Noctigon DM11 high CRI middle range thrower available
4369 posts / 0 new
ToyKeeper
ToyKeeper's picture
Last seen: 2 hours 19 min ago
Location: (469219) 2016 HO3 // I get way more privmsgs than I can respond to, so please ask in a public thread if possible, for a faster answer.
LuxWad wrote:
The lowest level on this light is about 0.46 lumens, which is lower than any other boost-driver light I have used. Interestingly, the moonlight “jump-start” is much too strong on this light and causes a bright flash, even at the lowest level of 1/50. … It’s also very unstable on the lowest level, with a strong flicker that can even be seen in the video.
… the runtime test is literally done in a bookshelf @ 21C, so thermals are not best-case scenario.
On mine, I measured ~0.56 lm to ~1300 lm with a 50E cell. Moon was stable, but turbo wasn’t as bright as I expected. However, I haven’t measured with a higher-amp cell. It could just be a weak battery.
I see the moon pre-flash here too, and I wasn’t able to get rid of it. I think it’s a hardware quirk, because it shows up even with jump-start at level 1 (which is default, and effectively means no jump start at all). I should still double-check though, to make sure it still happens even when jump-start isn’t compiled in. As far as I can tell though, simply turning on the boost circuit, without even sending any PWM to the control pin, causes a brief flash. It’s sending a flat zero for the brightness level, and it still flashes.
For thermal tests, what I’ve found works well (simulates real-world use, approximately) is to rest the light pointed downward on a wire shelf, with a fan on “low” blowing gently toward it from about 1 meter away. I place a phone under it to log data, and I adjust the position so turbo mode reads roughly 50% to 90% on the light’s sensor. I’m using an old Nexus 4, and its sensor goes from 0 to 10,000, so I typically try to make turbo read roughly 8,000. This gives good resolution without clipping. Hooray for analog gain staging!
For narrow lights, I place a spare lens on the wire shelf, and put the light on the glass. That’s only if the light is small enough to fall between the shelf wires though.
thefreeman
thefreeman's picture
Last seen: 19 min 27 sec ago
The startup current overshoot is something that I have in all the boost drivers I’ve made, but it’s only really problematic with the MP3431 based ones, Loneoceans’ boost driver had this, Mike C’s too, he used a small FET to pull down the Op-Amp inverting input for a short duration during startup to solve this, when using a dual sense resistor topology for very low moonlight like I do this can be mitigated by waiting for a couple of ms before turning on the high power range FET.
Both of these solutions don’t have support in Anduril though, and it would need a hardware revision… depends how problematic it is in the case of the DM11, how bright is this flash ?
Edit : I missed Luxwad comment, so ”bright” it is.
Lumen9000
Lumen9000's picture
Last seen: 1 hour 15 min ago
Pavlo wrote:
MoreLumens wrote:
Pavlo wrote:
I think 1600+ lumens at a CRI of 9080 in a throwy beam coming out of a single LED is amazing.
It is. New age is here. Abandon all low cri trash and worship your new king!
Triple those, please. Cool
Funny though as I think most people still prioritize quantity over quality. Maybe this is subjective, but at one point I think 20% more lumens is a minor increase compared to the jump you get in clarity going from CRI 70 to 90+. There are a lot of bad tinted high CRI options out there, but enough good ones that personally don’t see the need to ever go back to a low CRI light.
For floody purposes, absolutely. For a thrower to lighten up something 100-200m away, I’m not sure. FF E07x pro, I would love some high cri, if it was 6000 lumen plus, but that generates heat. Ahrgh, it’s all a circle jerk with compromises!
m03da
m03da's picture
Last seen: 23 hours 8 min ago
Oh true, it’s weighted by a curve that peaks in the green region.
without darkness, light is meaningless
burnt pocket counter: 0001
(he/ him)
elendur
Last seen: 12 hours 52 min ago
Hank, what currents are you using for the newer e21a tint ramping drivers? Are you still using only 1.25A/led by default as with the original 5A driver?
Can we chose to use 1.5A/led – 1.6A/led? What about with the upcoming DT8? Thank you.
Hank Wang
Last seen: 1 hour 48 min ago
The tint ramping D4V2/KR4 use 1.9A per LED, so, total 7.6A.
DT8 should be available in 2 weeks time.
https://intl-outdoor.com, Noctigon, Emisar, flashlight components.
Lumen9000
Lumen9000's picture
Hank, How are you guys holding up? I guess that you met some pressure with the release of the tint ramping lights, plus the DM11. You must be working your asses of 24/7! Hope you get some rest from time to time! Smile
gregor
gregor's picture
Last seen: 20 hours 19 min ago
LuxWad wrote:
It’s not the full review, but here is my first look and impressions of the DM11 (Nichia B35AM 5000K).
The review will take another couple of months or so, I will have to get another with a different LED. I’m not sure which is better, SFT40 or XHP35 HI…
Hank, do you plan to offer this flashlight with more floodier optics, like mention in this review.
Thank you
Hank Wang
Thank you
You can always buy the floodier optic by sending $5 to contact@intl-outdoor.com, we will add it to your order.
fogofwar
fogofwar's picture
Last seen: 7 hours 28 min ago
Hi Hank, I’m asking out of curiosity… why don’t sell products on Taobao? I know you have a store that you can take Alipay but you don’t list any products. It seems like you have a fan base in China as well but they might have trouble figuring out how to order.
I’d be happy to recommend your lights to Chinese people I know but it’s too complicated for most.
Hank Wang
The short answer is, I’m too busy, and no time to maintain Taobao store.
fogofwar
fogofwar's picture
That’s understandable – Taobao customers typically expect instant customer service from 8am to 10pm. It sounds like you need to expand and hire more workers to take off some of the time burden. 加油!
tactical_grizzly
tactical_grizzly's picture
Last seen: 2 hours 53 min ago
Hi Hank, is there any possibility of an alternative body tube for DM11? The current DM11 tube is too aggressive and small. The pocket clip is unusable too. I would love to be able to buy a 26800 tube just like D4SV2’s. It’s perfect.
I am also curious, why did you choose to make D4SV2, K1, and DM11 all have slightly different threads despite being almost exactly the same diameter where the body tube connects to the head? Being able to swap a D4SV2 or K1 body onto my DM11 would solve all of my problems with it. Please consider using a standard thread pattern on new models with similar connection sizes.
Oleg'destr
Oleg'destr's picture
Last seen: 34 min 19 sec ago
And make an optional tail cap with a hole for a lanyard.
You can also use a magnet, as in D4V2/D4SV2.
JordanZHP
Last seen: 19 min 57 sec ago
Hi Hank, do you have any plans for a Copper DT8? Thank you.
ch1ir
Last seen: 3 min 46 sec ago
Is it just me or did the price go up a couple of dollars and the clips and other add ons disappeared
Emisar D⁴, Astrolux C8, BLF A6, Sofirn sp36aV2, Reylight Mini Pineapple, BLF 348 KillZone, Lumintop IYP07, Emisar D18, Boruit D10, Manker e01, Ultrafire z1, Massdrop titanium AAA, Astrolux HL01, Armytek Wizard Pro Nichia, Tacklife LFL3A, Astrolux FT03, Zanflair T1
TexasToasted
TexasToasted's picture
Last seen: 1 week 4 days ago
I ordered Nov 25 and the price has not changed for the version I ordered- green with green switch led, and 3500K, B35AM LED. Still $74.65
I never saw any other options listed when I ordered. Only the body color, switch color, and emitter.
Ryzbor
Ryzbor's picture
Last seen: 2 weeks 5 days ago
Does the D4Sv2 already have the linear FET driver, or does is still use the old amc + fet one?
virence.com Nichia E21A sw30+sw40 Wizard Pro ; Skilhunt H03 XP-E2 660nm ; Wizard Pro E21A 2000K ; S2+ E21A sw40 d220 ; Sofrin C01R 660nm, Mf01 Mini Nichia 219B sw35+sw40
-ROYCE-
Last seen: 7 hours 18 min ago
Prices did increase by $5 for the newer models but the add on cost for B35AM and XHP 35 HI on the DM11 decreased by $5 so you wouldn’t notice a difference with that particular build.
ch1ir
Boss ty, so close to pulling the trigger
Streamtronics
Streamtronics's picture
Last seen: 2 hours 32 min ago
I wish there was a blue switch back light option. I thought that used to be available? Now I guess I'll have to decide between cool white and cyan when the SFT40 DM11 comes out, but I already have a light with cyan back light T_T
LuxWad
LuxWad's picture
Last seen: 1 hour 28 min ago
thefreeman wrote:
…how bright is this flash ?
I tried to test it, but it’s so quick it wasn’t easy to get a meaningful measurement – it appears to be about 1.6 lumens, so not exactly “bright” it seems Silly
Thanks also for the added info on the driver!
Interesting, all the previous tests were done with a Wurkkos-branded 5000mAh cell. I switched it out for a Molicel P42A and measured the exact same output, so at this one at least doesn’t seem to care about the battery used.
Perhaps I should start adding a fan in the runtime tests – I do mine with the light facing upwards in a white cubicle bookshelf, with an old Galaxy S-something plugged into life support specifically for measuring runtimes.
tactical_grizzly
If you add cooled runtimes, make sure to keep doing uncooled also! The vast majority of runtime tests are uncooked so they’re only comparatively useful if there are uncooled ones to reference against other lights.
Zero only does cooled runtimes, and while that may be nice for representing you holding the light and using it on a cool breezy night, his runtime tests are largely useless for comparison against other lights as tested by other reviewers.
They’re only useful for comparison against other lights he’s reviewed because the testing parameters remain the same.
ToyKeeper
ToyKeeper's picture
The same is true for every reviewer. Each person has a different setup for this sort of testing, so the variation is far more inconsistent than for things like lumens. At least with lumens, people can obtain reference lights and get within roughly 10% of the same value as other people… but for thermal runtime/output tests, one person might test at 15 C ambient temperature with a fan, while another might test at 30 C uncooled.
It can also vary significantly for a single reviewer. Like, even with HVAC and a thermostat, room temperature could be 17 C to 22 C in different seasons. A light may appear to regulate at a higher lumen level simply because it was measured during the winter.
gregor
gregor's picture
Anyone from EU on this forum Big Smile ?
Did you maybe buy any flashlight from https://intl-outdoor.com/ after 1.7.21?
Did you have to pay VAT, custom clereance costs?
Thanks
funwok
Last seen: 16 hours 22 min ago
Depends on the country and shipping method. For Germany -> normal shipping, no extra VAT/charges. Express shipping -> FedEx will send you a letter with custom/VAT fees.
Pavlo
Last seen: 57 min 45 sec ago
Hank,any chance you introduce Cree XQ-E High Intensity?
I think it would be a really good option for channel switching lights. Right now the throwy options are all cool white low CRI Osram. Offering Cree XQ-E HI will open the door to a much bigger range of CCT and CRI with an LED that has three times the throw capability of XP-L Hi.
Smile
Edit: XD16 also looks interesting and capable of 2 amps recommend max current.
TermsakC
TermsakC's picture
Last seen: 2 hours 56 min ago
A question for Hank: I saw on the Emisar/Noctigon website that there will soon be a new 26800 tube for D4SV2, in grey and cyan.
I am planning to buy a cyan D4SV2 this month and I want to include the 26800 tube in my purchase order.
When the 26800 tube will be available?
-ROYCE-
SFT-40 is available now.
JaredM
JaredM's picture
Last seen: 19 min 45 sec ago
Well thanks for that. Might have to order now.. Must. Resist..
https://fundrazr.com/osturaband
No affiliation, just a fan.
