Is there an 18650 tube light (Nitecore P12 Thrunite TN12) type with Anduril?
The only one that I know with rear switch is the FW3A/FW1A
Not that I am aware of. Anduril requires the use of an electronic switch, not a standard mechanical switch with locked on/off. I have been looking for a candidate to build one, just because. I would love to do it with an Olight, but the circuit board design is problematic as it would require a mcu change and one would have to figure out the pinouts and they do not have a bank of 7135’s on the driver to work with. Likely one of the Sofirn 18650 tube lights could be converted, have not looked into them yet.
The other option is the Lumintop EDC18(?) that is a side switch light, it comes factory with Anduril onboard.
Thanks guys. Just ordered an EDC18.
Have an FW3A.
Was hoping for single emitter, love the Sofirn SC31B.
I have an SC31 and am thinking of trying to convert it.
You should check out the FW1A. It’s basically an FW3A, but with a single emitter and reflector.
Thank you I will.
You have my attention. :nerd_face:
Maybe the Acebeam TK18 would be a good light to test on. It has a tail-switch (different from the FW3A/FW1A) and it is a tube light (well,at least more than aforementioned lights). Double tube, as also the Olight M2R, Acebeam TK16 and a couple Klarus lights (although these seem different in terms of working).
D4V2 with a side switch.
I’ve got a Sofirn SP32A in the mail that I’m planning on converting.
Wonder if there is a way to flash the driver or install a new driver that can be flashed and put it in the Folomov 18650S?
I’m no firmware/software man. Just wondering if anyone has tried. I love the form factor of it. Just hate the UI.
