After reading the positive recommendations for the MiBoxer C4, I was browsing through the Amazon deals thread and found a coupon code that made it too good of a deal to pass up. I got this to replace my Xtar WP2 and LaCrosse BC700. Yes it has been a few years and things keep changing.
I hope that someone with more tools, knowledge, and experience than I have will review the V3 MiBoxer C4. From what I can see this is quite a different charger than the one recommended. I think that is a good thing. From what I see this appears to be a very good charger. MiBoxer appears to be making a number of changes that I think make the charger better but I am not qualified to make that judgement. FWIW, here are some observations after a few days of using it:
Three significant changes from things mentioned in the reviews.
- The no termination issue appears to be fixed. Goes to 0 when full.
2. They have removed the battery test feature from slot 4.
3. Choice of charging currents is much larger, going all the way to 1.5 amps.
I have mostly just used the charger in automatic mode at this point. I am impressed. It appears to constantly monitor the battery and adjust the current accordingly. Some cells charge noticeably faster than my experience and some noticeably slower. Seems to depend on internal resistance.
I noticed, the last time I charged 4 of my LADA AAs in the LaCrosse, that one of them terminated very early. Didn’t think that much of it just pulled the cell and put it back in again and it appeared to finish charging with a total charge of about what I was expecting. When I put that same set in the C4, I noticed that one cell had a much higher internal resistance (something I haven’t measured before) and was getting a charge current much less than the others. In the end they all took about the same mAh but one cell took a lot longer to get there.
NiMh “leakage”? I was used to drained LADA 2450s taking 2.6 to 2.8 Ah to charge. Running a battery test would give a figure closer to 2.45. Attributed the rest to “leakage” as the cells were charging. Dissipated as heat actually. The V3 removed the test function and the manual simply tells you to fully drain the cell first then charging it will give you the capacity of the cell. In automatic mode this appears to be a reasonable test. Perhaps because of the way the charger adjusts the current there just isn’t as much heat dissipated therefore reducing the “leakage”? Seems to me like I can get a reasonably good measurement of a cells capacity this way. Think it might be quite a bit better for the batteries as well if they are getting a full charge with out excess current.
Nearly every 18650 I have is far less than what it is supposed to be. I kind of already knew this but the Xtar had no read out so this just confirmed what I kind of already knew. The red ultra fires that came with a headlamp a friend got cheap on ebay hold a wapping 300 mAh under their 3,000 mAh wrapper. Strangely enough they have good internal resistance readings. One of these days I am going to try the cell lottery again as I know that there are good cells out there today and I hope to get some.
Looking forward to learning more about this from someone with the necessary knowledge and tools.
