519A 5700K, 4500K, 3500K are available.
5283 posts / 0 new
tactical_grizzly
tactical_grizzly's picture
Last seen: 3 hours 10 min ago
I agree that D4V2/DW4/DT8 do not have enough threads on the front of the body tube for the charging adapter’s port to be in the threads. It would need to be placed either on the face of the charging adapter next to the center positive terminal, or on the outside and covered by a rubber flap.
Westie
Westie's picture
Last seen: 1 week 23 hours ago
bobvoeh wrote:
I believe you can email Hank for the lighted switch. He will give you the secret SKU to enter on the website to pay the extra cost. I already have the SST-20 in 4000k in a DT8, so I wanted something different so I went with the Nichia’s.
Thanks for the info.
How do you like it? I’ve read that the high CRI options are nice but underwhelming. People expect a hot rod since it’s a Hank light. Something reasonable is not an option Smile
PyriteParachute wrote:
In LuxWad’s review of the dm1.12 (https://budgetlightforum.com/node/81698), he noted that the model could benefit from a frosted optic option for the flood channel. I thought there was a floody option for the d18. Aren’t these the same optics? Anyone know for sure?
I believe that he said that they don’t fit.
norve
Last seen: 2 days 23 hours ago
Hikelite wrote:
The thread count on the D4v2 head is simply too small for that.
One more piece causes one more anodizing nuance mismatching, not a good thing at all.
Same here, I dont think to have 1 more part for charging only is a good idea
Only Hanklights
bobvoeh
bobvoeh's picture
Last seen: 5 hours 5 min ago
The light it puts out is great, very natural. But if you are looking for max lumens, it is lacking there. A couple of weeks ago I got another DT8 with the Osram W2’s. This one is much brighter. I think with the SST’s, the DT8 puts out around 4000 lumens and with the W2’s around 6000.
I have to make a new ring for the Lumen Tube I just got from TexasAce and then I can get real numbers.
tactical_grizzly
norve wrote:
Hikelite wrote:
The thread count on the D4v2 head is simply too small for that. One more piece causes one more anodizing nuance mismatching, not a good thing at all.
That’s precisely why it’s a separate part. You can choose not to buy it and have your port-less light that you want, while others can choose to buy it and have a charging port.
Shimshamtymamm
Last seen: 4 days 22 hours ago
I like this option.
m03da
m03da's picture
Last seen: 7 hours 42 min ago
It could be selectable.. Like magnetic tailcaps, check here if you want a USB charging tube, check here if you want an extra non-USB tube.
Hank Wang
Last seen: 5 min 54 sec ago
https://intl-outdoor.com, Noctigon, Emisar, flashlight components.
pol77
Last seen: 16 hours 43 min ago
Great news Hank! Do you know if they are 5 stage or 4 stage? And if they are L5 or L6?
Bob_McBob
Last seen: 3 hours 46 min ago
Great news! Will 2700K and 3000K be available soon?
Gunga
Gunga's picture
Last seen: 31 min 16 sec ago
Same question as above. I wanted a 2700/4500K mix.
Lightenzaza
Last seen: 6 days 12 hours ago
Great, but AVAST is detecting something on the site .
Caught a sickness . I found out i'm not alone .
p12gt, tn12v4, s1, tk15, s2+, l8, pd35tac, fd65, tk35 ue 2018, d4v2, kr4, kr1, d4sv2, fw3a, x9l, sp31v2.0, sp32av2.0, sp36blf, sp40, lt1, sp31uv, sc31pro, sc21, hs05, hs10, e07, e07x, tk18, pt40
BlueSwordM
BlueSwordM's picture
Last seen: 1 hour 18 min ago
It’s probably Avast’s fault TBH.
No trackers, no ads, no nothing on the Emisar website.
zak.wilson
Last seen: 5 hours 57 min ago
This kind of thing comes up on occasion because the heuristics these programs use don’t like something about Hank’s web hosting. It’s a false alarm.
Ceilingbounce – flashlight testing and runtime graphs for Android | Zak Reviews – my flashlight reviews, with lots of runtime graphs
lededf
Last seen: 4 weeks 1 day ago
Does anyone know the maximum lumen outputs of the 519A 3500K domed and dedomed, or where I can find the info? It is not mentioned under the D4W specs.
Andometto
Andometto's picture
Last seen: 1 week 3 days ago
Hi Hank,
Will there be an option for 519A in the DM11 and KR1?
Thanks.
Kit Latura
Last seen: 1 month 3 days ago
Andometto wrote:
Hi Hank,
Thanks.
+1
carsknivesbeer
carsknivesbeer's picture
Last seen: 6 hours 8 min ago
If there is enough interest will 519a 2700k be available in the future?
stephenk
stephenk's picture
Last seen: 5 hours 25 min ago
I think Hank has ordered 2700k, they just haven’t arrived yet.
will34
will34's picture
Last seen: 1 hour 1 sec ago
How much output should one expect from 4× 519a paired with the boost driver?
Around 1,800?
Shimshamtymamm
I saw an email from Hank stating 2700k would be in next week.
LTC
Last seen: 12 hours 20 min ago
My guess or estimation… at least 2400….
Around 1,800?
trevormbell
Last seen: 2 weeks 6 hours ago
For those wondering about outputs from quad lights. Check out this guide from Reddit. https://www.reddit.com/r/flashlight/comments/uewiqz/more_estimates_of_ou...
BlueSwordM
Basically, to calculate output, take the output of 4 LEDs at 2A, remove 5-10% from heat, and 10-20% from optics, and you’ve got the final output.
tactical_grizzly
1920 lumens
LTC
So meaning base on raw data from Djozz, 519A @2A for 651 lumens… How much we will be getting?
BOMBAY
Last seen: 3 hours 6 min ago
Why are the results of this table for the xpl hi version lower than in reality?
zak.wilson
In theory, things are the same in theory and in practice…
BOMBAY
The author relies on the test results, but for the xpl hi version he intentionally lowers these values. This table sucks
BlueSwordM
So yeah, 2000 lumens from the 519A model at 12V 2A seems perfectly reasonable.
