21700 D4K is available for pre-order
5695 posts / 0 new
zoulas
zoulas's picture
Last seen: 12 min 46 sec ago
Can someone post the link for the boost driver information, thanks in advance.
kokosnh
Last seen: 14 hours 48 min ago
CollectEverything wrote:
What I would like to see next is a Thrunite T2 competitor from Hank using this same tube, XHP 70.3 Hi/FC40 and a nice efficient driver
But we do have TS22 from wurkkos for 40$, it would be hard to go against it.
Flashapotamus
Last seen: 2 weeks 1 day ago
Hank does the D4K use the same head as the D4V2? Could I purchase a D4K tube and tail cap separately and use them with my D4V2 head? I would like to get a little extra runtime out of my D4V2 E21A 3500k and I don’t want to end up with 2 basically identical lights by ordering a D4K with the same emitters.
Scallywag
Scallywag's picture
Last seen: 6 hours 59 min ago
Almost certainly not. It would be quite tricky to make a 21700 tube thread into an 18650 head. The tube must be physically larger diameter
kokosnh
But D4v2 head thread opening is larger than 21700, hence the question
I even grabbed my D4v2, and 21700 to check it.
But well hank only said that the sizs of the head is the same, he didn't say it's identical, so I'm waiting for the answer as well.
thefreeman
thefreeman's picture
Last seen: 1 hour 10 min ago
Hank said the head is different.
With 22mm threads (d4v2) you would not be able to make a 21700 tube for it.
lotari
Last seen: 1 month 4 weeks ago
You could, if the battery doesn’t go inside the head. The extra space could be used for a hidden USB-C charging like in the K1 and K9.3 tube.
That would be a cool way to update everyone’s D1/D4/DW4/DT8 to 21700. Though for a business it’s of course better to introduce a whole new model, or a series (K = 21700), than to just sell fancy tubes for existing flashlights.
CollectEverything
CollectEverything's picture
Last seen: 16 hours 52 min ago
I see the TS22 but I think Hank could create a light that was distinct from it.
  • No internal charging for a lighter, more compact package
  • The choice to have either XHP 70.3 HI or GT FC40, maybe XHP 50.3 HI
  • Andúril firmware
  • Backlit button (rgb or fixed)
For it to be a really killer light it would need a driver that could hit those crazy 4000+ lumens but also be incredibly efficient at the medium levels. If it ONLY hits the other points I mentioned it would not really compete with something like a Thrunite T2 (using that for comparison since I don’t have any familiarity with the real world performance of the TS22)
My Collection
kokosnh
thefreeman wrote:
Hank said the head is different. With 22mm threads (d4v2) you would not be able to make a 21700 tube for it.
it's 23.40mm opening, and the threads appear to be 0.60mm height, so we have around 22.20mm
The cell should have about 21.50mm opening minimum (better to have more), to fit most 21700
(22.20-21.50)/2=0.35
So we got 0.35mm for the tube walls, yeah not possible...  cry
I could have measure it and do calculation earlier... and not just eyeball it
tactical_grizzly
tactical_grizzly's picture
Last seen: 10 hours 49 min ago
  • Andúril firmware
I would also be interested in this. A D1K, if you will. D4K diameter head (obviously it will need to be deeper to fit a reflector) but with all the emitter options from D1V2.
LuxWad
LuxWad's picture
Last seen: 13 hours 14 min ago
Honestly I feel like Hank could have updated ALL the 18650 side-switch lights (D4V2, DT8, D1V2, DW4) with the new wider head diameter, then added a new 18650 tube to fit the new head design.
Right now it wouldn’t make sense though from a manufacturing/business standpoint, considering he’s already invested into the 22mm tube system for the most recent lights
Scallywag
Scallywag's picture
I wish the 21700 lights had standardized threads, so the tubes between DM11, K1, D4K were interchangeable.
James C
Last seen: 3 hours 16 min ago
I think the DK4 highlights how chunky the D4V2 is. Don’t get me wrong, I like it a lot, but frankly it’s too big for me to comfortably pocket carry.
I’m sure other people have had this idea, but I’d like to see Hank make a compact 18xxx light as a triple instead of a quad.
Here’s a modded Wowtac A6 triple compared to a D4V2. It might be hard to imagine with the pic, but there’s a huge difference in pocket-ability.
zoulas
zoulas's picture
This looks awesome.
xevious
xevious's picture
Last seen: 3 days 16 hours ago
I’m overwhelmed by the emitter choices…
Would be nice if there was a good writeup of characteristics to expect with each one, and maybe even comparative qualities (why one might choose 1 LED over another while still very similar in output/efficiency). Is there a page floating about somewhere in this long thread that takes a good stab at it?
kat
Last seen: 16 hours 25 min ago
Yes, I would be interested in that too.
From the emitter list I am familiar with the 365nm leds, so I immediately bough a D4v2 with 8 5W uv leds Big Smile
But I would like to get 2 more D4v2 lights with regular high CRI leds like Nichia 219, and not sure which one to choose because there are so many new leds.
The new D4k, how larger is it compared to D4v2?
EraZorX
xevious wrote:
I’m overwhelmed by the emitter choices. Would be nice if there was a good writeup of characteristics to expect with each one…
I found the following reddit threads helpful for helping me pick, it’s not a comprehensive list but it’s most of them:
Thread 1
Thread 2
kat
Niceee
So best option looks like it is a Dual channel Emisar D4v2 with W1 + 519 4500K
Streamtronics
Streamtronics's picture
Last seen: 3 weeks 3 days ago
kat wrote:
Niceee So best option looks like it is a Dual channel Emisar D4v2 with W1 + 519 4500K
There is no best as such, it’s always a compromise, that’s why all the other options exist (and are frequently ordered) in the first place.
kat
True. But if you want both good throw as a search light, and nice flood for when you want to light up a big area closely, I think those are the best options.
Question regarding dual channels: does ramping work the same with dual channel lights? I mean, can I still have low to high lumen ramp for just 1 channel that I choose?
CM2010
Last seen: 15 hours 25 min ago
Will the KR4 be upgraded to 21700?
Streamtronics
Yes, brightness ramp works just as expected (1H), the channel mix is set with 3H (it replaces momentary turbo).
gustavoppires
Last seen: 1 month 1 week ago
!{height:800px; width:600px}https://i.imgur.com/AaexxGx.jpg!
This would be awesome… A compact sub-50g triple to beat FW3A / FW3X. 14500 lights are intresting also, but IMO it trades a lot of runtime/heat management for size.
Shimshamtymamm
Am I wrong when I say lh351d is a better flooder than 519a? I like the tint better with 519a but I’ve heard it’s not as wide/flood as the lh351d.
stephenk
stephenk's picture
Last seen: 2 hours 32 min ago
519A is still pretty floody, and has a better tint and higher CRI than the LH351D, but with less output. In lights with TIR optics, there will be a very wide spill beam for all emitters. However floodier emitters will have a brighter spill beam and less bright hotspot.
Zafiro Añejo
Zafiro Añejo's picture
Last seen: 6 hours 26 min ago
Hank, do you offer D4K as mule with 16x E17A 1800K or E21A 2000K? If so, would a boost driver make sense, too? Hoping for a positive reply. Big Smile
kokosnh
It's right there in the "DESCRIPTION"
The boost driver upgrade is available for the SST-20, Osram W1/W2, Nichia 219B R9080, as well as 519A version, each LED receives 2A current. The driver is not compatible with Nichia E21A, Nichia E17A, and mule versions of the flashlight.
karmii
Last seen: 3 hours 29 min ago
Also hoping for a xhp70.3 D4K, mule or shallow op..
Chatika vas Paus
Chatika vas Paus's picture
Last seen: 53 min 4 sec ago
I’m afraid that you have to make custom D4K by your own, buddy.
kiriba-ru S2+ and S21a spacers are available in EU. PM me. A few details here
Shimshamtymamm
Awesome. Thanks!
