This is my first time posting in this Forum, so hopefully I placed this in the correct area.
Based on the price these seem fake to me, but “Holiday sale” has been on AliExpress since 2013 and has a 92.6% rating.
What do you all think?
US $2.79 23%OFF | for Samsung Original 18650 25R INR1865025R 20A Discharge Lithium Batteries 2500mAh Electronic Cigarette Power Battery
https://s.click.aliexpress.com/e/XM2vtpe
jch10400
(jch10400)
August 16, 2019, 6:51pm
2
Not worth taking a chance, especially with only a 92 % rating.
So, while I was looking at a nice low cost source for 18650s, I came again at the sight of the Littokala store. What I found was digusting!
Then I noticed. The price of all 18650s have been cut by half, but many reviews are saying that their cells have leaked, have very low capacity, and have too low discharge rates. I would not buy any batteries from any of the Liitokala stores
6PCS of Samsung 30Qs:
LG HG2s:
Samsung 25Rs:
I have not looked at more cells, but even if they were free, thes…
‘If there is any doubt, there is no doubt.’ Ronin.
Chris
Not worth the trouble. My battery database shows $3.78 for a single 25R or as low as $2.90 in bulk.
Thanks everyone!
I figured it was too good to be true.
Barkuti
(Barkuti)
August 16, 2019, 7:37pm
7
I can't open that link unless I disable AdAway, this means it is blacklisted by the “ad police”.
That is an affiliate link, doesn't it?
If you really need help, please provide a real link.
Anyway, before I see anything my forecast is ultra high fake chance.
EDCPlus
(EDCPlus)
August 16, 2019, 9:58pm
9
When they use words like “for Samsung” this indicates deception, and is indicating that they are admitting it is fake. Also it says 100% Authentic Batteries. I’m sure they are real batteries, but are they real Samsungs? This is more than likely tricky marketing deception.
Lotta 2600mAH crapcells will clock in at at least 2500, but internal resistance might be obscenely high.
gman7228
(gman7228)
August 17, 2019, 12:02am
12
Description doesn’t jive either.
4PCS/lot for Samsung Original 18650 25R INR1865025R 20A Discharge Lithium Batteries 2500mAh Electronic Cigarette Power Battery
Product details:
Battery Brand: Liitokala
Battery name: Liitokala 18650 cylindrical lithium ion atteries
Battery Type: INR18650-25R_
gman7228:
Product details:
More great points!
I feel kinda silly now for asking.
I definitely won’t be ordering those!
Thanks again everyone!
amishbill
(amishbill)
August 17, 2019, 2:19am
15
Not knowing leads to questions
Questions lead to knowledge
Knowledge leads to better questions
Embrace the silly.
It leads to growth if handled properly.
amishbill
(amishbill)
September 3, 2019, 2:46pm
16
Is $2.99 +s/h good enough for you?
AND - from a reputable US company not too far from you?
Thanks, that is a great deal!
I purchased a 25R from a local Vape Shop and unfortunately it didn’t resolve my issue.
I now believe it’s a contact issue between the Driver and the pill.
I’m having a hard time getting solder to bond with the aluminum pill.
SIGShooter
(SIGShooter)
September 3, 2019, 10:22pm
18
You don’t have to solder the driver to the pill to get an electrical contact. I have a number of S2’s where I soldered thin strands of wire to the driver side, snipped and bent the wires over the side of the driver, and then pushed that side of the driver first into the pill before pushing down on the other side of the driver. A bit of solder on the bent portion of the wire makes it more form-fitting and a solid press fit into the pill.
Before I did that I also soldered the driver to the pill and it was hard to do, ugly, and difficult to remove the solder from the threads at a later date.
Thank you!
I will try that this weekend!
Note: I just realized I thought I was replying to my other thread!
I recently purchased a 105E 20mm 7135*8 3.04A LED DRIVER from mountain:
http://www.mtnelectronics.com/index.php?route=product/product&path=67&product_id=777
The driver works great but I noticed it goes into emergency low mode(flashlight dims and flashes very slowly) pretty quickly so, I checked my battery voltage and it was 3.68v and working fine in another light.
I put a fresh battery in and it did the same thing, and when I checked the voltage it was 3.69v.
Both batteries were 4.1v when I …
hodor
(hodor)
September 3, 2019, 10:38pm
20
EDCPlus:
Does this mean the batteries Simon sells on his AliExpress Convoy store are fake?
