November 22.
KC1 keychain light is available for now.
OTF lumen output at start-up for Nihm, direct drive when 10440 is used
Nichia 5700K R9080 dedomed 519A around 85lm OTF
Nichia 4500K R9080 around 72lm OTF
Nichia 219B R9080 4500K around 90lm OTF
SST-20 6500K/5000K: 77lm
SST-20 4000K/2700K 95CRI: 106lm
August 15.
D4K triple channel version will be available soon,
Interest collect, K9.3 new configuration option, UV channel, and the same option for the DM1.12 in the future.
D4K TI colorful version in stock,
2022-09-08
D4K for pre-order.
2022-08-20
RGB button has been added for D1, which can show the voltage just as K1.
2022-08-18
SFT-40 & FC-40 options have been added for Noctigon K1 flashlight,
2022-8-3
UV 5W 365nm with ZWB2 filter is available for D1
2022β07-23
Noctigon DM1.12 is for sale,
2022-05-25
519A 5700K, 4500K, 3500K are available.
2022-4-30
DW4 single channel / dual channel version in stock.
2022-04-26
D4V2 boost driver (single channel) option is now available
2022-04-06
KR4 / D4S V2 boost driver (single channel) option is now available.
The boost driver upgrade is available for the quad version of XP-L HI, SST-20, Osram W1/W2, Nichia 219B R9080 versions, each LED receives 2A current. The driver is not compatible with Nichia E21A, Nichia E17A, and mule versions of the flashlight. Please be noted that the boost driver version does not mean higher output than the regular version, it is a more efficient driver.
KR1 B35AM LED option available,
Some beamshots comparsion
2022-03-23
KR1 GT FC-40 LED option available.
2022-03-09
E17A R9050 1850K & E17A Azure available for D4V2/KR4
2022-03-05
Noctigon DM1.12 available soon,
2022-02-20
2021-11-24
Nictigon DM11 high CRI middle range thrower available
2021-09-25
Nichia 219BT-V1, R9080 Warm White, 2700K is available
Tint ramping version Noctigon K9.3 is available
2021-07-08
Just got some limited quantity Nichia 219B, R9080, 3500K & 4500K LEDs in stock.
2021-06-04
D4V2 TI sandblasted version in stock (18350 tube is not available)
Also the antique version for both copper and brass version for pre-order (18350 tube is not available)
2021-05-12
DT8 double quad flashlight in stock.
2021β04-28
Just got a small batch XP-L HI T6 8D LED in stock, 2800K, 90CRI, we will not put it for sale on the site,
if you like it, please order the XP-L HI V2 5D 4000K version on the site, and send us an email,
so that we can use XP-L HI T6 8D LED for the light you purchase.
2020-12-21, E21A 2700K, 2000K version back in stock for D4V2/KR4 series.
2020-11-6, D4V2 full copper version in stock,
ββββββββββββββββββββββββββββ
2020-09-29
Noctigon K1, all colors back, including green version, 35HI version restocked.
D4V2 cyan version available,
2020-08-28,
KR4 TI copper version in stock,
KR4 Nichia E21A version in stock.
βββββββββββββββββββββββββββββββββββββββββ
Noctigon K1, SBT90.2 version is coming, 4500lm, 420Kcd, 5A constant current. (April. 18)
βββββββββββββββββββββββββββββββββββββββββββββββ-
US warehouse stock at sales price, 7 days delivery within US. (April, 23)
Emisar D4V2 TI colorful series in stock. (April, 10)
customize your own KR4 tailcap.
April, 3rd, 2020, the 8 pcs 3535 LED mule for the D4V2 and KR4 is available,
March, 22, Noctigon KR4 is for sale.
β’ 5A Constant Current + Direct Drive
β’ Pocket clip and lanyard ring are both included in the price, which is easy to exchange
β’ Discrete knurling
β’ Grippy anodized surface
March, 2, 2020, we have come back to work, everything is back to normal.
November, 24, 2019, D4V2 Brass is up for sale.
Emisar D4V2 Ti is for sale now
Apart from the Cu+Ti host, the main upgrade of D4V2 Ti is the switch back light.
When the light is at OFF state, the switch backlight behaves the same as the aux LED.
When the light is at ON state, the switch backlight changes brightness with the main LED.
