Interest collect for a new Sofirn design: tube style18650, magnetic ring control, USB-C charging, 500 lm max (AKA grandma light)
536 posts / 0 new
DeusLight
Last seen: 2 years 7 months ago
I’m interested in one as well.
Asian8640
Asian8640's picture
Last seen: 4 months 1 day ago
I’m really liking the look of this flashlight. However, I would like to input that although I like the mode spacing, though I think that 10/50/250 lumens would be a much better mode spacing. Due to how we perceive light, the differences between 400 lumens and 250 lumens ia negligible while the run time and thermal improvements from dropping high output below 1A would probably work more towards the intended audience. A BUCK driver would also be preferable for improved efficiency and regulation meaning the end user wouldn’t have to worry about charging it as frequently. Either way, put me down for 1 for now.
Old Lumens Contest Entries: "7th 5mm LED Lantern":https://budgetlightforum.com/node/70438 and "9th Copper Pipe Triple":https://budgetlightforum.com/node/79484
hank
hank's picture
Last seen: 1 month 6 hours ago
Speaking tangentially about illuminated canes for walking, well, of course they’re out there. Google finds several.
Here’s a flashlight sized to clip to a cane; removable; made of glow-in-the-dark material too.
https://www.fashionablecanes.com/grip-on-led-cane-light.html?nosto=categ...
And here’s a whole illuminated cane.
http://site.ambercity.com/images/mabis/pathlighter-lighted-cane-502-1387...
Apology for the digression.
djozz
djozz's picture
Last seen: 3 hours 29 min ago
Hi Jeff, thanks for your valuable contribution. You have many suggestions that I think are generally useful, some are usefull for seniors but also do not ruin the design for others, and some that I think are useful for the 75+ segment but would make the light less attractive for other people, since this is not strictly a light for seniors. And then there is cradle-charging that apart from making the charging less universal may just be too expensive
What I will ad to the wish-list:
*smooth bezel but with a few small cutouts that let light to the side when bezel-standing.
*a quality USB-C socket that allows some abuse. At least USB-C can not be connected the wrong way around.
*up for discussion but I like the idea: charging up to 4.1V instead of 4.2V to preserve battery life
*although I think black will be most popular, clear ano or other very visible colours should be an option. Already on the wishlist is the control ring in a contrasting colour.
*if it can be done attractively, a contrasting colour if the USB-port gets a cover.
What I doubt will happen, although I understand the reasons for easy handling and runtime: 21700 size. First because the many who are already on the interest list will not expect that change, but also because it will largely kill the possibility to pocket-carry the light, which I expect many will do once it is there (especially if a 18350 tube will happen).
I added you to the list in the hope that the design will end up to your liking Smile
djozz
djozz's picture
Although I agree that 250 lumen is plenty for most, and that it will add to heat safety and runtime, I think that less lights will sell to us flashoholics if the max is “just” 250 lumen. The 500 was chosen as a fairly safe maximum output that will still appeal to flashoholics.
djozz
djozz's picture
@hank, I totally missed the cane illumination subject sofar but please digress Smile
jeff51
jeff51's picture
Last seen: 1 day 4 hours ago
djozz,
Keep after this. It’s something that needs doing.
It should be available through Amazon.
There are lots of potential users that would skip the light if the only way to get one is PayPal and China direct.
All the Best,
Jeff
Jerommel
Jerommel's picture
Last seen: 2 years 6 months ago
Do you really think so? It only adds 5mm in length and 3mm in width and consequently a couple of grams.
I wonder if it makes enough difference for it to be beyond pocket carry-able. Maybe due to the weight increase, though.
But then again, come to think of it, i haven’t got a 21700 light yet.. Facepalm
Good excuse to get one ! Smile
I wonder if it will be as cute in a short version as short headed triple and quad lights.
But there are apparently 20350 batteries out there already (iJoy).
To me it doesn’t matter too much if it’s 18650 or 21700.
But, the difference between 3500 and 5000 mAh is considerable.
5000 is 42% more than 3500.
I’m mainly looking forward to the “volume knob” dimming of this light.
That would be awesome.
It’ll probably be the biggest challenge to get it to work properly, evenly and logarithmically.
With a short movement slider you can suffice with 1 single Hall sensor, but if you want to spread the dimming over a (let’s say, at least) 120° rotation, you’ll probably need 2 or 3 Hall sensors and some clever electronics and / or firmware to translate that to intuitively expected brightness levels, on a logarithmic scale.
In fact, i think it would be wise if someone already started experimenting with this.
hank
hank's picture
>cane illumination
I’m thinking of attention-getting lighting for use in pedestrian crosswalks where I now find strobe most useful.
But that illuminated cane I found uses those pathetic little 12v cells, not a robust rechargeable battery.
Including as an option something like the clips that attach flashlights to bicycle handlebars would be helpful to people using walkers or canes who would otherwise have their hands full carrying anything besides the flashlight.
Here’s a motion sensor light that attaches to a cane or walker:
https://www.amazon.com/Path-Light-Attachment-Automatic-Mobility/dp/B071Z...
Reading the reviews, that has a lot of useful features. Turns on when moved, turns off after brief timeout when not moving, turns the light off when entering an illuminated area like indoors or under streetlights. 3xAAA, the usual blue-white. $20.
Quote:
SmartSense technology turns ON the light in low light conditions and when the unit is in motion In the dark, the light stays on for 12 seconds after motion has stopped In the dark, when not in motion, the SmartSense technology will turn on the Night Beacon LED, making it easy to find your cane or walker in the dark
Moddable? I think I have to find out.
Agro
Agro's picture
Last seen: 1 month 1 week ago
Same here.
BTW, I don’t feel the need to limit output of a muggle light except for children lights (before a child is trained to not shine at other people) and extremely powerful lights. I’d rather give them 1500 lm lights than 500 lm ones.
djozz
djozz's picture
Same here.
I agree with that for flashoholics and some of my friends, but most people I know would get worried about how hot the light can get, and after that are surprised that the light starts dimming (“is it broke?”), assuming thermal regulation at these power levels, while in the course of the discussions in this thread I’m more and more convinced that this build should be a no-manual flashlight without surprises.
gman7228
Last seen: 1 hour 38 min ago
I’m interested in three as long as it turns out to be kid friendly which means not enough lumens to hurt the eyes. If we want to grow the flashaholic community, you gotta get ‘em early. Smile I like the ring control too. Clix aren’t for kids.
gman7228
There are 10 kinds of people in the world. Those that understand binary notation and those that do not.
abneustadt
Last seen: 1 year 8 months ago
Hi,
i´m interested in 4 pieces. A wish would be a charging docking and voltage only to 4-4.1V.
greets
André
figment
Last seen: 21 hours 34 min ago
I’m interested in 2 of these.
Airtrade
Last seen: 1 year 6 months ago
I would be in for 3 of these.
prototype3a
Last seen: 2 weeks 4 days ago
I would be interested in a few of these if it is a smooth, fairly floody beam. If it’s a deep reflector and a 300meter beam, I’m out.
slmjim
slmjim's picture
Last seen: 12 hours 2 min ago
Interested
slmjim
Smile! It makes others wonder what you've been up to.
Time is more valuable than money.
You can get more money, but you cannot get more time.
Lost time is never found.
djozz
djozz's picture
The current amount of flashlights interested in, BLF and TLF combined, is 375.
JoeH12.81
Last seen: 1 day 2 hours ago
I’m in for a couple. Very interesting and fills a need for many. In addition to the grandma’s of the world, I feel like this is aimed at young budding flashoholics who love Dad’s (or Mom’s) lights, just that none are child friendly.
Well done djozz, looking forward to more information as it becomes available.
cm02WS6
I’m interested in one.
This will be nice for the kids.
gottobegeek
gottobegeek's picture
Last seen: 1 year 1 month ago
I am interested,
concept photo would be nice, colors?
g
djozz
djozz's picture
gottobegeek wrote:
I am interested,
I’m afraid that there is nothing yet but specifications. On request of Barry yesterday I made a first structural drawing of how this light could be built and sent it to him. At a later stage I may post the drawing but I must first get the comments of this design back from Sofirn’s engineers, discussing something that will not happen anyway is not so useful.
polarweis
polarweis's picture
Last seen: 3 weeks 2 days ago
Interested
"It wouldn’t be so bright if there wasn’t a shadow every once in a while." - Jason Mraz
hodor
hodor's picture
Last seen: 2 weeks 3 days ago
Thought I had replied but guess not. In for at least one. Thanks djozz et al. Beer
justanotherguy
Last seen: 1 hour 11 min ago
HMM I might be in for 4.
at 500 lumens, what kinda run time on a 3500?
( I just found this 350 post thread)
djozz
djozz's picture
If a high CRI led is used like the LH351D, I estimate about 1.5A to get 500 lumen, so runtime will be a bit over two hours on the highest setting.
mitsuki08
Last seen: 1 day 13 hours ago
Interested in 1
algernonramone
Last seen: 1 year 9 months ago
Maybe I’m misunderstanding the concept, but will this kind of be like a larger, High CRI version of a Jetbeam RRT-01? If so, I am very interested!
djozz
djozz's picture
Good question, it depends on how Sofirn picks this up. If they decide for the infinitely variable ring (it requires a different fairly expensive, more than a dollar, magnetic sensor component, and designing the control for it what they have not done before), it is not far from a 18650 version of the RRT-01, albeit with a bit lower output. If they stick to distinct modes (which is electronically different, probably cheaper and already known to them), it may not look to you like the RRT-01. Mind that the distinct modes outcome is still very much within the scope of this project, for the project I would be happy with that (but I do hope a bit for the variable control because that attracts an extra category of buyers). I hope for a few answers after chinese newyear.
sandanbob
Last seen: 5 days 10 hours ago
Please add me to the list as a possible buyer.
