Noctigon DM11 high CRI middle range thrower available
3932 posts / 0 new
Gunga
Gunga's picture
Last seen: 11 hours 37 min ago
Thanks Hank. How do I order tint ramping kr4 again. None for D4v2 right?
Hank Wang
Last seen: 3 hours 20 min ago
There is purhcase link on the site, you can order the regular KR4 on the site, and let us know the order number,
it will be fine.
https://intl-outdoor.com, Noctigon, Emisar, flashlight components.
Gunga
Gunga's picture
Any chance of it happening in a D4v2 or too small?
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 1 month 1 week ago
Hank Wang wrote:
There is purhcase link on the site, you can order the regular KR4 on the site, and let us know the order number, it will be fine.
Hank, does 2x SST20-DR and 2x 219B-V1 3500K work together both in KR4 and D4SV2? If so, what driver will you be using? 5A noFET or 9A noFET? Are LEDs aligned in diagonally crossed pattern or two colors side by side?
Hank Wang
Lux-Perpetua wrote:
Hank, does 2x SST20-DR and 2× 219B-V1 3500K work together both in KR4 and D4SV2? If so, what driver will you be using? 5A noFET or 9A noFET? Are LEDs aligned in diagonally crossed pattern or two colors side by side?
Yes, this combination works for both KR4 and D4S V2.
There are dozons of different combinations.
We choose the suitable current for each combination.
For example, if you choose 219B on both channels, we will use 5A for each channels.
If you choose 219B on one channel, and W1 LED on the other channel, we will use 5A for 219B, and 9A for W1 LED channel.
If you have your preference, just drop us an email, we will customs make it for you.
LEDs are at crossed pattern.
Lux-Perpetua
Thank you Hank. That is very helpful information. I am just waiting for DM11 to become available before I make my next order for at least two more flashlights. Smile
norve
Last seen: 2 weeks 2 days ago
By the time waiting for DM11, my bad habit made me click the buy button for Kr4 tint shift verssion. Thanks Hank, waiting for it …
Only Hanklights
CollectEverything
CollectEverything's picture
Last seen: 1 hour 2 min ago
Hank, I’m wondering about ordering a D4SV2 with the new constant current driver but with 4 identical emitters (no tint ramping). In this configuration, will the maximum output be lower than the standard D4SV2 with the same emitters?
Collection: TN42, TN40S, Catapult V6, SP36 BLF, sc700d, sc64c LE, D4V2 CuZn, D4V2 CuTi, D4V2 Al x2, KR4 Al x2
Wishlist: Acebeam K75, Zebralight sc600w mk IV plus, Convoy M3-C
dave1010
dave1010's picture
Last seen: 11 min 49 sec ago
tactical_grizzly wrote:
It’s not specifically tint ramping, but actually channel ramping. Your emitter choices determine whether it’s tint ramping, color ramping, hotspot-width-ramping (digital zooming, sort of), or whatever.
If you have emitters with two different color temperatures (like 219B’s in 2700K and 4500K), then the color temperature will ramp. If you have two emitters with different intensities (like W1’s and XPL-HD’s), then the hotspot width will ramp (basically). If you have one set of green emitters and one set of red, then the color of the beam will ramp between green and red with every color in-between.
Good point. Actual tint ramping probably isn’t very useful at all – what people are after is CCT ramping.
What I mean by this is changing the tint or duv (how far above or below the BBL) but keeping the CCT constant.
For example if you wanted to, you could ramp between some rosy 4000K sw40 219B LEDs and some green SST20 LEDs that are also 4000K but why would you?
Szypo
Szypo's picture
Last seen: 1 month 6 days ago
Hank can you use a 7.5A noFET driver to power the 219BT-V1 diodes in the D4S V2 flashlight?
The question is about the D4S V2 in the two channel “channel ramping” version (2× 219B 2700K 7.5A and 2x XP-L HI 4000K 9A).
5A for two 219B diodes is a very delicate current. I would prefer 7.5A.
7.5A / 2 = 3.75A per diode
One 219BT-V1 diode can operate stably up to 4A.
http://i.imgur.com/bkodESs.jpg
LuxWad
LuxWad's picture
Last seen: 57 min 52 sec ago
D4SV2 – Cree XPL-HD 5000K/Osram CSLNM1.TG 6000K
My Review Channel - https://www.youtube.com/luxwad
Hank Wang
Hi, your request is fine, please send us an email, contact@intl-outdoor.com
RamBull
Last seen: 5 days 20 hours ago
Hank is possible to let us know the current you use for each emitter?
1) SST20
2) XP-L HI
3) 219b
4) W1
5) W2
6) LH351D
Hank Wang
1) SST20
2) XP-L HI
3) 219b
4) W1
5) W2
6) LH351D
Sure, apart from the 219B LED which is 5A per channel.
Other LEDs are all 9A per channel.
Szypo
Szypo's picture
Hank thanks for your reply.
Another question is about the flashlight in a different configuration:
More and more people want to buy an Emisar D4Sv2 flashlight with four Osram W1 LEDs with a single channel driver with full stabilization and with an unlocked FET for Turbo as it is in the KR4 flashlight (9A Constant Current + Direct Drive). Hank are you able to prepare such a driver for D4S V2?
I see that user “CollectEverything” is also asking for the same configuration.
The D4SV2 with 4 Osram W1 LEDs is offered with an outdated driver (FET+ 3). I think many people would gladly buy a D4Sv2 flashlight with 4 Osram W1, W2 or XPL HI diodes if it had a driver like the KR4 has (9A CC + DD), because such a driver would give very good high brightness stabilization.
Picture of my flashlights for attention Smile
!D4-SV2-D4-V2!
Hank Wang
!D4-SV2-D4-V2!
Hi, please send us an email for the request.
ch1ir
Last seen: 1 hour 41 min ago
!https://i.imgur.com/4NzJlwZ.jpg!
Omg, this is awesome, does this do tint ramping or channel swap? Or both?
Very nice setup for max output
Emisar D⁴, Astrolux C8, BLF A6, Sofirn sp36aV2, Reylight Mini Pineapple, BLF 348 KillZone, Lumintop IYP07, Emisar D18, Boruit D10, Manker e01, Ultrafire z1, Massdrop titanium AAA, Astrolux HL01, Armytek Wizard Pro Nichia, Tacklife LFL3A, Astrolux FT03, Zanflair T1
LuxWad
LuxWad's picture
That one does just channel swap.
This one is Nichia SW27/SW45k, and ramps between the two.
This Video shows both in action. I will be doing a more detailed video on my channel soon.
Also, lighted switches! Thanks Hank for making and sending these awesome lights Big Smile
bartekreaper
bartekreaper's picture
Last seen: 7 hours 34 min ago
Hank, will it be possible to put this new driver from KR4 in DT8? I saw noone asked about that.
Also SBT90.2 in DM11 possible? Smile
Keys: Flashlight S11, Nitecore TIP2, Lumintop GT Nano, Astrolux LT1, Astrolux K2, Manker E02 II, Manker E03H II
Full: Emisar D4V2Ti SST-20 4000K, Emisar DT8 XP-L HI 4000K, Emisar D4V2 LH351D 4000K+W2, Emisar D4SV2 LH351D 4000K+W2, Wurkkos TS21 SST20 4000K, Wurkkos TS30S, Armytek Wizard Pro V3 WW, Astrolux MF01 mini SST20 4000K, Emisar D18 X-PL HI 4000K, Noctigon K9.3 XP-L HI 5000K, Noctigon K1 SBT90.2, Niwalker ES2 (lot of modules), Weeltool W4, Fenix LR40R modded XP-L HI tint mix+W2, BLF LT1 v4, Imalent MS18W
Souldrop
Last seen: 1 week 3 days ago
Eta on when black will be back in stock for d18?
move
Last seen: 3 hours 27 min ago
Hi,
I’m planning to order D4v2. Is there a samsung leds options for this flashlight via sugestions?
(If yes, any post or information about it such as numbers of flashlights max and continuous outputs.)
Thank you!
tactical_grizzly
tactical_grizzly's picture
Last seen: 58 min 25 sec ago
Hank,
I’ve heard rumors that you are working on a 26800 body tube for D4SV2. Is this true? If so, do you have an estimated release date?
Are you working on 26800 tubes for any other lights, like K1 or K9.3? I believe a 26mm cell would fit.
furandchalk
furandchalk's picture
Last seen: 5 days 10 hours ago
I’ve been holding out for a 21700 single emitter w/ Anduril2 and – most importantly – a buck/boost driver for so long. I have a D4v2 (5A driver) but never use it because it can’t sustain the output I need. Was about to give up again and order a ZL SC700d. (And/or a KR1 and mod it with theFreeman’s or Loneocean’s drivers.) Can’t wait to order a DM11.
I know it would be absurdly heavy, but I’d get it in brass black. I’d actually get a K1 in brass black if it would take the DM11 driver. I’d have to lug it around for miles in the desert but it’s worth it for copper/brass.
Anyway, can we request the DM11’s driver in the K1? Will the D4V2 or KR1 get the new buck drivers?
tactical_grizzly
There has been no mention of buck drivers in any of Hank’s lights (including DM11) as far as I can tell.
knifeguyyy
knifeguyyy's picture
Last seen: 8 min 28 sec ago
Do we know when theDM11 comes out yet? Anyone already have any experience with the Nichia B35?
tactical_grizzly
According to this Reddit post it’ll be released “next month” (November) and there will be a pocket clip available.
Hank Wang
Hank,
Yes, that is true, the 26800 tube should be available by November.
There are no other 26800 project plans.
JaredM
JaredM's picture
Last seen: 25 min 14 sec ago
I think I might be getting a dm11 b35. Looking forward to seeing final specs and finishes. Curious how it’ll compare to a d4s 26800 with sst20s.
knifeguyyy
Thanks!
id30209
id30209's picture
I have plenty of B35AM and B35AR and so far they are my number 1 emitter in both 90+CRI and output ( 1500+lumens).
They are big bro's of 219B and E17/21.
WTB Titanium 4sevens 2xAA tube
