Test/review of Golisi IMR18650 3500mAh L35 (Gray) 2019
10 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 day 20 hours ago
DSC_1079
Official specifications:
  • Capacity. 3500mAh
  • Maximum constant discharge current: 10A
  • Maximum peak discharge current: 20A
  • Has a build in fuse that blows if battery is shorted.
Golisi%20IMR18650%203500mAh%20L35%20(Gray)%202019-info
A high capacity 18650 cell with good current capabilities.
DSC_1078
DSC_1080 DSC_1081
DSC_1082
DSC_1083
Golisi%20IMR18650%203500mAh%20L35%20(Gray)%202019-Capacity
The two cells tracks nicely, the rated 10A current is just around maximum, I had to stop the discharges due to heat.
Golisi%20IMR18650%203500mAh%20L35%20(Gray)%202019-Temp-7.0
Golisi%20IMR18650%203500mAh%20L35%20(Gray)%202019-Temp-10.0
Golisi%20IMR18650%203500mAh%20L35%20(Gray)%202019-Temp-15.0
Golisi%20IMR18650%203500mAh%20L35%20(Gray)%202019-CapacityTimeHours
Golisi%20IMR18650%203500mAh%20L35%20(Gray)%202019-Energy
Golisi%20IMR18650%203500mAh%20L35%20(Gray)%202019-PowerLoadTime
Golisi%20IMR18650%203500mAh%20L35%20(Gray)%202019-TripCurrent
Golisi%20IMR18650%203500mAh%20L35%20(Gray)%202019-Charge
Discharge-Golisi%20IMR18650%203500mAh%20L35%20%28Gray%29%202019-pulse-1.0%2010%2010-IR
Conclusion
This looks to be a good high capacity cell for loads below 10A.
Notes and links
The batteries was supplied by Golisi for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
malkoff junkie
malkoff junkie's picture
Last seen: 1 hour 49 min ago
thanks where to buy ?
Malkoff !
RapidLux
Last seen: 46 min 3 sec ago
https://www.aliexpress.com/item/32910402600.html
maukka
maukka's picture
Last seen: 10 months 1 week ago
$10 a piece for a battery that is similar in performance (worse when approaching 10A) to a $5 NCR18650GA. No thanks.
gerasalex
gerasalex's picture
Last seen: 1 week 9 hours ago
Good, but, nevertheless, according to your graphs, it loses a little, relative to the Sanyo NCR18650GA 3500 mAh battery..
"... God is light, and in him is no darkness at all..." 1 John 1:5 (KJV)
d_t_a
Last seen: 19 hours 15 min ago
Is this another contender for the “3500mAh” category of 18650s (NCR18650GA, INR18650-35E, MJ1) or would this be a bit worse off?
malkoff junkie
sticking to GA.
Malkoff !
Superstocker
Superstocker's picture
Last seen: 33 min 11 sec ago
Thanks HKJ!
MrE
Last seen: 11 months 2 weeks ago
Superstocker wrote:
Thanks HKJ!
Indeed!
The aliexpress listing won’t even ship to the US anyway!
shadockan
shadockan's picture
Last seen: 4 weeks 8 hours ago
Thank you HKJ.
For those wondering what kind of battery it is, this is the LG MJ1 rewrap
Sanyo GA is a little stronger.
