ReyLight copper pineapple mini, AAA/10440 flashlight, Nichia 219B 4500K R9080 high CRI LED
265 posts / 0 new
shirnask
shirnask's picture
Last seen: 43 min 47 sec ago
So far mine runs equally well on NiMH, or 10440 without any issues.
Rdubya18
Last seen: 3 hours 26 min ago
Rey says on his site what type and length batteries to use . There is even a pic to show what is acceptable, along with length measurement .
trailhunter
Can rey just tell us what is an approved make/model battery to use?
AstroTurf
Last seen: 11 months 1 week ago
Product Page and Info here:
https://www.reylight.net/product/reylight-copper-pineapple-mini-aaa-1044...
Firebird
Firebird's picture
Well I feel silly now. According to Rey’s site a button top shouldn’t even work yet here we are using them!
Edited my post from before.
Patina is starting to develop on mine and I love it.
And the tail switch feels good too.
AzzonFire.
Johnnyh
Johnnyh's picture
Hmmm...I took the info on the website to mean that some button top 10440 are too long as illustrated in the photos. Regular alkaline, Eneloops and Energizer lithium’s are all button tops ( at least the ones I have)  but not in the extreme as illustrated. I don’t think he meant to exclude the use of all button top batteries...at least I hope not!
ReyLight
ReyLight's picture
Last seen: 1 hour 6 min ago
id30209 wrote:
And there’s a report that new Reylight won’t turn on on NiMh, only alkalines…
Looks like Rey is going to be busy making changes to the driver.
PM coming.
ReyLight
ReyLight's picture
There are some troubleshooting or fix.
1. tighten or loose the pill a little bit. there might be some bad contact or short somewhere.
2. unscrew the head a little.
3. remove the tailcap and try again.
The switch is press-fit into a copper thing, the switch body is usually at a lower surface. picture below.
20200202115148
milk
milk's picture
Last seen: 1 day 9 hours ago
Received mine today, beautiful light!
Mine also won’t turn on with any NiMH battery I have, just the 10440 that came with it. Tried tightening/loosening the pill and that didn’t work. It won’t come on with the head loosened a bit either, like it is for some other users.
ReyLight
ReyLight's picture
That’s strange, I will dig it out.
gottobegeek
gottobegeek's picture
Last seen: 5 months 6 days ago
Ordered one
g
milk
milk's picture
I played around with loosening and tightening the pill some more, and found a spot where it seems to be working fine with NiMH cells now. I got it by loosening the pill a lot, tightening down snug (not tight)and then backing off just a hair.
Luminosity
Can anyone confirm that the LVP works for the 10440? I just found mine at 2.1V and I can’t be certain if I didn’t accidentally click it on and run it down. But even if I did, I would’ve expected it to stop around 2.8V or so.
id30209
id30209's picture
Last seen: 24 min 21 sec ago
And i also got mine at last.
sadly NiMh is not this light favorite... Sad
Looks like voltage is too low for the driver. Alkalines work great and Liion but NiMh is a no go.
WTB Titanium 4sevens 2xAA tube
shirnask
shirnask's picture
sadly NiMh is not this light favorite… Sad
That’s odd, NiMh is what I use without any issue
id30209
id30209's picture
I did manage to get it lit on NiMh but only up to 2nd or 3rd mode then it just went OFF.
First batch of drivers... Rey will fix it with second one.
Oh yeah i forgot to mention i’ve placed Lumintop IYP365 with 219B and 2xEneloopAAA next to Pineapple Mini with Efest 10440 and guess what, it’s not nearly brighter than on Alkiline.
So yeah, max is not nearly bright as it should be on 10440
ReyLight
ReyLight's picture
Sorry for late reply. The Coronavirus is delaying everything. I have asked the factory to retest the output. Then I have realized there was a mistake, the sample was 219C LED, which had 300 lumens.
mini-219C-001
mini-219C-002
mini-219C-003
mini-219C-004
mini-219C-005
mini-219C-006
mini-219C-007
ReyLight
ReyLight's picture
Will post the pics for 219B soon.
ReyLight
ReyLight's picture
219B, 240 lumens.
mini-219B-001
mini-219B-002
mini-219B-003
mini-219B-004
mini-219B-005
id30209
id30209's picture
Yeap, that’s more like it. This emitter is pushed hard if it’s 300+lm.
What about NiMh issues?
ReyLight
ReyLight's picture
Going to post about this. Some of the NiMH battery has high inner resistence,  the low voltage might not active the MOS and not work prefectly.
20200217183605
ReyLight
ReyLight's picture
We might need a lower threshold for future.
id30209
id30209's picture
We also need updated present batch of mini’s.
ReyLight
ReyLight's picture
Sorry for the late reply. If your light is faulty, I will send you a new driver with new MOS mounted. Pls pm me your order number or email address.
jasontheguitarist
Last seen: 28 min 57 sec ago
I just got mine from Countycomm. Didn’t work at all out of the box. Removing the metal part of the switch and pressing the plastic switch directly gets the light to come on in one mode unreliably. Sometimes it does, sometimes nothing. Putting the tail switch end back on all the way gets nothing every time. Same with 10440 and AAA. I don’t know what’s up with it, I don’t want to take it apart and start screwing with it, I’m just going to ask Countycomm for an exchange and hope they are easy to deal with.
ReyLight
ReyLight's picture
There is a plastic insulating piece in the head, have you removed it?
jasontheguitarist
Yea I took the little white disc out first thing.
At this point it seems like there’s a problem with the driver. I was able to screw the head of the Reylight onto a different AAA light body to test and the Reylight will only turn on in high mode, mode switching and programming don’t work.
The button on this one also seems strange, the tail cap with the metal part of the button has to be loosened almost until it falls off before the button press activates the light (but still only in high mode only)
ReyLight
ReyLight's picture
This piece should be screwed in tightly. Otherwise, the tailcap will give too much pressure to the switch. Pic below.
20200202115148
Only high mode, I think there is a short in the head, pill assembly or driver. You can use tweezers to tighten or loose the pill a little and try again.
The quickest option is to contact CC, I believe they are happy to replace. If no, I will do.
DarkShot
DarkShot's picture
Last seen: 2 days 22 hours ago
Rey, do you have plans for a titanium Pineapple Mini?
Tixx
Love the AAA Moonlight! The 10440 is a bit bright. Also would love a recessed button. Overall an awesome light!
