I was just wondering if anyone knows where I can pick up some mcpcbs loaded with XP LEDs that have a bunch on there. Something similar to what is in Firefly R0T66 or E07 etc. Any number of emitters is
fine as long as max diameter of the optic does not exceed 50mm.
I would say the Skyray clones but they may be slightly larger than 50mm. I also only know then to come with an XML footprint. Maybe someone here has a relationship with FF and can help you out. Good luck.
According to Sofirn, the Q8 reflector is 51mm to the outside of the top rim. If a cheap SRK clone were acquired, it “might” be possible to machine away that little 1mm extra, but that would be up to him to decide, I guess.
In case it’s useful, here’s Sofirn’s listing for some of their cheap SRK clones. They do look like they all have XM size emitters.
You can always add bare mcpcb and any compatible bare leds into cart and leave me a note to solder them, I don't have all possible listings for all MCPCB-LED combinations, but I will add more as soon as I find more time.
