Test/review of Flowme QC3 USB charger JYX-218-QC
1 post / 0 new
HKJ
HKJ's picture
Last seen: 1 day 21 hours ago
DSC_7415
Official specifications:
  • Brand Name: FLOVEME
  • Output Interface: 5V/3A
  • Quality Certification: RoHS,ce,FCC,CCC,UL
  • Output Interface: USB
  • Power Source: A.C. Source
  • USB Ports: 1
  • Model Number: Quick Charge 3.0 & QC 2.0 Phone Charger EU Plug
  • Color : Black & White
  • Version: EU Plug
I got it from aliexpress dealer: FLOVEME Fashion Accessories
DSC_7389 DSC_7390
It arrived in a plastic bag inside a plastic envelope without any accessories.
DSC_7416 DSC_7417
DSC_7418 DSC_7420
DSC_7419 DSC_7421
Measurements
  • Power consumption when idle is 0.14 Watt
  • USB output is coded as Apple 2.4A, DCP, QC3, Huawei-FCP, (Samsung-AFC)
  • Minimum QC3 voltage is 4.25V
  • Weight: 58.8g
  • Size: 88.8 × 45.0 × 27.3mm
Flowme%20QC3%20230V%20load%20sweep
The overload protection is very high at 5V output. The voltage looks nice (Slightly above 5V).
Flowme%20QC3%20QC9V%20230V%20load%20sweep
At 9V the current limit is 3.5A, this is way above the rated 2A.
Flowme%20QC3%20QC12V%20230V%20load%20sweep
At 12V it is about 2.8A, again well above the rated 1.5A
Flowme%20QC3%20QC12V%20120V%20load%20sweep
With 120VAC supply the current limit goes down to about 2.5A for 12V
Flowme%20QC3%20QC9V%20230V%20load%20test
For a load test I used 9V 2A load for one hour, it worked fine.
The temperature photos below are taken between 30 minutes and 60 minutes into the one hour test.
Temp6877
M1: 42.6°C, HS1: 67.2°C
HS1 is the transformer.
Temp6878
M1: 40.2°C, HS1: 56.5°C
Temp6879
M1: 74.6°C, HS1: 79.0°C
HS1 is the transformer and near M1 is from the the rectifier diode.
Temp6880
M1: 68.7°C, HS1: 71.6°C
Again the transformer and the rectifier diode.
Temp6881
M1: 37.2°C, M2: 54.7°C, HS1: 67.3°C
10ohm
At 0.5A the noise is 17mV rms and 124mVpp.
5ohm
At 1A the noise is 28mV rms and 191mVpp.
2ohm
At 2.5A the noise is 42mV rms and 253mVpp.
10ohmQC9V
At 9V 0.9A the noise is 30mV rms and 216mVpp.
10ohmQC12V
At 12V 1.2A the noise is 58mV rms and 454mVpp.
Tear down
DSC_7981
Mounting the bottom in my vice and whacking the top with a mallet was enough to open it.
DSC_7982
At the mains input is a fuse (F1) covered in heat shrink, between the mains capacitors (C1, C2 & C3) is a inductor (L1). The switcher IC (SW1) is covered in a small heatsink. There is a safety capacitor (CY1) and a opto coupler (U2) to the low volt side.
DSC_7984
DSC_7985 DSC_7987
DSC_7986
DSC_7983
On this side it the bridge rectifier (BD1) at the mains input, on the low volt side is a rectifier diode (U3), the QC controller (U4: FT4) and the reference (U5: 431).
DSC_7988
DSC_7989
DSC_7991
The distance between high volt side and low volt side must be above 6mm, it is more like 5mm here.
Testing with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems.
Conclusion
This USB charger works fairly well with support for a couple of fast charge protocols, safety is not perfect and it can deliver too much current.
Notes
Index of all tested USB power supplies/chargers
Read more about how I test USB power supplies/charger
How does a usb charger work?
