Slim 18650 lantern
55 posts / 0 new
MtnDon
MtnDon's picture
Last seen: 1 hour 30 min ago
Here…. a single 18650
BlueSwordM
BlueSwordM's picture
Last seen: 3 weeks 1 day ago
@Barry, I think it would be better to just make an 1865/21700 lantern.
raccoon city
raccoon city's picture
Last seen: 17 hours 9 min ago
MtnDon wrote:
Looks pretty naughty!  :P
Agro
Agro's picture
Last seen: 8 hours 28 min ago
Cloud wrote:
BlueSwordM wrote:
Pretty obvious: since the beam is directed upwards, the diffuser will make lots of glare, and doesn’t have any good firmware.
The beam will go upwards and to the sides. Mostly upwards. So just elevate it and lay your light on something so it’s directed where you need or better yet hang a rope above and tie the by lanyard to shine down – best kind of lantern light – from the top down. If you have a magnet tail in the light ( or willing to glue one on) that’s another way to mount it and have the light directed where you want. Also like the poster above said. Put the foil behind where you don’t want to light to go either inside or outside of the diffuser….
I mean, before I was into flashlights I was into lanterns for like half a year, I have about 30 different lanterns, even nodded / combined them. There is a lot I can recommend but right now. A diffuser in a regular flashlight especially if the light is Dimmable seems like the simplest 2 in one solution.,,,,
That’s a part of the reason why I like Naturehike diffuser. They reflect a lot of light to the sides thanks to having a downward directed cone at the top. They never quite keep a perfect shape and take a few seconds to get them in a fair shape. And the beam is never perfectly smooth. But they still work better than regular silicone / plastic diffusers while being very universal (my S-sized works on BLF Q8 (though barely) and on AAA light), smaller and lighter. I complained a few times that for a piece of cloth they were quite expensive. But really – if I had to buy a diffuser for every of my lights that I wanted to have it I would pay more.
Juslearnin
Last seen: 59 min 15 sec ago
These work well:
https://www.ebay.com/itm/Camping-Hiking-LED-Waterproof-Light-Tent-Lantern-Outdoor-Emergency-Flashlight/383215848030?epid=24024316358&hash=item593971ca5e:g:PLoAAOSwC-5dp9bv
There are likely multiple sellers with essentially the same design. Look carefully as there are also ones that are two 18650s long as well.
It is a ?polycarbonate tube with caps on each end. As you screw the cap down it pinches an o ring that seals it to make it waterproof. I am not really a modder, but these things are completely simple to take apart and mod.
I bought a couple and they came with a 2000 mah 18650 which is soldered in place. I bought a couple of Panasonic 3400 mah 18650s with tabs soldered on and replaced the oricginal battery. They work well.
The don’t give 360 degree illumination, maybe a little more than 180 degree as the battery is on the back side, but are light, waterproof, and compact.
This one has better pictures to see what you are getting and comes with a 2600 mah battery for quite a bit more:
http://vi.raptor.ebaydesc.com/ws/eBayISAPI.dll?ViewItemDescV4&item=113483595784&category=168867&pm=1&ds=0&t=1569288776000&ver=0&cspheader=1
On mine one press comes on low white then it cycles through high white red and I think blinking modes but at any time a long press turns it off without going through all the modes.
Here are the batteries I put in them:
https://www.ebay.com/itm/2-NEW-PANASONIC-NCR-18650-B-Li-ion-BATTERY-3400mAh-3-7v-w-pre-welded-TABS/371386465607?epid=1337918909&hash=item56785bbd47:g:YSQAAOSwDNdVqKwW
Vincent7
  I use this setup. It's a 35mm film canister. These are really cheap , in bulk, online. These fit all of my 18650 Zebralights, plus some of my other lights.
My kids use these when we go trick or treating. I just put a little bit of electrical tape around the bottom, so the canister doesn't get knocked off.
It makes a nice , inexpensive lantern, with great run times and slides on and off easily.
sueli428
sueli428's picture
At 99 dollars, I am not sure if it qualifies as a “budget” light.
It uses a 26650 battery.
It is made by a company called Lantern. Seems like a really bad idea for a product name.
It is basically a flashlight with a diffuser on it. The tint looks kind of blue.
They sell the diffuser separately for $12.50. Opening is listed as 33mm or 1.3”.
Could maybe fit on a cheaper flashlight with a better tint and the same diameter bezel.
Anyone know of an 18650 or 26650 flashlight with good tint like Nichia 219C 5k for cheap with a 33mm or 1.3” bezel diameter?
I guess something a little bigger could be turned down, and smaller could be shimmed. I am not sure how much being wider on the top would negatively effect carrying and packing. I know for me it would always be falling over onto that wide part of the diffuser, so it would need to be sturdy.
https://lanterngear.com/collections/all-lanterns/products/lantern-black
https://www.youtube.com/watch?v=JdUGej9jx_4&feature=emb_title
Anyone heard of these and know about them, such as who manufactures them ?
MoreLumens
MoreLumens's picture
Last seen: 10 hours 23 min ago
I use Fenix AOD-S with BLF A6. Also fits nicely on Zebralight SC5w OP and works with Fenix LD12 too.
Jerommel
Jerommel's picture
Last seen: 1 year 6 months ago
This is not such a bad idea either:
https://www.aliexpress.com/item/32887936541.html
…but it’s AA…
DBSAR
DBSAR's picture
Last seen: 12 hours 17 min ago
…but it’s AA…
i have bought many variants of that over the years, if they would only build one without the blue-tint Latticebright XPE knockoff LED, remove the blinky modes, and not use a horrible PWM on the low mode, they would be a good pocket light micro lantern for emergency uses.
sueli428
sueli428's picture
That fenix diffuser is even more compact and cheaper than the Lantern one.
MoreLumens
BLF A6 4000k with diffuser and also my favourite aa-lantern Nitecore LR10 CRI.
BLF A6 with all those 7 different modes is pretty perfect with diffuser. All other lights that I been trying with it just seems to be always too bright or too dim, but not with this one.
raccoon city
That Fenix AOD-S diffuser looks real nice.
It's kinda pricey for what it is, though.
By the way, on AliExpress, they have it with free shipping.
(I don't know if Fenix sells their stuff on their website with free shipping.)
MoreLumens
Yeah it works. Little tight to get on, but you can easily sand some plastic inside to get a perfect fit.
raccoon city
There's a number of flashlight diffusers on AliExpress for under $2 shipped.
They couldn't be as nice as the Fenix one, but maybe they're good enough.
Search for:
flashlight diffuser
This one is the cheapest I've seen at $1.25:
https://www.aliexpress.com/item/33007563406.html
It's made for the Convoy S-series.
EDIT:
Here's something similar, and they actually deliver to the U.S.:
https://www.aliexpress.com/item/33004560643.html
raccoon city
Looks like a lot of the cheap diffusers are made for the Convoy S-series, which would also fit the BLF A6.
Because the FW3A is just a little bit bigger in diameter, I think the diffusers would sadly be too small for it.
aswang
Last seen: 1 week 1 day ago
I agree with Agro. I have too many diffusers and the naturehike is the one I use the most. Not as easy to set up but it works with almost all of my lights including headlamps, diffuses the light to the sides and not as much glare as using regular silicone or plastic diffuser because of the surface area. Doubles as a carrying pouch too.
agent80
Last seen: 3 hours 39 min ago
How does the Nature hike diffuser stand around the light? Doesn’t it collapse under its weight?
freeme
freeme's picture
Last seen: 4 hours 38 min ago
LR12
1thedeals.comyoutubeAstroluxNealsgadgetsolight
aswang
The small one stands ok. Not sure of the large one since I don’t have one.
snakebite
snakebite's picture
Last seen: 4 days 15 hours ago
is that remote phosphor?
nice use of the 2 liter bottle blank too
!{width:35%}https://images3.imgbox.com/de/d6/UeHxJeOm_o.jpg!
MtnDon
MtnDon's picture
snakebite wrote:
is that remote phosphor? nice use of the 2 liter bottle blank too
MtnDon wrote:
Here…. a single 18650 !{width:35%}https://images3.imgbox.com/de/d6/UeHxJeOm_o.jpg!
Yes, that is a remote phosphor, used with a royal blue XT-E led. XP-E also has some royal blue.
Chromalit is the brand name of the phosphor. Digikey some. I think Arrow does too.
D'AVerk
Last seen: 8 months 3 weeks ago
freeme wrote:
LR12
On this price it is not a solution against convoy+diff :)))
86250rrippin
Last seen: 3 weeks 2 days ago
18650 lipstick battery pack, 6 led dimmable usb light ,old pill bottle . Stays cool,runs all night easy , cheap . Pretty ghetto but it works awesome and I like the color. Its on high in pic , lower settings look more like a candle or oil lamp. My BFG LT1 is on order .
Sofirn BLF LT1Lantern, Sofirn BLF SP-36 , Thrunite TC-20 , Thrunite Catapult V6 , Firefies E01 , Astrolux C8 , Emisar D4v2 , Folomov 18650s , Lumintop FW3A , Thrunite T10T V2 , BLF A6 , Wurkkos WK30 , Olights , Streamlights , and one Old-School Maglite 3 cell D.
