drop in. Hopefully will get more runtime from it, since it’s not being driven so hard.
Agro
Agro's picture
Thank you for the link Marc E.
RoboEgg
Last seen: 2 years 1 month ago
I’ve ordered one too. It’s the first XHP50.2 drop in I’ve seen on sale. Should be a slight improvement on my T6 drop in (2.5amp draw).
The Last Katun
The Last Katun's picture
Last seen: 1 day 23 hours ago
I have already modified a couple of flashlights by replacing the XML2 with a 3-volt XHP50.2, without making any other changes; the drivers provided 2700mAh; the lumens in addition to an XML, there are, and the beam of light is more flood (at least with the parabolas of default with a diameter of about 27mm); I think the performance of an XHP50.2 is higher, with the same Amp, at 3 volts.
Overall I am satisfied, in fact, slowly, I will bring other flashlights to the standard one.
Regarding the P60, yes, the problem is the greater heat, it is a must to fill the space between the P60 and the head with metal plates (I use aluminum, beer cans) but certainly copper would be better
chooma
Got mine in yesterday….12 transit days.
Put it in a Solarforce shorty with purple Efest.
Yard brick wall is about 15 yards.
Yard pics are low and high.
White wall pics are at 2 and 3 feet….
I like this drop in…
http://imgur.com/gallery/i0cpUsN
texas shooter
Great, that is a bit brighter than I thought it would be. A few extra 7135’s should help even more. Thanks for the pictures. Mine is still in the mail.
AdrianWA
AdrianWA's picture
Is it possible to build a P60 drop-in that can handle 4 x 18650s? I have a Solarforce Gladiator host that needs a drop-in. What components do I need to build one? I would like a longer run time just in case when power is out in my country.
AdrianWA
AdrianWA's picture
This is a new 3 volt edition of the XHP50.2 so it runs at 3v and this driver is a standard 3 amp driver and should produce around 1000+ lumens probably higher maybe 1400? . If it was the 6v XHP50.2 LED at 3amps it would do over or around 2500 lumens but then it would be using a boost driver not a 7135 driver. I have bought a few driver from this store and they are decent/good. Good build quality and decent parts used but i found the 7135 driver i bought was not using an Attiny chip. If you bought one of these drivers you should get around 2500 lumens its got 6 extra 7135 so about an amp and half extra. https://www.aliexpress.com/store/product/22mm-3-7v-4-2v-1-cell-14xAMC7135-led-driver-board-5A-3mode-LED-Driver-Circuit/707941_32839274202.html?spm=2114.12010612.8148356.18.7ead15f1YGRLPI[/quote]
Hey Chris nice to hear from you again and doing videos on YouTube
texas shooter
AdrianWA wrote:
Is it possible to build a P60 drop-in that can handle 4 × 18650s? I have a Solarforce Gladiator host that needs a drop-in. What components do I need to build one? I would like a longer run time just in case when power is out in my country.
Sadly many just waste the extra voltage. You’re better of with a single cell P60 and three spare batteries for longer run time. At one of the cabins we camp at, its power is limited to a single solar panel. This keeps an AGM trolling battery charged. It lights the cabin on 12 volt system plus a little 200 watt inverted. That battery alone can charge items for a long time and be recharged on a car. Might be an idea for long power outages.
AdrianWA
AdrianWA's picture
texas shooter wrote:
Sadly many just waste the extra voltage. You're better of with a single cell P60 and three spare batteries for longer run time. At one of the cabins we camp at, its power is limited to a single solar panel. This keeps an AGM trolling battery charged. It lights the cabin on 12 volt system plus a little 200 watt inverted. That battery alone can charge items for a long time and be recharged on a car. Might be an idea for long power outages.
I don’t have a car and a solar panel. I don’t want to carry a battery case with 3 spare batteries inside it. If you have a look on goggle a Solarforce gladiator is a 4 x 18650 length P60 drop-in host. Nobody wants to change batteries every now and then in the dark. Many thanks for you opinion.
texas shooter
I don’t have a car and a solar panel. I don’t want to carry a battery case with 3 spare batteries inside it. If you have a look on goggle a Solarforce gladiator is a 4 × 18650 length P60 drop-in host. Nobody wants to change batteries every now and then in the dark. Many thanks for you opinion.
I have a SolarForce Gladiator with one of their 1-4 cell dropins. No extra runtime with extra batteries over using 1 cell. They just wasted the extra voltage in the driver. I know of no 17mm driver that lowers voltage and increases run time by raising current potential. One possible option is to use a Cree XHP35 LED that is build for 12 volts and much lower current for equal output.
AdrianWA
AdrianWA's picture
How about a 4 LED P60 drop-in that can use 4 x 18650? Can you please give me a list of what I need to do my own? I just want to give it a try. Thank you so much for your reply and I’m very sorry if I sound rude.
texas shooter
I got two of them a few weeks ago. One I left with the 8 7135 chips at 2.8 amps it’s an okay light with lots of spill. The other I added 4 7138 chips bring it up to 4.3 amps and it really brings this dropin to life. As is maybe 1100-1200 lumens, extra chips 1500-1600 lumens. My 12 7138 chips dropin from Pflepro actually measured 1790 lumens at 4.56 amps. The dropin is definitely worth it and works very well. With the extra chips it needs a good wrap of copper and is very much worth the effort.
