Test/review of Samsung 1 port EP-TA20EWE (Maybe fake)
1 post / 0 new
HKJ
HKJ's picture
Last seen: 1 day 1 hour ago
DSC_1019
Official specifications:
  • Input: 100-240V 50-60Hz 0.5A
  • Output: 9.0V-1.67A 5.0V-2.0A
  • MODEL: EP-TA20JWE
I got it from ebay dealer: swoy1753
DSC_1018
It was on a plastic bag inside an envelop.
DSC_1020
DSC_1021 DSC_1022 DSC_1023 DSC_1024
DSC_1025 DSC_1026 DSC_1027
Measurements
  • Power consumption when idle is 0.1 Watt
  • USB output is coded with DCP and QC2 (5V & 9V)
  • Weight: 35.4g
  • Size: 76.0 × 37.7 × 27.8mm
Samsung%201%20port%20230V%20load%20sweep
It can deliver 3.5A at 5V, that is rather high for a 2A charger.
Samsung%201%20port%20120V%20load%20sweep
The output power is lower at 120VAC, but still well above the rated 2A
Samsung%201%20port%20QC9V%20230V%20load%20sweep
At 9V it can deliver about 2.2A.
Samsung%201%20port%20QC9V%20120V%20load%20sweep
And slightly lower with 120VAC input.
Samsung%201%20port%20QC9V%20230V%20load%20test
The charger could deliver 9V at 1.66A for one hour.
The temperature photos below are taken between 30 minutes and 60 minutes into the one hour test.
Temp7350
M1: 73.0°C, HS1: 80.5°C
Temp7351
M1: 83.6°C, HS1: 86.4°C
Temp7352
M1: 70.3°C, M2: 52.4°C, HS1: 73.4°C
Temp7353
HS1: 80.0°C
Temp7354
M1: 44.4°C, HS1: 79.7°C
10ohm
At 0.5A the noise is 18mV rms and 529mVpp.
5ohm
At 1A the noise is 21mV rms and 467mVpp.
2ohm
At 2.5A the noise is 25mV rms and 410mVpp.
10ohmQC9V
At 0.9A the noise is 25mV rms and 635mVpp.
Tear down
DSC_1806
Putting a lot of pressure on the top of the charger with my vice made the lid pop out.
DSC_1807
On this side is the input fuse (F01), a MOV (TM01), a common mode coil, two mains smoothing capacitors (C01 & C02) with a inductor (L01/L02) between and a mains switching transistor (Q01).
There is the usual safety capacitor (CY01), partially isolated behind a plastic shield
DSC_1809
DSC_1810 DSC_1812
DSC_1811
DSC_1808
Here is the bridge rectifier made with four diodes (D01..D04), the mains switcher controller (U01), opto feedback (OP01), the protocol controller (U02) and a reference (U3: 431). The rectification is a normal diode (D21).
DSC_1813
DSC_1814
The distance between mains and low volt side is about 5mm, this is on the low side.
DSC_1815
Because one PCB track goes under the opto couple the distance is down to 4mm there.
Testing with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems.
Conclusion
These chargers are usually cheap imitations of the original Samsung, but I got a bit surprised when the QC only went to 9V (This is Samsung protocol) and the teardown shows a rather complex design with better isolation than many cheap chargers, but it is not good enough. The overload protection is at a too high level for a 2A charger.
I do not hope Samsung has ever sold this model, the isolation is not good enough.
Notes
Index of all tested USB power supplies/chargers
Read more about how I test USB power supplies/charger
How does a usb charger work?
