[1900k edition is in!] WTS: 1900k-5800k 5mm LED 95+ CRI
531 posts / 0 new
id30209
id30209's picture
Last seen: 1 hour 28 min ago
Unheard wrote:
1stein wrote:
BTW: anything else worth your recommendation as host for 5mms?
You already know about the Fenix E01?
I’ll place it in Surefire A2
WTB Titanium 4sevens 2xAA tube
Boaz
Boaz's picture
Last seen: 12 min 48 sec ago
I'll take a pack
                 υμεις εστε το φως του κοσμου ου δυναται πολις κρυβηναι επανω ορους κειμενη
1stein
1stein's picture
What about multiple leds? Any decent host known? Headlight is a good idea too.
rngwn
rngwn's picture
Round 1 packages are shipped (along with some other packages for different customers)
rngwn
rngwn's picture
All of the packs have been reserved, so I will announce that this is now out of stock.
Anyone who placed the order should pay before Saturday, or I will cancel the order and release the reservation.
1stein
1stein's picture
Aw, you shouldn’t have posted the bill, we trust you to the very end. Needless to say a reward for you should be granted admittedly. I’m really really thankful you make rare (hard to obtain where I live) leds available for us.
Beer Beer Beer
Unheard
Unheard's picture
Last seen: 1 hour 16 min ago
There are some Varta hosts for multiple LEDs (up to 7). From the technical data I assume current is well within the specs, i.e. <=25mA. Those Vartas are not bad qualitywise, but I have not tried to open them. Yet.
Edit: Thanks a lot for shipping! Beer
Smile, you cannot kill them all.
mitsuki08
Last seen: 5 hours 25 min ago
@rngwn Any other color temps planned in the future or only 3400k?
rngwn
rngwn's picture
^ I initially planned for 4000k, but they don’t have it. I will have to make a jump to 5600k for anything cooler than that.
They may have 3500k, though.
rngwn
rngwn's picture
Another 1700pcs is coming this weekend, same CCT, same bin.
iamlucky13
Last seen: 5 hours 13 min ago
The test images look good!
rngwn wrote:
It’s the usb CC/CV buck-boost converter.
Sounds potentially handy. Is this one you built, or is it available as a finished product or kit somewhere?
Hopefully, but we don’t know for sure, much less when it might happen:
Sofirn C01 host version
If you haven’t put a Yuji in a coin cell light like the Photon Freedom, it’s almost a must have, and it looks like this LED would also be a great choice. Maglite Mini incans are also very easy to put a 5mm LED in.
If you want to get really fancy, I believe you can send McGizmo an LED of your choice to install in a McGizmo Sapphire, although perhaps he still has some Yuji’s left.
If you want something in the middle, there is a Surefire A2 mod product that may or may not still be available called an “onion ring” that a CPF member makes. It holds 3 LED’s and has a potentiometer to adjust output.
And then, of course, 9x LED lights are easy to come by. They can usually be disassembled by removing the batteries and pressing the pill out of the front of the light.
DavidEF
DavidEF's picture
Last seen: 7 months 2 days ago
A mix of the 3400K and 5600K in a multi-emitter light might be interesting. If they’re in equal numbers, the average CCT would be 4500K, which is a nice neutral. If it’s like other LEDs that have been used this way by some BLF members, it would actually turn out looking nicer than using the same number of just 4500K emitters in the same light.
- The YKK Philosophy
rngwn
rngwn's picture
Available pre-assembled from Aliexpress.
Barkuti
Barkuti's picture
Last seen: 1 day 7 hours ago
iamlucky13 wrote:
rngwn wrote:
It's the usb CC/CV buck-boost converter.
Looks like:
https://www.aliexpress.com/item/4000050185767.html
Some other less fancy (but cheaper) units available:
https://www.aliexpress.com/item/4000065859565.html
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Viruses DON'T cause diseases! They are better called exosomes, and they are cell cleaners! Watch Virus Theory vs Exosome Theory video and awaken to this truth! Check this article by MD Andrew Kaufman. Read the book “Béchamp or Pasteur” by Ethel Hume for in-depth information.
mitsuki08
I take it that the 5600k is not high CRI though?
rngwn
rngwn's picture
^ They are high CRI too. Just that I’m testing waters with Warm white first.
mitsuki08
Oh okay nice! I’d be interested in 25 3400k and 25 5600k if ever you plan on getting the 5600k and if I can do that(I don’t want to mess up your inventory since you only ship 50 per pack). As DavidEF suggested I just plan on mixing these for a neutral temp.
Barkuti
Barkuti's picture
Just found this 5mm led powered Mateminco BL-01 thingy @ FastTech:
Stylish “host” for an emitter swap (remember FastTech allows BLF coupon).
Unheard
Unheard's picture
Very nice little bullets. Are the LEDs up to the specs of this lights? I imagine current might be somewhat higher than 25mA. No?
1stein
1stein's picture
Thanks Barkuti!
Good idea Thumbs Up , however I had to pay extra for shipping with batteries Angry
Took also a few Fasttech flagships: authentic
rngwn
rngwn's picture
The reason that I didn’t plan to go for 5600k is that Yuji still sells 5600k 5mm (and I believe there are still some of these or similar clones selling in the wild). I don’t plan to step on their toes (yet). But if enough people want me to do it, then I will do it, no objections Wink But maybe I will, after the 2nd batch.
Unheard
Unheard's picture
Do you already have an idea how to get the PCB out? Heat? Brute force? Both?
Nice find. Bought a couple of them, too :-).
1stein
1stein's picture
I have no idea. Will see when I get them in hands.
Barkuti
Barkuti's picture
1stein wrote:
Thanks Barkuti!
This is the cheapest sale for the Mateminco BL-01 in AliExpress: https://www.aliexpress.com/item/32875327787.html
Crazy expensive.
If you wanna shop batteries at FastTech better pack some battery items together, saves money.
The battery shipping subject did a lot of harm to sales of harmless batteries and harmless battery powered stuff. I'd buy small shipments of alkaline or silver coin cells from china in the past and while it still is possible for cheap, it's not that easy.
Some sellers (in AliExpress) just @#$% with the “selected carriers for batteries” thing and ship the stuff declaring it to be something else, at least sometimes I think.
Pity.
1stein
1stein's picture
BTW:
I also took some simple 5mm LED flashlights from local market but with a dynamo. I hope it’ll withstand wide temperatures range in my car. We’ll see.
Link for the same item on Ali.
id30209
id30209's picture
rngwn, i’d like 30pcs of 5600k once you get them
DavidEF
DavidEF's picture
I can’t promise you anything. But I personally wouldn’t worry at all about the current that 3x LR41 button cells could send to this LED. Big Smile
Unheard
Unheard's picture
At least, given usage time is 3 hours. Must draw something less than 25 mA, given a capacity of 25 to 33mAh each cell. If my math is ok, that is Thumbs Up
Barkuti
Barkuti's picture
Unheard wrote:
DavidEF wrote:
But I personally wouldn't worry at all about the current that 3x LR41 button cells could send to this LED. :D
A lot less than 25mA on average, this is for sure. The actual power delivery efficiency is quite low, such cells aren't designed for high drain. Simplicity and reliability are the main factors here.
If you need 'em cheap, check this ad for example: https://www.ebay.com/itm/10PCS-1-5V-AG3-LR41-392-SR41-192-Alkaline-Button-Coin-Cells-Watch-Battery-Sturdy/382209158751 Smile
iamlucky13
They’re powered by three LR41 alkaline button cells. The 45 lumen stock rating strikes me as extremely unlikely.
Those cells can’t push much current. I don’t expect it would be any problem.
