Just got a 2006 Ford Escape for $200, Trying to make it a daily driver for cheap
213 posts / 0 new
Lightbringer
Lightbringer's picture
Last seen: 5 hours 22 min ago
Yeh, before the cat bounces up’n‘down fairly quickly as the fuel-trim is adjusted, but after the cat has all kinds of lag which “smooths” the output. RC network would work well. LOL
JaredM
JaredM's picture
Last seen: 28 min 17 sec ago
Well that’s a significant difference in readings, but a plugged exhaust that’s getting worse would also reduce your readings. Did you recheck the old MAF readings the same day as the new one?
Two diagnostics is recommend are 1: a vacuum gauge test and 2: watching the run engine in the dark.
The vacuum test should help point out the potential exhaust back pressure issue. If you could rent a back pressure gauge and tap into the o2 sensor that would be ideal..
The reason for viewing the engine in the dark is for watching for ignition system shorts. I’ve caught bad plug wires arcing this way before. Free and easy…
Don’t let this thing best you! Lol
https://fundrazr.com/osturaband
No affiliation, just a fan.
Muto
Last seen: 14 hours 49 min ago
About the engine in the dark, yeah check both when cold and when good and hot.
Had a 1970 Ford panel van with 6cyl. and it got down on power where you had to slam it into 2nd gear (3 on the Tree) to make medium steep grade hills.
Pulled the dog house one night and all the wires were glowing and arcing.
Next day replaced wires and ran like new engine, had to lower idle down even. Taught me to test for that on all cars since. Also have had a bad ignition wire when new, it does happen, so when people say well the wires are new OK but are they performing correctly.
Don’t think that is the problem here as his truck seems to go bad like someone is throwing a switch.
Where I live there are cheap Pull Your Own junkyards and I would be tempted to just go get the main computer if it is cheap enough and see what gives.
Had one take a crap on a Jeep, had lots of random electrical gremlins, replaced it and wala:)
Later
The difference between Hoarding and Collecting is the illusion of Organization
.“I will get one of flashlight from patrol car”
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
Texas_Ace
Texas_Ace's picture
Last seen: 1 day 16 hours ago
Sadly with a coil on plug setup you would not be able to see any of the high voltage ignition areas so that test would not help much I am afraid.
Indeed, it will run normally sometimes and then run bad again a second later like throwing a switch, which is why I am basically positive it is an electronics issue but nothing shows up on the OBD scanner.
The ECU is something I have considered a few times but the cheapest I have found one is $50+, that is a lot to waste on a longshot like that, particularly on a car only worth maybe $500 in it’s current condition.
Vacuum seems normal according to the OBD, it reads in absolute but gets down around ~3-4psi at idle which sounds about right.
JaredM
JaredM's picture
I would recommend checking the vacuum with a manual/analog gauge, as the refresh rate often hides the more subtle behaviors.
I was going to suggest the same thing as Muto with going to a U-Pull-It for some random sensors etc..
Crank and cam pos sensors primarily.
BTW, does your OBD readout have a knock count? This is an issue that should surely trigger a DTC, but I am curious if it somehow its detecting knock and pulling timing/richening A:F
Texas_Ace
Texas_Ace's picture
It did have a knock readout of some kind but it never triggered even when I could hear it pinging. I tested the knock sensor when the intake was off and it seems to be good, so this is another reason I suspect something deeper then a basic sensor error. That or the knock detection sucks on these ECU’s.
In my 4runner the knock detection is really good, you can get away with an amazing amount of abuse because of it lol.
I might toss a mechanical vacuum gauge on it and see what it reads, although so far everything has checked out as matching the OBD readout so loosing hope.
Going to try putting in my old spark plugs / coils today (have not been able to bum a ride to the parts store) to see if it shows any improvements, the plugs worked fine when I replaced them.
After this, sadly going to have to put it out to pasture for the time being so I can work on the 4runner, I am out of ideas for the Ford outside of the ECU itself.
Texas_Ace
Texas_Ace's picture
Well, just swapped to the old coils and plugs, no change. I would of expected some kind of change if they were the issue.
The really strange part is that once again, it runs perfectly for the first few seconds after a cold start when still in open loop. Then it goes into closed loop and the issues start.
Pretty much rules out any mechanical, fuel, clogged exhaust or timing issue as those would effect open loop as well.
Just replaced the MAF. I could not find my vacuum gauge but the readings seem on point for the MAP sensor or at least close enough to not cause this big of an issue.
Anyone else have any bright ideas?
Only thing I can figure at this point would be the ECU itself but that is a lot to spend on a long shot. I have replaced the ECU in a few cars in the past with strange issues and it never worked before.
JaredM
JaredM's picture
First few seconds you say.. how many is that exactly? 5, 10, 30?
Texas_Ace
Texas_Ace's picture
Hard to say exactly as I have not timed it, ~15 seconds or so I would guess today from a cold start. When it is already hot it is shorter.
I was watching the OBD at one point when it left open loop and the instant it did is when the issues started.
I have noticed this since I got it, just not as pronounced. When I would first start it up in the morning it would be really peppy and drive great until I was at the end of the block, by the time I took off from there it would be back to it’s old down on power ways.
JaredM
JaredM's picture
Okay. Well let’s try and force it to stay in open loop for an experiment. Try disconnecting coolant temp sensor and see if that keeps it OL. If not, then disconnecting the upstream O2 sensor should. These will obviously cause a CEL but this can really point us in the right direction
EDIT: if it only took about 15 seconds from cold, then it’s likely the heated o2 sensor determining the switchover point. Coolant temp may not help
Texas_Ace
Texas_Ace's picture
Interesting idea, I was wondering how I would go about forcing it into open loop but I worked with standalones or tuneable ECU’s for so long I never really learned what would cause a stock ECU to do that.
I will try the temp sensor first, assuming I can get at it. I remember disconnecting a plug next to the tstat when doing the intake manifold and not sure I can get to that plug with the manifold in place.
JaredM
JaredM's picture
Oh. I forgot to ask what the load % reads now with the new MAF?
Texas_Ace
Texas_Ace's picture
It was hard to get exact before/after numbers but it seemed to read a bit lower on average. It would still go to 100% with some throttle but seemed like it took a little more then before.
JaredM
JaredM's picture
Hmm. So a minute of googling tells me there may be a fuse for the o2 heater circuit. That was on the v6, but the i4 may have that as well. That can be another way to disable/delay closed loop.
Texas_Ace
Texas_Ace's picture
Cool, that sounds like the simplest option, I will see if I can find which one that is
JaredM
JaredM's picture
Texas_Ace
Texas_Ace's picture
JaredM wrote:
https://ricksfreeautorepairadvice.com/2006-ford-escape-fuse-diagrams/
Fuse #5. 15amp
Off to give that a try……
Texas_Ace
Texas_Ace's picture
Well, sadly pulling that fuse did not keep it from going into closed loop.
I was looking for the temp sensor but could not seem to find it, did some searching and seems it uses a head temp sensor?
https://www.2carpros.com/questions/coolant-temp-sensor-36995243
I have seen that plug by the coils but was not sure what it was for.
JaredM
JaredM's picture
Shoot. Did you at least get DTCs ? P0141
Texas_Ace
Texas_Ace's picture
Ok, disconnected the temp sensor in the head and tried again, still went into closed loop.
Although while driving I did notice something odd, when it gets up to the 4k RPM wall it would go into “open loop/deceleration”.
This is the same thing it says when I rev in neutral and the rev limiter kicks in at 4k.
Could it think it is in neutral?
Texas_Ace
Texas_Ace's picture
Nope, no codes which I found strange as well, although maybe I didn’t leave it running long enough, I can check for pending codes next time I am out there.
Gonna let it cool off and try disconnecting the O2 sensor tomorrow most likely.
JaredM
JaredM's picture
Oh that’s interesting.. both getting no code and the idea about neutral/park.
As for the O2, I think I see the connector on the firewall behind cylinder 4 in an image search. Should be another easy one to test. If it goes into closed loop without an AFR sensor, the ecm actually becomes an suspect in my book. As of now, I’m looking elsewhere.
JaredM
JaredM's picture
A test maybe for the gear selector might be to try and start it while it’s in drive. If it allows it to fire up, you’re onto something for sure
Texas_Ace
Texas_Ace's picture
Another good idea, I will try that now.
Although this might be a more “hard wired” safety vs a ECU decision.
Lightbringer
Hang on, let’s take a step back…
Open loop does 2 things: generally runs rich to warm up things in a hurry from a cold start, and (duh) uses open-loop preprogrammed values for everything. Once you go closed-loop, it leans out and uses soft trim-values instead.
So if open-loop is good, more fuel means better acceleration, etc., and those values are programmed at the factory, normal expected values but not trimmed for the specific engine.
Remember the old (rather stoopit) trick of putting a wedge under the accelerator for “better fuel economy”, simply to keep people from stomping hard on the accelerator pedal? Sounds almost like that’s what’s happening closed-loop, ie, something’s tricking the ECM to limit fuel-flow somehow? (Eg, load sensor, etc.?)
I forgot if your engine runs rough or does anything untoward, other than just having a lack of power.
I heard of cases where the VSS or cam/crank sensor, etc., “jumped a cog” and threw off valve timing. Ie, the sensor might read a good timing value, but it’s just off enough to let the engine run, but be horribly weak.
Case in point, miscalibrated temp sensor on Andouille-based lights. My new SC31pro was reading and blinking out 44C-45C, but it was really 23C (then slowly sneaking up to 25C from just sitting in my hand when I was playing with it). So it was thinking the light was already running pretty warm even though it was sitting in rather cool air undisturbed. But!, it was doing exactly what its sw was telling it to do.
JaredM
JaredM's picture
So there are a bunch of hits for this model and bad transmission range sensor. This tells the pcm what gear it’s in. Might be something to look into if other things don’t pan out.
In case it comes to that.. https://www.amazon.com/dp/B000C7ZR90/ref=cm_sw_r_cp_apa_i_MELCFbXRV5DWX
Texas_Ace
Texas_Ace's picture
Ok, tried starting it in drive, no go.
Disconnected the O2 sensor and it was hunting all over the place with the fuel trim and timing for the first few laps of the block but eventually went into “open loop/sys error” mode.
There are also pending codes for the O2, MAF and temp sensor, so guess it was just not long enough for them to become real codes.
While it was hunting there were times it felt better but no pattern I could detect and it never seemed to be up to normal power levels. Once it went into open loop entirely, it oddly seemed very similar to the normal issues I have been having.
At low throttle inputs it would try to die now and at WOT it would also act funny but at normal throttle levels it was not that much different then before. So guess that rules out the open loop being the answer.
It must be the start up tune, if I start it, slam it into gear and floor it, it will take off like it used to for the first few seconds. Then it will fall on it’s face.
As far as any other issues, this is what makes it so strange, it starts, idles and runs perfectly other then having zero power at all. Thats the hardest part, no hints as to where the issue lies.
A timing issue is something I considered early on as well but this is a timing chain engine, is it even possible for it to jump a tooth? There is no rattle from the chain when running, so it would seem to still be tight.
Texas_Ace
Texas_Ace's picture
Interesting, at least it is cheap, I need to look through the OBD output again and see if it outputs anything about the gear.
Texas_Ace
Texas_Ace's picture
Thanks for all the help and suggestions by the way, I am about to drop kick this thing to craigslist lol.
I know it must be something simple, but no clue what it is. This is easily the strangest issue I have ever had on a car. I have had things I didn’t want to fix or were not worth fixing before but this is the first time I could not even get in the ballpark of what the issue is.
JaredM
JaredM's picture
A plugged exhaust takes a few seconds to build up pressure and then cause issues. I would say this would be under 15s for sure and likely around 5-10s. I don’t know if I can rule that out from the descriptions so far..
The fact it runs good for a short time leans me towards exhaust or electronic.
To be clear, if your startup cold, immediately slam into low gear and go WOT, will it exceed 4k rpm?
