Energizer Ultimate Lithium AAA 2019 L92
Official specifications:
- Classification: “Cylindrical Lithium”
- Chemical System: Lithium/Iron Disulfide (Li/FeS2)
- Designation: ANSI 24-LF, IEC-FR03
- Nominal Voltage: 1.5 Volts
- Storage Temp: -40°C to 60°C (-40°F to 140°F)
- Operating Temp: -40°C to 60°C (-40°F to 140°F)
- Typical Weight: 7.6 grams (0.3 oz.)
- Typical Volume: 3.8 cubic centimeters (0.2 cubic inch)
- Max Discharge: 1.5 Amps Continuous (single battery only) 2.0 Amps Pulse (2 sec on / 8 sec off)
- Max Rev Current: 2 uA
- Typical Li Content: Less than 1 gram
- Typical IR: 140 to 180 milliohms (depending on method)
- Shelf Life: 15 years at 21°C
A retest of a very good lithium AAA battery, has it change performance during the years (I tested it in 2013)?
The discharge curves looks normal for Lithium batteries, i.e. constant capacity also at high load. This battery holds capacity up to 1A current.
Conclusion
it is still a very good lithium battery, in fact it is slightly better at high loads, but capacity is the same.
Notes and links
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
- LEDs & Other Stuff - - UI CheatSheets - - CRX Flashlight Builds - - CRX Stuff for Sale -
Thanks for that. I always appreciate your tests and accumulated data!
Thank you for the review, thorough as ever.
I noticed that Energizer now claims a shelf-life of 20yr. (on the battery itself: 12-2039).
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
