Sofirn 21700 4800mAh 3.7V Battery 48A 10C
13 posts / 0 new
Hank33
Hank33's picture
Last seen: 3 days 15 hours ago
What to members think of the following battery? Good perrformance? I know everyone talks about the VCT6 or Samsung 40T but are the Sofin ones ok also? Pls say they are cuz I just ordered some sealed
Now time to choose a 21700 thrower! cool
Skylight
Skylight's picture
Last seen: 3 hours 27 min ago
Sofirn battery are not the highest performing around but generally they are good quality.
If these 21700 have 4800mAh you can expect a maximum current of 10 to 15A from them. No way they will deliver 48A. But these are for high capacity not for high current.
In terms of 21700 thrower take a look at the Noctigon K1.
Hank33
Hank33's picture
thaanks
lawallac
lawallac's picture
Last seen: 2 days 20 hours ago
Also if you get the K1 you won’t need a really high drain cell, the high capacity would be the way to go.
Barkuti
Barkuti's picture
Last seen: 13 hours 38 min ago
In the world of battery cells one common misconception from people lacking expertise is interpreting number suffixes ending in “A” as amperage ratings. Third party cell rewrappers are guilty of feeding this. Actual manufacturers of batteries never rate their cells that way, i.e. a Samsung ICR18650-30A isn't rated for 30 A discharge. Actual, detailed OEM ratings are in cell datasheets. Cells with explicit current ratings in their wraps are rewrapped cells.
That 4800 mAh 21700 cell most likely is a 2C rated cell, or around 10 A maximum continuous discharge. Examples: LG M50T, Samsung 48G. And while some testing should be done, bear in mind Sofirn is unlikely to pay big bucks for high performance and hard to obtain cells, i.e. cells could very likely be from some good chinese OEM like Lishen.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your spirit or soul. Innocent
Keanu Reeves may need your help. Join his Telegram channel here.
SKV89
Last seen: 5 days 11 hours ago
No way any 21700 with 4800mah will have 48A current. This is likely a Samsung 48G with 4.8A continuous discharge. Or if we’re lucky, it could be the Lishen LR2170SF, which from my test average about 4750mah and is rated for 13A. Testing it in my Fireflies E07, the LR2170SF outputs a good bit higher than the LG M50T and the Samsung 50E so it is definitely the best high capacity cell if you care about output. The Noctigon K1 with even the White Flat 2mm emitter, it only uses 7-8A of current so the 50E and M50T should be more than adequate.
Hank33
Hank33's picture
Ahh shucks I already ordered if BEFORE I posted the thread Grad Now I’m forced to look for a 40T Big Smile
Hey great info all! Big Thanks Smile
ggf31416
Last seen: 48 min 52 sec ago
They indeed claim 10C discharge, 48A, but there is no way that’s feasible. It could be a pulse rating but pulse ratings are deceptive because you never know what’s the ‘pulse’ duration.
Barkuti
Barkuti's picture
SKV89 wrote:
… Samsung 48G with 4.8A continuous discharge. …
The 48G can be discharged at up to 2C continuous, just not for cycle life. Which pretty much is in line with any other cell, i.e. you won't get optimum or maximum cycle life discharging at strenuous rates.
Sofirn
Sofirn's picture
Last seen: 9 hours 35 min ago
Hi BLFers and Sofirn Fans!
You can purchase direclty on our official website: www.sofirnlight.com now!
We uploaded flashlights, batteries&chargers. Some are the latest version, some are old models for inventory-clearance. Check all the products and see what you need! It doesn't matter where you are located.
Link: https://sofirnlight.com/collections/all
https://cdn.shopify.com/s/files/1/0286/7671/8652/products/3_9254a4d6-244c-45c4-be6e-693e0ffca015_1024x1024@2x.jpg?v=1576227713https://cdn.shopify.com/s/files/1/0286/7671/8652/products/H18180abb826f4ed78db2fd166126b792x_1024x1024@2x.jpg?v=1575873715https://cdn.shopify.com/s/files/1/0286/7671/8652/products/PLB_26650_1024x1024@2x.jpg?v=1576208326https://cdn.shopify.com/s/files/1/0286/7671/8652/products/product-image-1210424084_1024x1024@2x.jpg?v=1576203814
Furthermore, if you need some products online but no good place to buy, we can find the source and sell on the website at a great price!
oops, almost forgot the discount code: ALL$2OFF. Use it to save US$2 for your order. Only 18 times left to be used. First come, first served!
Any questions, please reply or PM.
Sofirn Team
Sofirn
Sofirn's picture
Thank you for your thread. I released a post below your this post.
Have a nice day!
Barkuti
Barkuti's picture
Sofirn, please pay more attention to what you do. First of all, you came here to post old news, i.e. you posted about your website yesterday in the thread Purchase Directly on sofirnlight.com. By this time the discount code is no longer valid, and certain stuff like PLB cells is out of stock.
I looked at PLB cells yesterday, you barely had a handful of them for sale. Do you plan on stocking more INR26650-50A units at $3 each? That is great price for battery pack assembly, something I do sometimes.
Anorher important thing is, your above #10 post is badly formatted. All its spaces are encoded as non-breaking spaces, this prevents the forum engine from properly dividing the text in lines. Non-breaking spaces should only be used between words you strictly don't want to look separated, and nothing else! Flat Stare
Moleyman69
Last seen: 1 month 6 days ago
Funnily enough, I had four of the 4800mah Sofirn cells just arrive on Friday.
Discharging at 1A on my Opus C3100 v2.2 I got the following capacities:
5092
4984
5092
5067
I also received four of the 4000mah version as well for comparison and got these capacities:
4352
4261
4346
4413
Hope this helps,
Moley
