Convoy S21A (Short Technical Review)
71 posts / 0 new
Rayoui
Rayoui's picture
Last seen: 10 hours 54 min ago
I have one of the new 8A buck drivers with 12 mode group firmware and I’ve had this happen once as well.
Techno
Last seen: 6 hours 30 min ago
abgx1 wrote:
seems like spring bypass is not very high quality, after short time it just ripped off on all 3 s21a which I had
I guess its because of low quaility insulation on that cable used for bypass, which will become just too stiff(plastic like, instead of rubber…) due to heat damage
anyone can chip in whether there are any safety concerns when the bypass cable snaps?
X
Nachtfeuerzeug
Nachtfeuerzeug's picture
Techno wrote:
abgx1 wrote:
seems like spring bypass is not very high quality, after short time it just ripped off on all 3 s21a which I had I guess its because of low quaility insulation on that cable used for bypass, which will become just too stiff(plastic like, instead of rubber...) due to heat damage
Probably not. But, the light can be run at a lower level. I have remade the bypass with a larger wire due to this happening on some of my S21As, too. At first, I was surprised it happened because the stock wire looked ok.
EDC
FW3A, SST20 4000K || S21A, Crescendo Mtn20DD, LH351D 4000K || SP32A, SST40 5000K
Recent/ongoing Mods:
S2+, TexAven 17mm, LH351D | S21A, Crescendo 20mm, XPL HI 5000K | L2 w/Mtn17DD Zener Guppydrv, XHP-50 | C8+ OP, DD XHP-50
SP32A w/SST40 5000K | TIR Upgrades | EagleTac clip | Ultrafire C2 w/6A 20mm & LH351D | S2+, Biscotti, Nichia 219C 2700K |
Reviews:
Sofirn SP31 v2.0 Tactical Flashlight (Cree XPL HI) || Sofirn SD05 Scuba Diving Flashlight || Sofirn SC31 USB Rechargeable (XP-G3) || Sofirn SC31 Pro 5000K
abgx1
I dont think so, you will just lose few lumens on higher levels
Adrian000
Adrian000's picture
Last seen: 6 months 2 days ago
Terry Oregon wrote:
I measured 21.48mm with my calipers.  I use Samsung INR21700-48G which fit just fine.
Is the SST40 of this review the 5000K version ? It seems like by the picture
justanotherguy
Last seen: 1 hour 5 sec ago
Just got mine in, does anyone know of a clip that fits around the light and is captured by the tailcap?
In this style…
Click
Terry Oregon
Terry Oregon's picture
Last seen: 3 hours 11 min ago
It's the 6500K version
My reviews: , My personal collection of lights LINK,  J5 Tactical V1 Pro review LINK,  Thirteen Optical Sensors review LINKZebralight SC700d review LINK,  Ray-O-Vac Super Power Sportsman review LINK,  Convoy S2+ color combos LINK,  How To flash D4V2 LINK,  Convoy S21A LINK
GarethC
Last seen: 3 weeks 2 days ago
The Convoy S21A can be had with either the “4 modes” driver or the “12 groups” driver.
Link:
https://www.aliexpress.com/item/33026858558.html?pdp_ext_f=%7B%22sku_id%...
In the “12 groups” driver instruction it is mentioned: “BTW, do not leave the light in config mode for long period of time, because it will wear out the driver’s memory faster.”
Does that mean that Convoy lights with the “4 modes” driver will last longer than those with “12 groups” driver ?
Thank you in advance.
CR888
Last seen: 1 week 1 day ago
Probably best asking in a thread that Convoy owner Simon posts in regularly about the driver ‘wearing out’.
CR888
justanotherguy
Link:
yes, IF you plan on leaving the light in config mode… !
If you use it like a light and reconfigure it only occasionally I cant see you being able to see any meaningful difference in driver life
