Test/review of PD trigger P30 (Hidance)
This device is a trigger to access PD voltages on a USB-C charger.
I got it from Aliexpress dealer: HIDANCE Official Store
There was no fancy packing or instructions included with the device, it was in a small plastic bag.
It will show output voltage, this is a measured value with low resolution.
Increasing the voltage will drop the decimal point.
When drawing current it will also show a measured current.
Measurements
  • The trigger will remember selected PD voltage without power.
  • It will enabled output voltage on a PD supply when connected.
  • For maximum current check the specifications of the used power supply
  • Power consumption of trigger is 5 to 6mA
  • Trigger uses 3A mode.
  • The USB output is not coded but passed the data line through to the USB-C connector
Holding down the up or down button will start a automatic voltage selection test sequence.
Voltage drop including USB-C and USB-A connections:
Minus: 0.116V at 3A -\> 39mOhm
Plus: 0.0973V at 3A -\> 32mOhm
This is a fairly low resistance and much of it is probably from the connections.
A closer look
The trigger do not have many parts. There are two USB-C input connectors, one can be plugged directly into a USB-C PD charger, the other requires a cable. Between them is a blue led that will turn on when the PD selection works correctly. The small square chip is probably a PD interface chip, the microprocessor is hidden below the display. For local power supply there is a voltage regulator (6203A).
The current sense resistor (10mOhm) is placed next to the USB-A output connector.
Below the display is not only the microprocessor, but also a EEPROM memory chip.
Conclusion
The display makes this trigger very easy to use, because it will always show the output voltage, but I do not like it uses a USB-A output connector. It makes it way to easy to connect 5V only equipment to it and damage the equipment.
Thank you for the review of this interesting PD trigger!
Do you know what is the maximum current allowed for each voltage?
