The Feit enhance bulbs on costco’s site all have terrible reviews indicating bad caps and build quality, but as you said the models were different.
If I knew what to look for i’d be willing to sacrifice one to see if they’re built any better.
Caps that are rated 105C or less, worse if they’re not japanese. Good ones are rated 130, only 6 cents more.. They’re always potted with grey stuff, have fun with that..
Once had some overpriced chinese ones rated 85C (viribright) needless to say they die fast >_<
Ok, i’ll crack one open after work and report my findings.
It wasn’t potted. Just a little bit of crunchy glue (epoxy?) holding the driver in place…
Chinese put meaningless markings… you never really know the real values… even Adam’s chinese sunlike have inaccurate document/rating according to him…I don’t trust chinese electrolytic capacitors. Probably why the reviews are so bad.
Even if they “can” last advertised ratings, Chinese products have a higher error rate than Japanese. USA-made suffers a similar problem sometimes, misleading measurements…
Not necessarily saying its bad as there isnt much info on the new brands, but China loves to rebadge stuff..
I only like high CRI, I have or have had in order of pref:
Fireflies NOV-MU 21 4500k E21A (preorder)
Fireflies ROT66 219B SW45 D220
Fireflies E07 219B SW45
Emisar D4 SST20 4000k frosted lens (the lack of some preset levels kinda makes me want to rate it lower though...)
Jaxman E2L 219c 5700k (indoor use only due to color temp)
I bought a 4 pack of the “100W” equiv Feit bulbs from Costco a few weeks ago. I could probably get spectral readings one of these days.
On another note I bought some of these EcoSmart brand “filament style” LED bulbs with clear glass casing. Color temp of 3000K is really nice and they dim with my cheap Lutron dimmer with NO BUZZING. It’s a miracle. I’ve tried like half a dozen bulbs with this dimmer and they all buzz so that is very exciting even though the bulb might only be 80CRI, need to test it as well.
At around $2/bulb i’m definitely willing to give them a shot. I’ve been searching for a while and i’ve yet to find any other bulbs even near this price range with this CRI/R9 and dimmable.
That being said, i would’ve gladly paid slightly more for better electronics. I wish these could be opened up without destroying them. It may be worth it to swap the caps.
I was worried about dimmability too. The Feit’s dim with no issues on my Caseta dimmers. They just don’t get quite as low as my recessed lights. I’d say about 10-15% dim.
I believe the Feit’s buzz a little (like most LED bulbs to be honest) but really it’s only an issue on bathroom lights for example where it’s quiet and you commonly have down facing globes right next to your face.
Thanks for the tear-down elwood. I’m going to visit my local Costco and see what they have.
Another thing that I’ve been debating is to just modify all of my Walmart brand LED bulbs. Every one that I’ve opened so far has used 9 series 3030 mid-power chips that share a footprint with Optisolis. A couple of strap wrenches and heat from a hair dryer twist of the plastic diffusers which are held by a white silicone. Problem is I don’t have enough Optisolis emitters right now to even do one bulb in a low CCT.
Damn,I have allocated some time to search for DIY parts to build similar “sunlike” led bulbs. And only now realized how big that bulb would be… Seems 7W-9W (based on sellers specs) is the biggest TDP I could afford while purchasing Al LED bulb shell. That plastic diffusor on powerfull led bulbs takes too much space.
Good thing about those bulbs is that you can just screw the diffuser out, which isn’t needed if you have a diffusing fixture or ceiling bounce the light for example.
Could you post a picture of the rest of the bulb and emitters please?
“Remez” brand offers led bulbs on Seoul 3030 sunlike LEDs.
Quote:
South Korean LED maker Seoul Semiconductor Co Ltd says that its SunLike Series natural-spectrum LEDs have been adopted for lighting brand ‘REMEZ’ by RemiLicht GmbH for the Russian lighting market. The LED light bulbs feature a human-centric lighting design enabled by the SunLike Series LEDs.
I’ve had terrible results with most LED bulbs I’ve purchased… well ever. I have a couple brand name units which are going strong but most of the normal replacement LED bulbs (is it A19?) seem to fail in the same or less time than the old incans.
I’m not super picky, just looking for something which will last, is affordable and offers 4000k or warmer with 80 or better CRI. Is there any particular “go-to” replacement bulbs which would fit this requirement?
Only DIY… unless you’re using low power “commercial” bulbs (usually max 600 lumen) rather than off the shelf “consumer bulbs”. The package can’t dissipate the heat, and many consumer bulbs are built to fail.
Some DIY implementations are pretty easy and simple…$500 photographer panel for $72 parts, but tools are always needed no matter the route
Honestly, I’ve used Walmart’s Great Value brand 2700K 60W (and a few 80 and 100s) almost exclusively over the years. I’ve bought dozens of them and never had a single one fail during use. Maybe I’m lucky, but I think they’re pretty reliable.
As for CRI, I don’t know where they stand. Tint from revision to revision has varied above and below the BBL, but never really objectionable. Warm white mid power emitters probably have 80ish CRI as standard I’d guess as <3000K black body curves are much easier to replicate. I’m going to swap one of mine to Optisolis and see how it compares in the real world. Just waiting on a shipment..
Buy a name brand and keep your receipt + the cardboard part of the box. Philips stood behind their warranty for me i’m sure the other big name brands would too. I’ve also taken a current model CREE bulb back to home depot and exchanged it for its same model with no receipt. It’s rather absurd to say no consumer bulbs are good.
The fixture, line power, weather, and a dozen other variables come in to play as well when it comes to the reliability of these bulbs. I think initially and to some extent still these are marketed as lasting a “lifetime” or never having to replace them in order to justify their higher cost but it’s simply not true.
Hyperikon delisted their 1600 lumen bulbs from amazon for a reason… landlord said major manufacturers didnt want to warranty unless he paid thousands for whole house regulation
Can somebody summarize for me the whole Costco discussion, do we have there a new ultra high CRI candidate?
No, they are like 92 CRI, ~60 R9 and dimmable but considering those specs they are quite cheap and represent a good value. Not a new ultra CRI candidate though.
The one’s i purchased are, supposedly 91 CRI, 90 R9. Just saying
I do agree though. They’re not ultra CRI but at just over $2/bulb they’re an excellent value.
Now I am dealer of the REMEZ =)
With price like in official site (10-20% highter)
I have international shipping, but now it is 6$ for any order (by belpost)
About time of life of REMEZ bulb.. 30000 hours.. How they test it? Just by 1000 hours =)
You can buy REMEZLED bulbs with international shipping HERE
I just taked results of the SmartEcoLightning (who do SOLs)
I am going to do bulbs with their LEDs with UV and IR for plants (additional light). But it will be for eyes too. It is with extreme hight CRI too. I am going to do 6, 12, 18, 36, 110W
1st. – Big aluminum body-radiator.
2nd. – 130° capacitors.
3d. – high CRILEDs with all spectrum. I mean hight CRI in all R1-R15 indexes.
Just put some in my basement fixtures. Tried the 5000k but they were… just wrong. Too harsh. The 3000k rated ones (which feel more like 4000k to me) are quite nice, though. While not ULTRA high CRI, they are very decent and certainly heads and tails above most other commonly available LED or CFL bulbs. Typically our basement bulbs last a long time due to limited use, so might not be the best test of durability but we’ll see. I did date each bulb on the base in sharpie.
https://badcaps.net/forum/showthread.php?t=57684
Jaxman E2L 219c 4000k
Klarus Mi7
Varmint removal (throw):
Convoy M21A C8 ver SST20 4000k (5a)
Convoy S2+ SST20 4000k (3200ma)
Lumintop ODL20C
CRI test dump https://drive.google.com/drive/folders/1kcl_uOhgfpR4RSsa8F4b-UUVP9mkL6Cr...
yes, thx. It might (will) look ugly but at least something.
Will try to find more info about this shell
The one on the left might be a solution.
He posted where he gets his parts somewhere.. said the ones on aliexpress were cheaper and broke.
https://shop.tbfocus.com/item.php?id=18603492069#3497744845763 was one of the links
Klarus Mi7
Lumintop ODL20C
I already tossed everything but I did take these before doing so…
http://www.semiconductor-today.com/news_items/2019/nov/seoulsemi-051119....
“En” version is not ready (https://remezlight.com/en/).
All led lamps on “ru” site are in preorder (https://remezlight.com/production/led-bulbsz/) and no international shipping.
Klarus Mi7
Lumintop ODL20C
Klarus Mi7
Lumintop ODL20C
Thanks, just added to the table. Hope we'll be able to have independant testing for them in the future.
Rise and Shine my precious...
You can buy REMEZ LED bulbs with international shipping HERE
BelMORDOR’s Ламповщик|Lampman
https://t.me/sunlikenews
Does it support 120V, seems like it doesn’t from their site? Also, too bad about no dimming.
I will send it to Maukka for test. They do not want to send it now. I mean for free. They concentrated in Russia market now. So, I will do it.
Also I will do review on my youtube.
3d. – high CRI LEDs with all spectrum. I mean hight CRI in all R1-R15 indexes.
Alright I spent $99 on this Android app cause I was too lazy to install and carry a laptop all around my house for you guys.
NOTE: the only one I allowed to “warm up” was the 100W Feit, all the rest were on for less than 1 minute.
EcoSmart 60-Watt Equivalent A19 Dimmable Energy Star Clear Filament Vintage Style LED Light Bulb Bright White (4-Pack) “3000K”
Cree 40W Equivalent Soft White (2700K) B11 Candelabra Exceptional Light Quality Dimmable E12 LED Light Bulb (2-Pack)
CEOM100/930/4 (N) – Feit enhance 17.5W (100w replace) 3000K – COSTCO
Builder installed recessed lights in house
One last bulb, a GE 15W T8 fluorescent replacement in the garage:
CRI 81.3
R9 15.6
R12 60.5
CCT 3836.5K (0.0047 Duv)
Rf 81.7
Rg 97.8
