Test/review of Orico 3-port Mobile Phone Charger WHC-3U
2 posts / 0 new
HKJ
HKJ's picture
Last seen: 4 days 12 hours ago
DSC_0184
Official specifications:
  • Brand Name: Orico
  • Output Interface: USB
  • Max. Output Power: 15w
  • Quality Certification: RoHS
  • Quality Certification: ce
  • Model Number: WHC-3U
  • Applied Fast Charge Protocols: No Support
  • Power Source: USB
  • Input: 100-240V/0.3A
  • Type: Travel
  • Item: ORICO 3-port Mobile Phone Charger
  • Material: PC+ABS Fireproof
  • Input: AC 110-240V 50/60HZ 0.4A
  • USB Output: 5V2.4A*3, MAX15W
  • Protection: Over-heated/Over-current/Over-charging protection
  • Plug: EU Plug
  • Color: Black/White
I bought it from Aliexpress store Orico Official Store
DSC_0177 DSC_0178 DSC_0179 DSC_0180
It arrived in a cardboard box with specifications.
DSC_0181
The box included the charger and a instruction sheet.
DSC_0185 DSC_0189 DSC_0190
DSC_0186 DSC_0188
DSC_0187
Measurements
  • Power consumption when idle is 0.06 watt
  • USB outputs are coded as auto with Apple 2.4A, Samsung, DCP
  • Weight: 68g
  • Size: 88.4 × 58.3 × 27.3mm
Orico%203-port%20Mobile%20Phone%20Charger%20WHC-3U%20%231%20230V%20load%20sweep
The first output can deliver 3.7A
Orico%203-port%20Mobile%20Phone%20Charger%20WHC-3U%20%233%20230V%20load%20sweep
The same with another output.
Orico%203-port%20Mobile%20Phone%20Charger%20WHC-3U%20%23123%20230V%20load%20sweep
And all outputs together is also 3.7A
Orico%203-port%20Mobile%20Phone%20Charger%20WHC-3U%20%23123%20120V%20load%20sweep
At 120VAC it drops to 3.5A, this better than the rated 15 Watt
Orico%203-port%20Mobile%20Phone%20Charger%20WHC-3U%20load%20test
The charger can deliver 3A for one hour.
The temperature photos below are taken between 30 minutes and 60 minutes into the one hour test.
Temp7095
M1: 65.5°C, M2: 42.3°C, HS1: 65.8°C
Temp7096
HS1: 56.7°C
Temp7097
M1: 63.8°C, HS1: 69.0°C
Temp7098
HS1: 68.2°C
Temp7099
M1: 47.8°C, HS1: 64.7°C
10ohm
At 0.5A the noise is 7mV rms and 339mVpp.
5ohm
At 1A the noise is 10mV rms and 330mVpp.
2ohm
At 2.5A the noise is 22mV rms and 362mVpp, generally the noise is low.
Tear down
DSC_1679
As usually with this design I could mount the base in my vice and break the top off to open it.
DSC_1680
On this side is the input fuse (F1: 2A), two mains smoothing capacitors (EC1 & EC2) with a inductor between (L1). The safety capacitor (CY1) is mounted close to the USB connectors. There is a large switching transistor (Q1). On the low volt side is also two smoothing capacitors (EC4 & EC5) with a inductor between. Both inductors are glued to a nearby capacitor to make it more stable if the charger is dropped.
DSC_1682 DSC_1683
DSC_1684 DSC_1685
DSC_1681 DSC_1698
The mains switcher (U1) is a rather small chip. On the low volt side is the synchronous rectifier (U2: Marked OSC7710) and two auto coding chips (U3 & U4)
DSC_1699
DSC_1697
The distance between mains and low volt side is well above 6mm.
Testing with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems.
Conclusion
The charger is nicely designed with low noise, good safety and auto coding. Only problem is that is has 3 USB outputs, but not much more power than one output can use.
Notes
Index of all tested USB power supplies/chargers
Read more about how I test USB power supplies/charger
How does a usb charger work?
chargerlover
hi HKJ,
Could you explain or make the same about the issue with high noise (rms/vpp) of a charger ? what is the impact of that issue ?
I saw a case you reviewed with rms/vpp = 67/949
https://lygte-info.dk/review/USBpower%20Aukey%20Dual%20Port%20Wall%20Cha...
you did not complain about the noise of that charger
BUT a case with rms/vpp = 48/520 , you mentioned :” The noise and temperature is a bit high” it means the value is not good.
https://lygte-info.dk/review/USBpower%20Tanggood%20USB%20Type%20C%20Char...
why did not you complain for Aukey’s case instead of Tanggood ? If Im not wrong, the Aukey PA-U32 must be the worse one and should remark the noise issue for that review instead of nothing.
Smile
Thanks.
