Lumintop GT nano on the way
828 posts / 0 new
Gebe
Last seen: 12 hours 51 min ago
jon_slider wrote:
chooma wrote:
Just some size pics
great photos, thank for the “joint” effort
looks like the 10180 Nano body, works with the nitefox head.. nice!
and did a 10440 work in your Nano, without making the LED turn blue?
My Nano from Skylumen has a copper board. I have used it pretty extensively with both the TiHi and Nitefox 10440 tubes and absolutely no bluing of the LED.
I was happy too that the Nitefox head works great with Nano Body. A two for one great buy with the Nitefox!
roostre
Last seen: 1 hour 10 min ago
Thanks for taking the risk and posting your results.
Did you use a 10180 Li-ion battery in the GT Nano body with the NiteFox K3 head or did you use a 10180 NiMH battery?
If so, it is very interesting that the higher voltage Li-ion battery did not damage the NiteFox K3 head and now I am wondering if the stock NiteFox would be damaged if I used a 10440 Li-ion battery in it (which may allow a higher current flow than a 10180 Li-ion battery would) and how much brighter it would be compared to using a NiMH AAA battery.
I do not have any 10440 Li-ion batteries yet, but did purchase the two-pack of the NiteFox K3 single-AAA-sized twisty lights from AmazonUS along with my GT Nano.
How many flashlights does a "real man" need?
None, real men are not afraid of the dark.
Gebe
Yes, 10180 Li-Ion cell with the Nano body. I wasn’t aware they came in NiMH. I haven’t used the Nitefox head with the Nano body a whole lot but so far no problems and boy, the little sucker is bright. I’m sure it’s not advisable for extended period use but I’ve used it for 1 to 2 minute periods with no ill effects so far.
A problem with using Li-Ion cells with lights that aren’t recommended for their use is sometimes you’ll lose some of the functions such as strobe, low mode, etc.
roostre
Gebe wrote:
Yes, 10180 Li-Ion cell with the Nano body. I wasn’t aware they came in NiMH...
Earlier in this thread, forum member "jon_slider" mentioned some NiMH 1/3 sized AAA batteries that are almost the same size as a 10180 Li-Ion battery and that was the first time I had ever heard of this size and do not know anything else about them:
https://budgetlightforum.com/comment/1748796#comment-1748796
jon_slider wrote:
...can the Nitefox driver can handle LiIon too?
otherwise use a corresponding primary cell in 10180 size?
for example 1/3 AAA NIMH
(I dont know if it fits the Nano body...) ...
zoulas
zoulas's picture
Last seen: 6 hours 31 min ago
Just got mine. Very cool. It wont replace my larger 18650 based lights but cool nevertheless. My first impression was from the box size. The box is smaller than a pack of cigarettes.
chooma
Last seen: 45 min 47 sec ago
A member posted this on CPF….
“I was excited to see you post this extension for the Nano, so I quickly ordered one and it came last night. I popped a good 10440 cell in it and turned it on. All was well till I kicked it into turbo. A few seconds after being in turbo the light went very purple. I pulled the body off and the battery was not being popped up via the spring at the tail of the body. Not sure if that was the cause of the issue or not.
Now, when I put the 10180 battery in the output is lower and the overall light is purple with a small tan spot in the middle. Seems like it may have been overdriving the LED somehow… bummer. At least this happened on a fairly cheap light, I guess.
Just a warning to others, but I’m sure it’s an anomaly of bad luck for me”
No issues for me….
chooma
jon_slider wrote:
chooma wrote:
Just some size pics
No Blue issues for me Jon…
Gebe
No issues for me….
When I purchased my Nano from Vinh, there was no mention of a copper board or anything else. When I received it, it definitely had a copper board. Later after visiting his site on CPF, he said he didn’t sell them without a copper board.
There’s been many reports now of the Nano’s LED turning purple when turning on turbo but thankfully I haven’t had any such problem and have used turbo in my example in short bursts without any problems.
Anyway, now I notice that Vinh recommends buying the Nitefox light if you want a 10440 tube. BUT he cautions, use it at your own risk!
It looks like these Nano heads can handle 10440 tubes or not.
jon_slider
jon_slider's picture
Last seen: 1 hour 16 min ago
Gebe wrote:
chooma wrote:
No issues for me….
thanks Gebe and chooma for the reports
do you use protected, or unprotected 10440?
Muto
Last seen: 2 hours 23 min ago
Got one today and am using Ultratac K18 tube with Efest 350mAh 10440 no problems yet.
Has a decent clip on it that works well with Nano plus has spot for trit.
As a bonus the Lumintop shorty 10180 tube fits and works on the K18 head.
The K18 is currently only $19.99 on Amazon without lithium battery package.
Happy so far!
The difference between Hoarding and Collecting is the illusion of Organization
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
roostre
This is my first experience with Narsil, so I have carefully read the NarsilM v1.3 User Manual included with the GT Nano and the main NarsilM forum thread.
According to the GT Nano manual, the factory default for the "Auto Step Down" setting is "Temperature", but the results from my light's "Driver Temperature Query" are very inaccurate and there does not seem to be any adjustment to correct this.
When I do a triple-click "Battery Status Query" followed by a double-click "Driver Temperature Query" with the light stabilized at 24º C room temperature, the light reports that the driver temperature is 38º C which is 14º too high.
If I continue on by doing a double-click "Firmware Version Query" followed by a 2 second button hold, the light blinks 4 times confirming that I have successfully reset the light to the factory defaults.
After resetting the factory defaults with the light still at ~24º C room temperature, the "Driver Temperature Query" initially reports that the driver temperature is 44º C which is now 20º too high but in a few hours it drifts down to reporting 38º C again.
I have not yet used the "Auto Step Down" configuration mode to select "Temperature" which then turns the light on at 100% brightness while you hold the light to feel it's temperature and then click the button when you feel the desired temperature level that you want to set the thermal limit to. I am not sure how well this will work with a low capacity battery in a small light.
Some issues I wonder about:
1) Does the "Driver Temperature Query" from Narsil lights report the temperature accurately and is there an easy adjustment to correct an inaccurate temperature readout?
2) Is there any way to confirm that the "Auto Step Down" configuration mode is set to "Temperature" or should I just enter this mode and quickly click within 5 seconds which keeps the previous configuration which (since I have not set my light) would be some unknown factory default temperature limit?
3) Is it always recommended to do the "Auto Step Down" mode "Temperature" calibration (where the light runs at 100% brightness until you click) both initially before first using the light and after resetting the factory defaults (since this is supposedly the factory default setting)?
4) How does the light behave thermally if you never do the "Auto Step Down" mode "Temperature" calibration (where the light runs at 100% brightness until you click) since this is supposedly the factory default setting?
I doubt any of this makes much difference when using the GT Nano with the miniature 10180 Li-ion battery but it may be important for thermally protecting the LED when using a larger 10440 Li-ion battery and I am also curious what thermal strategy others use with NarsilM in the larger GT-series and other NarsilM lights.
Notmyrealname
Last seen: 8 min 5 sec ago
For anyone who wants to know, an email from Lumintop tells me that only the first batch of Nanos in 2019 had aluminum boards and also that the 10440 tube is still under testing and will be released as soon as available. So that means….absolutely nothing.
I feel sorry for people who don't have a hobby or interest to escape to.
jon_slider
thanks for sharing info
I got replies from all 3 email inquiries to lumintoponline.com, lumintoplighting.com and lumintop.com
they all said the copper nano is not yet in stock
I wrote back to ask each of them, whether all 3 sites are part of the Lumintop company, or if any of them are separate private resellers.
Gebe
jon_slider wrote:
Gebe wrote:
chooma wrote:
No issues for me….
Unprotected Efest IMR10440.
Tom E
Tom E's picture
Last seen: 7 hours 23 min ago
I wrote Narsil/NarsilM, but doesn't mean I remember everything smile
1) --> Temp and voltage calibration are compile time settings - there's no UI to set them, and no way to see what they are set to
2) --> Don't think there's any way to see the current setting. If in doubt, set it the way you want it
3) --> Hhmm. I think so if that's what you want.
4) --> Not sure. Based on the driver design, you cant be sure the temp is accurate, and heat depends on amps, which depends on what the battery can deliver, which is based on how charged the battery is, plus how much resistance there is (springs, wires, etc.). There's no definitive answer here. I'm surprised lights are still being shipped with NarsilM actually. I gave up on it a couple years ago.
Also I don't know what their factory default is. NarsilM can be custom configured with compile time settings, and I don't know what the exact source code is they used. They don't even tell me a light is using my firmware, yet alone ask me to help tweak it for the specific light.
roostre
Tom E wrote:
I wrote Narsil/NarsilM, but doesn't mean I remember everything...
Thanks for the response.
One of the reasons I purchased this light was to experience Narsil and it is definitely a bonus having the historical figures involved contributing to this forum.
I have not changed the factory default thermal limits and the highest temperature my light has reported while repeatedly pushing it to Turbo is 54º C (which is not an accurate reading). I am using the included 10180 Li-ion battery which only lasts a few minutes with multiple low voltage blinking warnings before the final low voltage cutout where the light will not turn on. This highest temperature is 16º C (29º F) above the 38º C (which is also not an accurate reading) that the light reports when at a room temperature of 24º C (75º F); so the actual highest temperature of the light that I have been able to achieve is most likely 24º C + 16º C = 40º C (104º F).
I will monitor the temperature and thermal step down capabilities more carefully once I have a 10440 battery with 4 times the capacity of the 80mAh 10180 battery.
Tom E
Tom E's picture
Just keep in mind the performance of the cell. All 10440 cells are not alike. Some have lower resistance than others, but none of them can compare with the better 18650's or 21700's. Also the 10440's increase resistance with age/use, faster than the bigger cells.
Tom E
Tom E's picture
Got my Nano today:
  • switch LED is not working (should be RED from the pic), tried to enable it through the config UI but it didn't help. The LED is there and looks like the resistor is there, so not sure how they disabled it. I was expecting it to be factory configured with the LED off, but allowing you to turn it on. Probably a good idea to have it disabled because when NarsilM sleeps, it doesn't do LVP, unlike Anduril, and with such a small capacity cell, not a good idea to keep the LED ON.
  • appears to be pretty decent throw, considering the battery
  • I got a copper MCPCB, and appears to be DTP. I got pointy needle type of leads on my meter, and you can see bump outs of the center pad, so I pocked one of the leads through the top layer and got continuity with the MCPCB base.
  • charging works! Light went green, batt measured 4.16V
Of course I took the driver out, and as expected, it has a 20 pin ATTiny85, no pogo pin I/F, and also the CPU is on the top surface of the bottom PCB so blocked from any type of clip. Dismantling the 2 PCB's looks risky for me to do - easy to get apart but re-assembly would be tricky to align it, and level them perfectly.
Would like Anduril2 in it so could do voltage and temp calibration, and enable the switch LED, since Anduril2 monitors LVP even when asleep.
Gebe
Tom E wrote:
Got my Nano today:
As many have reported as I did in my post earlier. No biggie as who cares as it’s probably a battery drain anyway but it’s weird that Lumintop would tout it as a nice feature.
Muto
Red Led comes on when battery gets weak.
Gebe
Nice but if it doesn’t work at all?
jon_slider
Gebe
jon_slider wrote:
GT Nano Manual
![img]https://i.imgur.com/MqxFdXJl.png[/img]!
Thanks for that Jon and understood and whatever you do, the back button switch light on many of ours doesn’t work at all! If yours does, great. Mine doesn’t but IMHO, I don’t really care.
Muto
Disregard my low voltage comment, mine seems to be on even now with high voltage but it is so dang weak you can not see it in well lit room even up next to your eye but in dark room it is dimly lit.
Did seem brighter outside in dark when cell was weak so that is why I thought low voltage alert.
I am so used to doing mechanical lockout it will make no difference.
Cool little flashlight when used with 10440 tube.
jon_slider
I found the Lumintop site difficult to use, but not as bad as Aliexpress. Also if searching for Lumintop, clicking on the Lumintoponline instead of lumintoplighting site got me to a official looking site that wasn’t current and wouldn’t allow me to log in without reregistering.
I wrote to the three lumintop sites asking if they are official lumintop factory sites, all 3 replied.
two are, lumintoplighting is not
this came from ec@lumintoponline.com:
lumintoponline.com is a part of lumintop, and it is official site from us.
I am sorry we do not know the site https://lumintoplighting.com. And I have already reported this to the management.
this came from lumintoplighting@foxmail.com:
The website www.lumintop.com is Lumintop official website.
The website lumintoplighting.com is an online shopping websites
and this came from leo@lumitop.com
www.lumintop.com is official website
pc_light
pc_light's picture
Last seen: 14 hours 2 min ago
Pilotboy wrote:
Does anybody know if the Lumintop EDC 01 will work with the GT Nano?
The EDC01 that I had would screw on part way but does not reach.
Confirming what others have already discovered the UT K18 works well, offering the choice of pocket clip or keyring.
Seeking the light.
Notmyrealname
this came from ce@lumintoponline.com:
You are right Jon_slider. I placed an order with lumintoplighting and it turns out to be a fake Lumintop site with fake inventory. They showed the copper GT Nano as being in stock but after I ordered it showed as shipping in 10 days, so they were actually taking preorders or are drop shipping. I requested cancellation and a refund 3 times and finally got a response asking for my Paypal address for the refund which I sent and they said it would be 2 working days. I hadn’t receive it after a week so emailed them and they said that they “regret to inform me” they’d shipped it on the 10th (despite my 3 cancelation requests) as they didn’t get the Paypal address but would try to “withdraw” the shipment! on the 12th and have been silent since. I very much doubt that they actually shipped and I won’t know for months as I have no tracking number and the mail is very slow here. What BS!
So I’ll file a case with Paypal. I’m sure I’ll win as things are pretty clear and in 20 years of using Paypal I’ve only opened 1 claim (against Nealsgadgets) so I have some credibility but I understand it’s a hassle if they contest it.
It looks exactly like the official Lumintop site, uses their logos, photos and descriptions, shows the number of items in stock and and answers questions as if they are Lumintop. It seems like a lot of effort for what can’t be that much money. I’ll let the real Lumintop guys know about it.
Bizarre.
Pip
Last seen: 7 hours 21 min ago
My ultratac k18 doesn’t fit. Threads are different. Mine is also the newer model k18, slightly different than the one pictured above.
TIFisher
Last seen: 1 day 7 hours ago
You are right Jon_slider. I placed an order with lumintoplighting and it turns out to be a fake Lumintop site with fake inventory. They showed the copper GT Nano as being in stock but after I ordered it showed as shipping in 10 days, so they were actually taking preorders or are drop shipping. I requested cancellation and a refund 3 times and finally got a response asking for my Paypal address for the refund which I sent and they said it would be 2 working days. I hadn’t receive it after a week so emailed them and they said that they’d “regretfully” shipped it on the 10th as they didn’t get the Paypal address but would try to “withdraw” the shipment! on the 12th and have been silent since. I very much doubt that they actually shipped and I won’t know for months as I have no tracking number and the mail is very slow here. What BS!
Bizarre.
What’s more bizarre, I purchased two lights back in December and January (GT MICRO, GT MINI, both NM1) from Lumintoplighting without issue. Both were received timely, and I have no reason to believe they aren’t genuine. Not saying these guys aren’t shills, but if they are, they surely do a good job at it.
jon_slider
there are a lot of flashlight vendors that try to give the impression they are the manufacturer, when they are actually resellers
fenixlighting, fenix-store, nitecorestore, are all Not manufacturers, they are private businesses.
In any case, paypal dispute is the quickest way to Stop the frustration of unaswered and misleading emails back and forth. Vendors are motivated to protect their Paypal relationship, disputes go to a different email address (listed in Paypal).
Filing a dispute immediately escalates to resolution. I recommend not wasting time negotiating with the customer service staff on a vendor site.
good luck with your resolution, Notmyrealname.
fwiw, Lumintoplighting would probably still ship your item, once they get it in stock… Neal does the same thing, he takes orders before he has stock, then ignores email questions he cannot answer, such as, did it ship, when will it ship, and other consumer support questions. otoh, Neal immediately gives a refund, if a clear request is made. By clear request I mean, not an exchange, not a modification, not an addition, just Cancel and Refund.
