Noctigon DM11 high CRI middle range thrower available
4263 posts / 0 new
Lumen9000
Lumen9000's picture
Last seen: 9 hours 44 min ago
Hank Wang wrote:
4Null wrote:
Hank Wang wrote:
https://www.noctigon.com/image/catalog/DM11/DM11.jpg
What a beautiful light. The knurling on the tube looks very pronounced, how does it feel? Does it have USB charging?
Yes, they are very pronounced, even too pronounced which I’m afraid some people may not like it.
It does not have USB charging function, the tube is different than the K1/K9.3 tube, which are not interchangeable.
The charging port is removed to reduce the height and weight of the light as much as possible.
Then we hope an eventual 12.1 will get it instead.. Wink
id30209
id30209's picture
Last seen: 7 hours 30 min ago
Correllux wrote:
If we see this new light with the 5000K SFT40 I'll click "buy" without thinking. I love that green. A darker navy-ish blue would be really nice, too, and a matte red. I still have a thing for good earthy coyote tan, too.
SFT40 5000K doesn’t exist and Hank is not making them so easy …
WTB Titanium 4sevens 2xAA tube
TriggerTX
Orange, please! I even have an open slot in my Ouch Pouch for it.
strayz
Last seen: 1 day 7 hours ago
Subing to see what Hank has in store for us.
Cool
stephenk
stephenk's picture
Last seen: 1 day 3 hours ago
This suggestion might need its own thread, but I thought I would post it here as Hank makes (in my opinion) the highest quality and value for money Anduril based lights.
18650 tube lights with tail switches are massively popular, especially the Convoy S2+, and in the past we had the excellent BLF/Astrolux A6. The FW1A was a very popular “not quite a tube light” that was great until Lumintop recently stuffed it up. The Noctigon KR1 is awesome, but not quite pocketable/EDC as the head is 35mm. So what I’m proposing is for a flashlight manufacturer to step up and built an “modernized” Anduril based, single emitter, tail switch 18650 tube light.
Possible specifications:
Single emitter in deep smooth reflector >20KCD with XP-L HI (or TIR if this throw specification would still be met).
Support for SST-20, SST-40, Osram W1, W2, Cree XP-L HI emitters.
18650 Tube Body approx. 25-26mm diameter, maybe 21700 if the tube and head can stay within 28mm max (so that it can fit in all light painting systems).
Good thermal mass for sustained brightness.
Illuminated tail e-switch (illumination can be turned off if required).
Reversible side clip direction (2 indented rings for the 2 clip ring positions) desirable, but not essential.
Anduril 2 (of course) including all strobe modes!
5A+FET or 7.5A+FET depending on the LED (similar to KR1).
Range of colour options.
USB charging would be nice, but not essential.
Let me know what you think, of whether this needs it’s own thread.
tactical_grizzly
tactical_grizzly's picture
Last seen: 2 hours 9 min ago
Per Hank via email, K12.1 (or however many emitters it may have) will use three 18650’s for more runtime and thermal mass. Still many many months out and design is not finalized, but he is working on it.
ArtieT59
ArtieT59's picture
Last seen: 2 hours 4 min ago
tactical_grizzly wrote:
Lumen9000 wrote:
Hank Wang wrote:
Yes, they are very pronounced, even too pronounced which I'm afraid some people may not like it. It does not have USB charging function, the tube is different than the K1/K9.3 tube, which are not interchangeable. The charging port is removed to reduce the height and weight of the light as much as possible.
Then we hope an eventual 12.1 will get it instead.. ;)
Per Hank via email, K12.1 (or however many emitters it may have) will use three 18650's for more runtime and thermal mass. Still many many months out and design is not finalized, but he _is_ working on it.[/quote]
whoa.... AWESOME!,  TG!
And, YES!, i like the triple 18650 tube light size!
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
The BLF GT with SFT40 (2300lm, 2700m+ @ 30 seconds!)
https://budgetlightforum.com/node/79561
ToyKeeper
ToyKeeper's picture
Last seen: 1 week 1 day ago
Location: (469219) 2016 HO3 // I get way more privmsgs than I can respond to, so please ask in a public thread if possible, for a faster answer.
It’d be awfully difficult to make an illuminated tail e-switch. It’s difficult to get one wire to the back end of the light, but at least that’s reasonably straightforward since it can connect to a contact ring. With more than one wire though, a contact ring doesn’t work.
As for a clip, my favorite style is deep carry with the button end up. So for a tail switch light, it’d be a tail clip. For a head switch light, it’d be a head clip. That way, when you grab the light to unclip it, the button is right there without having to flip the light around.
Otherwise, I like it but I’d go for something narrower and less throwy. Like, 21-22mm in diameter (maybe 23 if necessary) instead of 25-28mm. And 8 to 12 cd/lm in a textured reflector/optic instead of 15+ cd/lm in a smooth reflector/optic. Probably a linear-only driver (or maybe a buck driver) with no direct-drive FET. Overall low mass for easy carry, even if that means it can’t sustain bright modes very long. It may even make sense to lower the power from 5A to 3A (or 2A, for a 219B emitter).
If it’s difficult to fit the parts on a driver that size, it could save a bit of space by switching from attiny1634 to attiny1616. It’s 3×3mm instead of 4×4mm, and needs only 3 pins to reflash instead of 6. This would mean using a different flashing kit though.
A tail switch light of this size would be pretty difficult, so it might need a slightly wider diameter to fit a wire or ribbon connecting the tail switch. A side switch version could probably happen in 22mm though, by adding a bit of length and allowing the button to stick out a little.
This wouldn’t have huge output numbers, but it would be very practical to carry around all the time.
Sounds like what I have in mind is pretty different… like a Mini-EDC-1 vs your Mini-Thrower-1.
Rayoui
Rayoui's picture
Last seen: 3 hours 6 min ago
You basically just described a Zebralight (save for lack of Anduril) Big Smile
I’d love to see a smaller single emitter tail switch Anduril light from Hank to fill the void that is left by the FW1A. Throw a buck driver in it and it would be the perfect EDC light.
Sillen
Sillen's picture
Last seen: 11 min 38 sec ago
ToyKeeper wrote:
ArtieT59 wrote:
A NEW COLOR?!?
I’m still hoping for purple.
My small but growing collection – magenta/violet/lilac/purple, I don’t judge – TrustFire MiniX & Convoy T3 in transit
stephenk
stephenk's picture
Thanks for your input. My list is really a wish list for the ultimate Anduril light for light painting photography (hence “throwy”, single emitter, 5A+FET, and 24-28mm tube) – a sort of updated BLF A6 to some extent, or slimmer KR1, and to also fill the void from the FW1A’s demise. As you mentioned, having a tail switch would require an inner tube, so it would need to be slightly thicker than typical 18650 lights.
The S2+ meets my personal needs for floody illumination (I use 2700k/5700k LH351D in the 5A lights, usually on 35% output), but it would be nice to see a “sensible” Anduril based light in that market as well with no FET (max ramp at 150).
zak.wilson
Last seen: 6 days 4 hours ago
Except that Zebralights have very efficient boost or buck/boost drivers, that being the main reason I usually carry an SC64c LE (ergonomics and build quality are also big advantages). I’m glad to see Hank doing a little more of that (even though the K1/XHP35 is inefficient on high), and would love to see it it something EDC-size.
I don’t think Hank designs lights by popular vote (a good thing), but I’ll say what I want anyway:
  • A roughly EDC-shaped tube light under 25mm
  • 1×18650, with the option for shorter tubes
  • Pocket clip held on with screws like a Zebralight
  • I don’t care very much if it’s tailswitch or sideswitch, but the latter would help it be thinner
  • Recessed switch like a Zebralight if a sideswitch is used
  • Single emitter
  • Reflector (option of textured or smooth) or TIR with a reflector-like beam pattern
  • Boost or buck/boost driver depending on emitter
  • B35A option, various 3V options
  • Anduril 2 and flashing pads, naturally
Ceilingbounce – flashlight testing and runtime graphs for Android
LuxWad
LuxWad's picture
Last seen: 2 hours 20 min ago
  • Single emitter
With an illuminated side switch this would be about perfect. I would add that metal cover on the switch would be really nice to see. It would also be great to have a reflector in the same size as a standard optic so the two could be easily swapped out depending on preferences. A choice between OP or smooth reflector would be fantastic
But then, would it really still be a Hanklight? Sure it would be great, but it doesn’t really seem to fit in with the other deisgns, since it’s not a mega-lumen flood or super thrower… if Hank made this it would be super popular of course, but isn’t the D4 already his take on that style of light?
Forsythe P. Jones
I think MCU-controlled flashlights these days have mostly moved to side switches because then they can be soft switches, controlling signals rather than switching large amounts of current that are easier to switch with a FET. The side switch connects the switch to the MCU without having to run a sleeve through the battery tube. The current itself is also a lot higher than in old lights, like 7+ amps in the case of the D4v2. High current lithium ion rechargeable cells let us do that. In the consumable cell era, even the insane Surefire lights that burned through two or three CR123A cells in 15-20 minutes only used 3 amps or so. The M6 may have used 6 amps since it had two sets of cells (6 cells total). So with the MN21 lamp (500 lumens) it cost around $30 an hour to operate. The tail switches on those lights (power only, no microprocessor) were quite massive. They were momentary-only pushbuttons which you could lock by tightening a lock ring. Surefire made several attempts to make clickie switches for its smaller lights, but afaik none of them worked very well.
Anyway I think an illuminated tail switch would take more compexity than we’ve seen here so far. I don’t mind the idea but it doesn’t sound like a big enough gain to be worth the increased diameter and other issues. I’m very happy with the D4v2, I can understand wanting a thrower of similar size, and I can also see wanting a thinner light, straight sided and maybe using 16650/16340. I do like the the coming SP10 Pro (dual fuel AA/14500) and would certainly buy a Hank light (i.e. same general idea but higher quality and minimal size) with that design.
Yes I’m in favor of switching to the Attiny1616 in future drivers even though it means a new flashing device. It’s a better chip in various ways.
JaredM
JaredM's picture
Last seen: 13 min 34 sec ago
Not sure how reliable it would be, but if the inner signal tube actually became bat+ powered from a current sensing circuit, and switch LEDs drew a constant baseline current which would be considered ‘0’ to the sensing mcu, then the switch would ‘short’ to gnd through a current limiting resistor, which would spike the sense voltage and therefore act as the switch signal. Maybe a zener could be utilized to differentiate between ‘baseline’ and ‘ signal ‘
https://fundrazr.com/osturaband
No affiliation, just a fan.
stephenk
stephenk's picture
There are plenty of side switch Anduril lights. For some use cases (such as my hobby of light painting photography) a tail switch is required as side switches are inaccessible when the flashlight is connected to a tool. Some flashlight users just prefer a tail switch. Hence my suggestion of an tail e-switch with Anduril 18650 tube light (approx. 25mm dia), as it simply doesn’t exist in the market right now. I think I can give up on the illuminated tail switch idea!
Forsythe P. Jones
Oh, that is interesting about light painting needing a tail switch. Maybe what we really want is a remote controlled light? There are lots of lights with remotes these days. It would be great to have one with Anduril. Here is a Fenix remote switch that seems to replace the tailcap on some of their lights:
https://www.fenix-store.com/fenix-aer-04-tactical-remote-switch
I guess for a side switch design there could just be a switch port on the side as well. I’d be supportive of this, especially with the t1616 processor, since it could be used for other stuff too, such as configuring or reprogramming the light.
stephenk
stephenk's picture
Some light painters use remote pressure switches (notably Klarus, Nitecore, and Olight), and again they need to be connected to the tail as the head of the light is in the adaptor/connector and inaccessible. RF remotes are more of an annoyance than a help and only really useful in RGB lights. Personally I like the momentary mode on Anduril, as it allows fine control of on/off. My buying guide to flashlights for light painting is in my signature.
stephenk
stephenk's picture
I’ve not seen any Zebralights with tail switches!
Rayoui
Rayoui's picture
You wouldn’t want to use one for light painting anyways. Zebra’s UI just isn’t cut out for it
stephenk
stephenk's picture
Very true. The only Zebralight that has interested me is the FC700D as it can sustain 1500 high CRI lumens, so great for backlighting, however they don’t sell it in Australia. So I’ll just stick with my Q8!
pol77
Last seen: 49 sec ago
How about a tail switch with tritium vials?
stephenk
stephenk's picture
That’ll do!
lazerEagle
lazerEagle's picture
Last seen: 3 hours 51 min ago
Who has tritium? more like unobtanium.
Speaking of unobtanium + 1 for 5000k SFT-40 emitter!
New torch looks super interesting, look forward to more specs.
- the best way to predict the future is to create it -
Knobbers
Last seen: 3 months 2 days ago
Hi Hank,
are there any new informations about the problems with german customs and resend the packages ?
I still wait for one flashlight
Hank Wang wrote:
Dear Germany customers,
Recently, many packages to Germany show the tracking status “No one available to receive the item, the package will be returned to sender”.
Actually, those packages have not passed German customs, and will be returned to UK sorting center, so, they will not be returned
to China. In the mean time, some packages did pass through the German customs and have been delivered to the customers sucessfully, so, we have no idea why those packages were refused by German customs. I think it’s related to the Brexit since all the package to Germany are handled via Royal mail in UK, but it’s only assumption.
Anyway, those packages are on the way back to UK sorting center.
So, our plan is to resend those packages as soon as we find a better shipping method to Germany.
It should take us 2 weeks (till the end of September) to handle this issue, and resend those package.
In the mean time, if you can not wait, you could also request refund for the orders.
Sorry for the inconvenience.
elendur
Last seen: 3 hours 35 sec ago
This new 40mm TIR looks like the battery tube screws in deep, a bit like in the K1. Is this the case?
I’m trying to make sense of the proportions. Is the switch farther away from the tail-end, comparing to the K1?
Looking at it makes want to hold it (*edit * meaning: it looks ergonomic, has a nice size, and I want one). Thanks for also making this green!
Valynor
Last seen: 2 hours 44 min ago
@Hank
Could you please post a picture of the DM11 standing next to a D4V2 + D4SV2 so we can a better feel for the dimensions?
Hank Wang
Last seen: 3 hours 30 min ago
Knobbers wrote:
Hi Hank,
We have already started to resend the package one by one, please let me know your order number via email, so that we can resend your order.
https://intl-outdoor.com, Noctigon, Emisar, flashlight components.
berogg
id30209 wrote:
TiCu or AlCu. Colors are for social networks, less colorful are for real use
As you ask for Ti, which is horrible for heat dissipation and more of a show piece variant. The very thing you’re accusing ano’s of.
id30209
id30209's picture
Read again…TiCu…
