Astrolux MF01 Mini Limited Edition Copper (1PC) and Brass (1 PC) Flashlight Set Preorder
https://www.banggood.com/custlink/3DKKBEP4zi
Discount Price: US$207.94 (Regular = $259.93)
Discount Code: BGMLES
Name: Limited Edition Set With 1x Copper & 1x Brass Astrolux MF01 Mini
Specification:
Emitter: | 7* Luminus SST-20 LED / 7* XPL HI mounted on copper DTP MCPCB |
Color temperature: | cool white: 6500K natural white: 5000K warm white: 4000k |
Body color | Copper(Red)/ Brass(Gold) |
Flux: | 5,500 lumen up to 6100 lumen actually with samsung 30T 21700 |
Candela: | 43,000cd |
CRI: | CRI95 (4000K) |
Distance: | 415 meters |
Firmware: | open-source GPL v3. Anduril firmware |
Battery: | 1x 26650 / 21700 /18650 Cell ( 26650 Recommended ) |
Driver: | High efficiency direct drive flashlight driver |
Reflector: | High quality smooth reflector |
Lens: | Glass with anti-reflective coating |
Body: | Aluminum alloy with Type III hard-coat anodizing |
Button: | Silicone rubber |
Ingress rating: | Equivalent to IPX7, do not immerse in liquids |
Impact resistance: | Up to 1 meter |
Weight: | About 1250g without cells |
Dimensions: | 180mm*135mm*65mm (length* Width* Thickness) |
Anduril extra modes:
[1] Candle mode
[2] Bike flasher
[3] Party strobe
[4] Tastical strobe
[5] Lightning storm mode
[6] Stepless dimming
[7] Beacon
[8] Momentary
[9] Muggle
AUX LED Color Charge:
[1] 3.9v-4.2v: Green, d1, d2 on
[2] 3.3v-3.9v: d1, d2 on
[3] 2.9v-3.3v: Red on
[4] <2.9v: All shut down with LVP
[5] Using 4 trimmers to adjust the brightness of AUX LED.
Features:
1. Using 7x Luminus SST-20 LED
2. Max output up to 6100lm
3. Max beam candela is 43000cd
4. High efficiency direct drive driver
5. Aerospace grade aluminum alloy
and stainless bezel
6. Advances sux leds design with color change which
indicates voltage change
7. High quality coated lens and optics
8. Hard III anodized and anti-slip knurling
9. Good heat dissipation with cooling fins
Package Incleded:
1 x Astrolux MF01 Mini Copper / Brass EDC Flashlight
1 x User Manual
1 x Lanyard
2 x O-ring
1 x Lanyard
2 x O-ring
Accessories Recommended:
