This Shockli 18650 3500 mAh battery is specified as 25A continuous and 30A pulse current. Is this possible with such a battery? It would then be the new best all around cell good above both Samsung 30Q and 35E. How could Shockli official battery store put fake info on the wrapping when they are now starting to get good reputation?
False.
10A continuous is the max.
I planned to buy lots of batteries from Shockli Battery Store. Now I’m in doubt if I can trust the wrapping specs. Is this really Shockli official store, or should I buy Shockli batteries another place?
Shockli 26650 5500mAh 20A/30A BT
Shockli 21700 4550mAh 22A/30A FT
Shockli 21700 3800mAh 30A/40A FT
Shockli 26650 5500mAh 20A/30A FT
Shockli 21700 4000mAh 20A/30A FT 14.8W -> In the heading it is 40A
Shockli 16340 700mAh 2A/3A BT RCR123
Shockli 14500 1000mAh 2A/3A BT
Dare I say the cells are probably genuine rewraps but the specs may be exaggerated somewhat.
If it helps, I’ve bought a few of their black and white 26650 and they’ve been good. Will also be buying some of their 14500 cells.
The shockli rep here has links to that store so that should be the official site. Now how to know if the rep is an official Shockli employee?
18650, 3500mAh, 25A continuous
Of these 3 numbers only 2 can be true. Currently.
Hi RapidLux
Thank you for your feedback
i am sorry for the information on the wrapper confuses you
I have confirmed with the engineer and now I will officially reply to you
Shockli 26650 5500mAh 20A/30A BT(discharge current is right)
Shockli 21700 4550mAh 22A/30A FT(discharge current is right)
Shockli 21700 3800mAh 30A/40A FT (discharge current is right)
Shockli 26650 5500mAh 20A/30A FT(discharge current is right)
Shockli 21700 4000mAh 20A/30A FT (discharge current is right)
Shockli 16340 700mAh 2A/3A BT RCR123(discharge current is right)
Shockli 14500 1000mAh 2A/3A BT(Continuous/max is 3A/5A)
Shockli 18650 3500mAh 2A/3A BT(Continuous/max is 15A/20A, the wrapper information 25A/30A is exaggerate)
Shockli Authorized dealer in china (Does not include US, European, Asian agents)
1. Aliexpress store Aliexpress Link
2. Gearbest store Gearbest Link
3. Banggood store Banggood Link
