WTS/GB: [4000k ARRIVED, Test Report's In] GT-FC40 (a.k.a. XHP70's flattop, 12v 40w sister) 95 CRI, Available in 4000k, 5000k
168 posts / 0 new
Jerommel
Jerommel's picture
Last seen: 2 years 6 months ago
I may order one along with more 5mm LEDs.
Early next year, some time.
SKV89
Last seen: 4 days 5 hours ago
Received my 3 today. They were well packaged in a sealed static bag like factory seal. Do you actually have a packager or did you order them prepackaged?
I’m waiting for my FT02 v2 and maybe thinking of swapping it in the Noctigon K1 XHP35 HI version. Should make for a very nice ultra HI CRI thrower.
Thanks for all your effort to bring us this emitter! Now just patiently waiting for Djozz’s test. Big Smile
id30209
id30209's picture
Last seen: 8 hours 33 min ago
SKV89 wrote:
.  I'm waiting for my FT02 v2...
That's why i order FT02v2 also LOL
WTB Titanium 4sevens 2xAA tube
rngwn
rngwn's picture
Last seen: 1 week 2 days ago
I repackaged those myself. They are sold in a bulk tray.
djozz
djozz's picture
Last seen: 2 hours 47 min ago
What am I supposed to test?
SKV89
I see you have a 4000K on order so thought you were planning to test one.
djozz
djozz's picture
Of course I will do some spectrum testing, but if you refer to output/voltage, I was not planning on that because I expect it not much different from the 5000K one.
I’m waiting on a XHP35 driver, I was thinking of first do the mod and then check the tint.
Scientist
Scientist's picture
Last seen: 2 weeks 3 days ago
I had been wanting to upgrade my Jaxman Z1 for a while and this emitter seemed like a good opportunity to do it. I had a Kiriba-ru Cu pill and when the H2-C driver arrived the other day I jumped on it
Now I don’t have to go through the H-M-L-strobe-SOS modes it came with. And as a bonus when zoomed in I don’t have just four panels but 16!. One thing that is visible when zoomed in is that the individual panels are not uniformly colored. It’s a little hard to tell in this image because I can’t bring the emitter surface into complete focus, but some of them are yellower than others (upper left) and there is a dark spot lower right of center.
It doesn’t really affect the beam when zoomed out (flood mode) and I will typically use more flood mode than zoom mode. I just wanted to show you guys an example of what you may get. So now I have improved modes and high CRI in my Z1! Thanks rngwn.
An additional note, I’m not sure what driver they sent me. It has four modes that correspond to very low, low, medium and high, but double clicking goes to turbo and triple clicking goes to strobe, modes not listed for the H2-C description at the place I ordered it. It’s drawing over 4A on turbo but I only have a Fluke meter to do tail measurements so I’m probably measuring too low.
Please illuminate responsibly
Part time fragmented conciousness technician
UV triple using Sofirn C8F
395nm High Power LED in Sofirn SC31b
SKV89
I’m surprised at the huge difference in tint within the same emitter. I was thinking of modding a Cometa with copper pill but you just saved me the trouble. Thanks for letting us know.
rngwn
rngwn's picture
Finally put one in a suitable host. The manta ray C8.2 w/ 10mm hole.
https://www.reddit.com/r/flashlight/comments/ejt0qh/nld_manta_ray_c82_w_...
SKV89
Wow you found a perfect fit spacer too. Where did you get the spacer?
KevinZA1988
KevinZA1988's picture
Last seen: 6 days 15 hours ago
It comes with the host
Acebeam L18, Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Emisar D4, Emisar D4V2, Emisar D4K, Emisar D4SV2, Fireflies E07, Jaxman E2L, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Olight Baton 3, Olight Warrior Mini 2, Olight M2R Pro Warrior.
Most of them have been modded! =)
https://photos.app.goo.gl/JaJaDv4V838AEJf39
SKV89
It is sized for XHP70.2?
KevinZA1988
Long version Manta Ray C8.2 black flashlight host https://a.aliexpress.com/KwYly5nRV
Yes, check in the item description. Make sure you take the 10mm reflector option.
rngwn
rngwn's picture
I bought the short version though. They also come with XHP70.2 gasket.
Edit: you want to wick off the excess solder blob on the sides of the emitter, or else the gasket won’t fit.
id30209
id30209's picture
What the heck, i'll take another one.
Skylight
Skylight's picture
Last seen: 1 day 14 hours ago
I have found two more hosts that are suitable for this 12V led. It works nicely inside the Sofirn C8G and the Haikelite SC26.
As the Sofirn C8G and the Haikelite SC26 both use a XHP35 they both have a 12V boost driver.
The SC26 originally uses a 16mm PCB but if you cut a bit of copper away where the switch board is to make sure they don’t contact a 20mm works fine.
The C8G does not use the standard 20mm PCB size so the GT-FC40 20mm MCPCB has to be trimmed to 17-18mm until it fits the PCB cavity.
What you need to do is swap the reflectors for others with a bigger 10mm opening for the 7070 led format. I have used OP reflectors to smooth the beam a bit which can be ringy because of the individual dies on the led.
In the C8G I have used this kind of reflector: C8 reflector 10mm led opening
This reflector fits perfectly in the Haikelite SC26 with 7070 led: kaidomain.com/Flashlight-DIY-and-Tools/Reflectors/29_6mm-x-24mm-Aluminum-Reflector-for-CREE-XHP70
I really like the tint and color rendering of these two flashlights now. It is much better than with the XHP35. Of course they won’t throw as far anymore but still decent enough and with 95CRI. Cool
SKV89
Good Job! Looks very nice! Thanks for sharing.
Agro
Agro's picture
Last seen: 1 month 1 week ago
I notice that Getian has also a 50W LED.
Does it have XHP70 footprint as well? Is it also high CRI? Any chance for a GB? Wink
rngwn
rngwn's picture
Agro wrote:
I notice that Getian has also a 50W LED. Does it have XHP70 footprint as well? Is it also high CRI? Any chance for a GB? Wink
I think they are one and the same as this 40W emitter, and I remembered they even listed 60w with the same number of die and footprint (also with less lm/w, which confirms my suspicion).
As Djozz have tested, these “40w” parts could easily be run at 60w (as long as you can cool it), and might even survive a brief period (minutes) of 100w without degradation.
Agro
Agro's picture
I see…but why have different model numbers? Pure marketing “We have a model tailored to your needs”?
That’s very possible but maybe it would be good to ask for clarification?
contactcr
Last seen: 10 hours 36 min ago
If anyone wants to sell me one of their unused ones PM me.
contactcr
D80v2 with GT-FC40 4000K and 20mm MTN-BST3 driver, reamed reflector (probably more than necessary)
Mid (stock lens)
High (stock lens)
Mid (with diffused lens)
High (with diffused lens)
id30209
id30209's picture
Need another one of these.
Shipping combined wither COB order
will34
will34's picture
Last seen: 6 hours 30 min ago
Has anyone tried this emitter with convoy 22mm 1 Cell 2.3A boost driver?
Or which driver for best performance?
Thinking of building either a M21C or manta ray C8.2
rngwn
rngwn's picture
I did tried that exact same convoy driver at some point on C8.2, though the stock host doesn’t give good enough contact and I can’t go into turbo as a result.
I did later try to bypass the terminals with solder braid. With Liitokala 5000mAH, it worked when fully charged, but will drop out of turbo on 50-75% SoC. After a while, I recklessly try to go into turbo repeatedly and probably eventually killed the driver with the transient after 100th attempt or so. To sum it up, if I want to use that driver again, I will probably need a higher drain battery or better bypass mod. Handling 10+ amps from a single cell is no joke here.
Alternatively, there’s a GB attempt by nzoomed. It’s a driver that could potentially drive the emitter at 50W out of single cell.
http://budgetlightforum.com/node/71017?page=4
id30209
id30209's picture
Got another GT and straight mod exactly.
Convoy M21C with Convoy XHP35 driver and FC40 paired with Convoy OP reflector.
Bloody awesome!!
ch1ir
Last seen: 5 min 46 sec ago
Are these still available?
id30209
id30209's picture
L - FC40
R - Stock XHP70.2 5000K
rngwn
rngwn's picture
Still have a fair bit left, interested?
