I really appreciate the enthusiasm from reddit users, but for some reason, I’m not able to view Reddit recently, .
DM stanads for D and M series combination.
The price should be $55~75 depends on the versions.
This is prototype, but it’s 95% the same as the final version, the length is 120mm.
If the reaction from Reddit is any indication, you’re going to sell a ton of these lights – especially at that price!
Honestly this seems like it will be a great light for my uses, between the size and the B35 option, I’m very excited to try it out when it becomes available.
Of the emitters you’re offering in this light, do you have a personal favorite?
They are not, but we do have the tint ramping and independent dual channel version D4S V2 in stock,
you can send us an email for the custom build.
Very exciting! Hank, is there any extra cost when custom ordering with channel switching or ramping (besides the varied cost of different emitter options)?
There is no extra cost, we can even add the switch backlight for this new version, just like the D4V2 TI.
Hank, what is the output of this new dual channel D4sv2 driver (tint shifting, not ramping)? Is it 9amp CC? is that 9amps per channel ? (meaning 2x leds on channel one get 9amps while ON, and 2x LEDs on channel 2 get 9amp while ON?)
If doing an osram W2 version of new D4sV2, 9amp for 2x led's is fine, but so is FET if proper battery is used (green and white W2 can handle 7.5amps each = 15amps capacity). How should we order, what notes do you need to know?
If doing an osram W2 version of new D4sV2, 9amp for 2x led’s is fine, but so is FET if proper battery is used (green and white W2 can handle 7.5amps each = 15amps capacity). How should we order, what notes do you need to know?
For the 219B version, it’s 5A per channel.
For the XP-L HI, W1, W2, SST-20, it’s 9A per channel.
They are fully regulated, FET disabled.
What about this new driver in normal D4SV2? Possible or only in new tint-ramping and dual-channel?
Now just release DM11 and people will overload your site
Keys: Flashlight S11 MOD, Lumintop GT Nano, Astrolux LT1, Astrolux K2, Manker E02 II, Manker E03H II
For the 219B version, it's 5A per channel. For the XP-L HI, W1, W2, SST-20, it's 9A per channel. They are fully regulated, FET disabled.
For the 219B version, it’s 5A per channel. For the XP-L HI, W1, W2, SST-20, it’s 9A per channel. They are fully regulated, FET disabled.
is there fet on the driver? Is it just disabled?
It’s just disabled.
Does this tint ramping D4SV2 use the same driver as K9.3, just with a different firmware? Is K1 now using this same driver as well, again just with a different firmware?
Would it be possible to see this driver on D4V2?
Not sure about D4V2 since the driver pcb is too small, but we do have the same options for KR4 flashlight, I mean the tint ramping and dual channel versions.
Just to be clear, this tint ramping works like on K9.3, right? It’s not like on IF25?
It’s Anduril 2, so tint ramping works like any other Anduril 2 light: 3H from on (click 3x and hold the last click) and it will slowly ramp between the two emitter types. That’s how the tint-ramping K9.3 works as well.
Yes, indeed, K9.3, tint ramping/channel switching D4S V2, and KR4 are with the same driver, only different format.
Tint mixing, rint ramping, channel switching, it could be hard to understand for the users, that is why I have sent 2 pcs D4S V2 to LuxWad for reviewing, hopefully, he will explain the difference better in the video.
It's Anduril 2, so tint ramping works like any other Anduril 2 light: 3H from on (click 3x and hold the last click) and it will slowly ramp between the two emitter types. That's how the tint-ramping K9.3 works as well.
I don’t have any of mentioned models so i’m a bit confused how this works. So once you set desired temp it will ramp up and down in that CCT?
Can you specify?
Please make sure firmware is:
-Channel Switching: instantly switches from one channel to the other with no smooth transition
I saw that in one of you posts so I just asked for that in my emails to him!
https://www.youtube.com/luxwad < Videos
Hank, are the newly stocked D4Sv2 tint ramping?
https://intl-outdoor.com, Noctigon, Emisar, flashlight components.
Reddit | Grizzly’s Reviews | YouTube | Convoy Guide
Any plans to offer an IR option on any lights?
YES!! This is very good news indeed! A tint-ramping D4SV2 with a backlit switch is very exciting!
What about the driver? Same one or like in KR4/DT8?
Full: Jetbeam RRT01 XP-L HI, Fireflies PL47MU, Fireflies PL47G2 2021 XP-L HI, Emisar D4V2TI RO1 XP-L HI, D4V2TI RO2, XP-L HI Emisar DT8 XP-L HI, Emisar D4V2 LH351D+W1, Emisar D4SV2 LH351D+W1, Noctigon KR4 XP-L HI+Nichia, Noctigon KR1 SBT90.2, Noctigon DM11 SFT40, Lumintop ODL20C V2, Fireflies E07 XP-L HI, Fireflies E07 2021 XP-L HI, Armytek Wizard Pro Max WW, Emisar D18 X-PL HI, Noctigon K9.3, Niwalker ES2 (lot of modules), Weeltool W4, Fenix LR40R modded XP-L HI tint mix+W2, BLF LT1 v6, WildTrail WT90, Amutorch DM70 4000K, Imalent MS18W
If it has tint ramping then it’s an entirely new driver.
I tint ramping S model with a 26800 tube, please
https://fundrazr.com/osturaband
No affiliation, just a fan.
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
The BLF GT with SFT40 (2300lm, 2700m+ @ 30 seconds!)
https://budgetlightforum.com/node/79561
WTB Titanium 4sevens 2xAA tube
Has anyone measured Duv for the sw27 yet?
Can two channels be used simultaneously with a maximum power of 2 * 9A?
No, if the two channels to be used simultaneously, it would be 9A in total.
It’s just disabled.
Hmmm...you got my attention!
EDIT: going to wait for DM11 and order both
How about the DT8?
I am waiting for one and I am so curious
Flashlight addicted
Just to be clear, this tint ramping works like on K9.3, right? It's not like on IF25?
EDIT: gonna check some K9.3 videos
Can you specify?
Currently searching to buy:
Fireflies NOV-Mu 21 in 2000K
That was my question exactly… having 2 channels is what puzzels me. Are you using one or both at the same time?
