[♛ FreemeGB] Convoy S12 3*SST20/ 3*219C 4000K-6500K 6A 21700 LED Flashlight - ALIVE
150 posts / 0 new
id30209
id30209's picture
Last seen: 11 hours 45 min ago
And my order is still Processing.
Nice, real nice. Don’t kniw what to think, maybe to go to other dealers. Second GB already where eveybody is getting their lights but me.
WTB Titanium 4sevens 2xAA tube
korpzgrinda
korpzgrinda's picture
Last seen: 12 hours 27 min ago
Location: Eastern Woodlands in the Wilderness of North America
I don’t see anywhere in this thread where anyone is “getting their lights”.
id30209
id30209's picture
Me neither but i see folks saying “shipped” while mine went from processing, backorder, processing and now out of stock.
WTH?
lightdecay
Last seen: 11 months 1 week ago
I was one of the first to order and my order is processing. Only my charger shipped.
This is what my order says, and it has not changed since I ordered on August 29:
Expected Shipping Date: 2019-09-10 11:00:00
aors10
Last seen: 8 hours 2 min ago
Interested
id30209
id30209's picture
And my order 72320576 has changed from backorder to request reffund.
I freakin give up. Not worth the money...
JamesB
Last seen: 3 weeks 3 days ago
Intradested , Smile
mortuus
mortuus's picture
Last seen: 5 hours 54 min ago
I freakin give up. Not worth the money…
this isnt new, its just backordered or something, it says on bg now that its getting stock later this month..
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
Gerrh
Last seen: 2 months 1 day ago
I want one please.
d_t_a
Last seen: 20 hours 17 min ago
Any idea for approximate lumens values for each LED/tint type of the Convoy S12? It says “6 Amps” max current.
freeme
freeme's picture
Last seen: 16 hours 8 min ago
I will take some measurements once i received my light in a few days time.
d_t_a wrote:
Any idea for approximate lumens values for each LED/tint type of the Convoy S12? It says "6 Amps" max current.
1thedeals.comyoutubeAstroluxNealsgadgetsolight
locusto03
Last seen: 20 min 30 sec ago
I’d like a code, please!
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 2 days 5 hours ago
~1600lm for SST-20 4000K
~2300lm for SST-20 5000/6500K
~1800lm for 219C 4000K (and probably 5700K too unless they’re a different flux bin)
All very rough numbers based on the tests of those LEDs here on BLF, and assuming the driver is supplying 6A.
darklight
Last seen: 2 years 1 month ago
i’m completely new to the modern flashlight world but am i’m right with the following:
regarding the full output of 1600lm (sst20 4k), which will produce so much heat that it’ll step down after a couple of minutes, i’ll only get a nonstop output of around 500lm (30% in mode 3)?
thx alot
BurningPlayd0h
thx alot
On a light this size, probably around there after thermal throttling kicks in. Depends on if the temp limit is set to 50C like the other recent Convoy lights or higher as well though.
Should be closer to 600lm+ from cold start since that’s 30% of power, not output and lower modes are more efficient.
freeme
freeme's picture
Convoy S12
3*SST20 6500K undefined lumens
Retail Version
Peak Value
2030 lumens with Sony VTC5A (4.18V @5.7A)
Verified by FreemeLAB
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 6 hours 29 min ago
That’s really good numbers compared to a over driven LED. A XPL2 would need to be at like 10amps to achieve the same output. You might be seeing around 2400 lumens without light losses?
withoutink
interested
Cheers-
Withoutink
My Flashlights
Instagram | YouTube
freeme
freeme's picture
Short clip. cool
tjhabak
Last seen: 1 year 11 months ago
I received my light but the switch is not working. I can activate the light and switch modes by shorting the body to the negative terminal of the battery but when put together, it is DOA. Has anyone else experienced this or have any ideas on a fix? I did try installing a McClicky in the tail cap and it half-way worked but not reliably. There must be a contact issue somewhere but I cleaned all the surfaces and made sure everything was assembled tightly with no luck. I just want to say that for the money, if I can get this thing working, this will be a killer light! Fit and finish are very good and the output is very impressive! I hope nobody else has any problems with theirs!
freeme
freeme's picture
Are you able to perform a continuity test with a DMM for the tailcap alone?
VK-GX
Last seen: 6 months 5 days ago
Interested.
Aspxhp702
Very interested. I’d like the coupon thanks
In love to xhp70.2
freeme
freeme's picture
Sent. Please take note that coupon will expire by end of the month.
Aspxhp702 wrote:
Very interested. I'd like the coupon thanks
olles
Last seen: 5 days 16 hours ago
interested in 2, thanks,
olles
freeme
freeme's picture
You got mail.
olles wrote:
interested in 2, thanks, olles
Grigio
Grigio's picture
Last seen: 1 day 12 hours ago
I’m in for 1, thank you!
freeme
freeme's picture
Let me see... Sent.
Grigio wrote:
I'm in for 1, thank you!
Grigio
Grigio's picture
Thanks, freeme!
