My Vapcell S4+ Analyzing Charger photos and observations
137 posts / 0 new
d_t_a
Last seen: 4 hours 56 min ago
Jimo wrote:
Does that work in all modes such as capacity test.  And when capacity test starts discharge do I need to do it again for 1a discharge
And are all 4 slots capable of 3a charge and 1a discharge. And thank you for taking the time to help me. Jim
That’s 2 questions in one.
As tatasal mentioned, all 4 slots can do 3A charge current.
But only slots 1 & 4 can do 1A discharge current, while slots 2 & 3 (middle) can do 500mA discharge current.
While on Capacity Test mode, it seems the S4 Plus automatically selects the discharge current to use (I’m not sure if it depends on the selected charge current, or maybe the IR measurement, since for Capacity Test mode, only the Charge current is user selectable, assuming in “Manual” mode; the Discharge current is automatically chosen by the charger).
However, one can manually set the Discharge current when using the “Discharge” mode (outer 2 slots max 1A discharge current and middle 2 sltos max 500mA discharge current).
TheAuditor
Last seen: 4 hours 45 min ago
I think mine just blew up. With one battery in channel one, it showed all four channels charging, and there was a burning smell. I have turned it off Smile
Bonum commune communitatis.
Yarp.
AguassissiM
AguassissiM's picture
Last seen: 8 hours 31 min ago
That sounds very close to my misfortune with my Vapcell S4+ only 10 months old, good luck trying to get it replaced under warranty…..
***Rofis MR70*TurnRaise*Catapult V6*BLF Q8*BLF Mini*BLF Micro*Haikelite MT09R* Convoy C8*BLF D80v2 SST40*MatemincoX6S*AstroluxFT03-xhp50.2*AstroluxFT03-sst40*BLF-LT1*AstroluxFT03S-SBT90.2***
TheAuditor
I had an AAA battery blow up in ch4 and the charger developed issues after that, which does d not end well. I suspect the battery going bang damaged things.
Yarp.
AguassissiM
I only used mine to charge the 18650,21700,26650 and one day it just refused to work and died.
When power is applied the screen back light comes on very dim and you can not see anything that is normally displayed,
when i insert a battery in any of the slots the display turns a little brighter and when viewed from an angle i can see a very dim outline of the functions,
however there are strange things happening, no matter the slot i choose using one battery the charger never shows the proper slot information where the battery is inserted it shows that there is nothing in that slot but it shows 1 or 2 different slots without any battery in them that these slots are charging.
When I insert 4 batteries everything goes blank even the dim back light goes out.
Jimo
I purchased vapecells4plus, and it works very well. The only issue is that batteries must be put in correctly. To get accurate readings.
Jimo
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 19 hours 57 min ago
I really wish the sound it makes when a cell is finished charging could be turned off, it drives my dog nuts.
Jimo
I don't think it is supposed to make a sound.
Jimo
BurningPlayd0h
Jimo wrote:
I don’t think it is supposed to make a sound.
Mine gives 7 or 8 fairly loud beeps when cells are finished charging, and the reviews I read (including HKJ’s) before purchasing it mentioned it as well – if it weren’t for the great performance in every aspect it would seriously make me consider using something else.
Maybe it doesn’t do that in manual mode? I’ll test it tonight.
Jimo
Mine beeps about 5 times when finished changing and thats it. So mabey something wrong with yours or something wrong with mine
Jimo
BurningPlayd0h
I’ve never counted the exact number of beeps but otherwise that’s… exactly what I described mine as doing?
Jimo
It's supposed to beep when charging is complete.
Jimo
BurningPlayd0h
Jimo wrote:
It’s supposed to beep when charging is complete.
Okay, good that mine is doing what it should but I really wish there was a setting to disable the sound. This is the only charger I’ve even heard of having any sort of audio feedback.
Jimo
The xstar dragon peeps to
Jimo
d_t_a
Aside from the Vapcell S4 Plus, the Liitokala Lii-600 also beeps (10 quick beeps) after finish charging. Both don’t seem to have user-configurable way to disable the beep sound though.
The SkyRC MC3000 and Xtar Dragon VP4 can also beep on finish operation/charging, but sound can be configured to disable sound.
Personally, I didn’t seem to get too bothered by the audio feedback for charging completion — maybe because in my area, there is a lot of ambient sounds and I’m already de-sensitized… (I suppose my flashlight beamshot videos can attest to that — there are always lots of background noises around my place even at night…)
I personally find having audio feedback (after finish chargng operation) to be good, since I can know that the charger has finished charging even when I’m not looking at it. Although, I understand that depending on the scenario, maybe those beeps may be a little bit bothersome for others…
So far, I only know these 4 chargers with audio feedback, are there other chargers that also have audio feedback after charging operation? (I can’t remember if the previous Lii-500S also has beep sound after finish charging..)
Hikelite
Last seen: 6 months 4 weeks ago
Has anyone tried to open up the device and physically remove the buzzer?
BurningPlayd0h
I would try that with almost any electrical device except a li-ion charger. The consequences of something going even slightly wrong are just too high, especially with my (low) level of skill and knowledge.
…also microwaves. Do not screw with microwaves because they will find 10 different ways to kill you before you’ve even gotten a decent look at the internals. Shocked
TimMc
TimMc's picture
Last seen: 20 hours 36 min ago
Yes. I opened up my Vapcell S4 plus and desoldered the buzzer. I don’t recommend doing this. It’ll probably void any warranty.
https://imgur.com/a/zVjkXWt
tatasal
Last seen: 7 hours 41 min ago
Seriousness aside, I personally have no problem with a charger buzzer. I have a hearing damage that weirdly does not let me hear that certain buzzer frequency.
My family always complain whenever I use my iCharger, and Vapcell. It also buzzes when it’s Done..making them go crazy watching me having no reaction to it!
Though I can hear it if I only put my head, or ears, just a few inches away from the charger.
BurningPlayd0h
Agreed, it’s the dog that has a problem with my S4+ not me Big Smile
Hikelite
Yeah, but you know it is just a buzzer, unless it is monitored if it buzzed or not (which I would doubt it is).
Now regarding a li-ion charger, look at that reflow on the 3.3uH inductor, quite weak for a li-ion charger, twisted a bit more and you have a short, would not be bad a take the heat gun and correct it.
Hikelite
Thanks for the pictures, I am sure will void the warranty.
Yet I wonder who will honor warranty especially if I buy it from overseas.
The buzzer seems there where I added the red circle?
Hikelite
Well, I got the opposite issue, I hear everything and most around me can’t hear anything, I hear the buzzing of the video card, of the monitor while I scroll, buzzing of the wall USB adapters, the Ikea E14 bulbs buzzing, I hear the silent fans, the neighbor that has to drill a new hole at 7 AM in the morning (seems he fancies this time of the day each day of the week for noises)
I often think of others with worse hearing than mine that they might have it better not hearing anything under the sun. Smile
tcc
I just got the vapcell as a companion to my original maha c9000.  Love how clear the display is.  Everything is going good so far but I was wondering if there is a chart somewhere which lists different sizes of li-ion batteries and what charge/discharge current to use?  Something like this
This chart is for NiMH/NiCd batteries.
tia
TimMc
TimMc's picture
I use these values:
10440 -> 250 mA
14500 -> 500 mA to 1A
18350 -> 500 mA to 1A
18650 -> 1A to 3A (best to read the data sheet for your cells)
21700 -> 1A to 3A (best to read the data sheet for your cells)
It depend on the cell.
tatasal
So far the common, accepted safe max charging rate for li-ions is 1C and at least .33C for niMh.
For discharge, 500mA to 1A is acceptable for both.
dts71
Last seen: 1 month 1 week ago
Could it simply be the power adapter that is broken?
Have you tried another?
AguassissiM wrote:
I only used mine to charge the 18650,21700,26650 and one day it just refused to work and died. When power is applied the screen back light comes on very dim and you can not see anything that is normally displayed, when i insert a battery in any of the slots the display turns a little brighter and when viewed from an angle i can see a very dim outline of the functions, however there are strange things happening, no matter the slot i choose using one battery the charger never shows the proper slot information where the battery is inserted it shows that there is nothing in that slot but it shows 1 or 2 different slots without any battery in them that these slots are charging. When I insert 4 batteries everything goes blank even the dim back light goes out.
tcc
Just a quick question.  I charged a Nitecore 21700 (NL2150) and the nitecore site says it's 3.6V but as you can see from the picture, Vapcell charged it to 4.2V.  Is this an issue?  Or am I mistaken some how?
Jimo
The Vapecell charger works well. But I have noticed sometimes the readings are not consistant.And it has alot to do with how the batteries are put in the charging bay. I would recommend that when you place the batteries in charger that they are perfectly straight. Try running them again and see if
reading is different. If the readings are the same ask the battery manufacturer about them.
Jimo
tcc
Dug a little deeper and found this.  So it seems ok (Doh) laughing
