Test/review of CinkeyPro 5V 4 port 4A
1 post / 0 new
HKJ
HKJ's picture
Last seen: 8 hours 25 min ago
DSC_0762
Official specifications:
  • Input voltage: 100-240 V 50-60Hz
  • Output: 5.0V 4A
I got it from Aliexpress store: CinkeyPro Phone Accessories Shop Store
DSC_0761
It is a cheap charger and as usual it is in a envelope without anything else.
DSC_0763 DSC_0767
DSC_0764 DSC_0765
DSC_0766 DSC_0768
Measurements
  • Power consumption when idle is 0.16 Watt
  • Top row of USB output is coded as DCP
  • Android marked output is coded as Samsung 5V
  • IOS output is coded as Apple 2.1A
  • The outputs are in parallel.
  • There is a led behind the green plastic.
  • Weight: 50g
  • Size: 76.4 × 52.4 × 32.0 mm
CinkeyPro%205V%204%20port%204A%20%231%20230V%20load%20sweep
The charger can deliver about 3.3A on a port, not the rated 4A.
CinkeyPro%205V%204%20port%204A%20%234%20230V%20load%20sweep
Another port is the same.
CinkeyPro%205V%204%20port%204A%20230V%20load%20sweep
All ports together is also the same
CinkeyPro%205V%204%20port%204A%20120V%20load%20sweep
And output current is also the same at 120VAC.
CinkeyPro%205V%204%20port%204A%20230V%20load%20test
The charger can deliver 3A for one hour.
The temperature photos below are taken between 30 minutes and 60 minutes into the one hour test.
Temp7155
M1: 60.5°C, HS1: 64.2°C
Both M1 and HS1 is the transformer.
Temp7156
M1: 44.5°C, HS1: 70.4°C
HS1 is the circuit board, heated by the transformer and maybe the rectifier IC.
Temp7157
M1: 66.2°C, HS1: 69.4°C
Temp7158
HS1: 59.1°C
Temp7159
M1: 50.3°C, HS1: 59.7°C
10ohm
At 0.5A the noise is 18mV rms and 172mVpp.
5ohm
At 1A the noise is 51mV rms and 322mVpp.
2ohm
At 2.5A the noise is 33mV rms and 198mVpp.
Tear down
DSC_0794
Using my vice to apply some pressure just below the green band broke the glue and I could open it.
DSC_0795
At the input is a fusible resistor (F1) , the switcher IC (TD6520), beside the transformer is the safety capacitor. Around the USB connectors are 3 leds for lighting the green band.
DSC_0797 DSC_0798
DSC_0799 DSC_0800
DSC_0796
On this side is the bridge rectifier (BD1) and a synchronous rectifier chip (U2: TC730). There is also 3 more leds for the green band.
DSC_0801
DSC_0802
The distance between mains and low volt side must be above 6mm, here it is more like 3mm.
There is another issue with safety, the wires connecting the circuit board to the plug can touch the low volt side, not very safe.
Testing with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems.
Conclusion
The rated 4A current is on the low side for four outputs, but the charger cannot even deliver the rated current and safety is not very good either.
Notes
Index of all tested USB power supplies/chargers
Read more about how I test USB power supplies/charger
How does a usb charger work?
