Lumintop has a new small keychain style light on the market that’s using using TurboGlow as part of the heads structure. It has a built in battery and microUSB recharging. Thanks to Lumintop for sending this to me to review.
View this review on YouTube at:
Join the Facebook Page: https://www.facebook.com/LiquidretroReviews/
Follow me on Instagram: https://www.instagram.com/liquidretro/
Packaging & Accessories
The light comes in a small nicer cardboard box with foam holding it in place. It comes preinstalled with the non removable battery. Accessories include a short 5” USB-A to Micro USB cable and a split ring attached to a small chain and clip for attaching to your keys or other device.
Construction
The Glow I is made from aluminium and works off a twist design but is different from some other similar lights. First the tail cap is removable, and held in place with an internal neodymium magnet and indexing notches. Pull force to disconnect here I would guess is about 5-6 pounds. I think this is sufficiently strong for many scenarios but if you were concerned about it coming off accidently a bit of superglue or JB Weld would make this more permanent.
I found the magnet here to be actually really nice. It means the light could server as a short under the hood light in your car at night if needed etc. The body of the light has a hole in the side the body is twisted all the way to the left reveals the microUSB charging port. There is a small internal LED in the port that goes red when charging, green when charged.
To operate the light you screw it to the right until it turns on. The light has only 1 mode and no UI to speak of. The head is captured so you don’t have to worry about it getting loose or lost during charging which I know has been a minor issue with other similar lights. The internal 80mAh 10180 battery is sealed and not replaceable.
The turbo glow barrel built into the head of this light, and serves as the walls of the reflector, meaning it’s directly exposed to the LED anytime it’s on. This means it gets charged up everytime the light is on, and since it’s turbo glow it’s much brighter and lasts significantly longer then standard glow in the dark material. It even does a pretty good job of charging and maintaining charge during normal exposure to room or sunlight.
Size & Weight
This is a small light, similar to the Olight i1R I reviewed a while back. It’s currently been my keychain light. I measured the length of the Lumintop Glow I at 45.3mm, maximum diameter around the turboglow at 15.6mm and minimum diameter on the body at 14mm. Weight was 16.4g without the keychain. It’s pretty comparable in size and diameter to the Olight i1R. See the photos below for other peers.
LED & Beamshot
The Glow I uses an Osram LED. No specific model or temperature is given but no surprise here, it’s cool white. Lumintop lists the output officially has 40 lumens. This is more than sufficient with the size and application here. The light is using an optic with a built in diffuser. The result is a pretty standard beam, floody, good for short range which is what you would expect with this light.
Runtime
Runtime here out of the 80mAh battery was better then I expected. My total runtime was around 80 minutes, with the first 60 of that being near the 40 lumen mark and declining. The light actually ran significantly longer but it doesn’t have low voltage protection so it would be best after you notice the decline in output to charge it.
Recharging
Charging took 1 hour and 10 minutes and the fastest I observed was 0.12A via the microUSB port. While that’s pretty slow this is a very small battery so that’s what you would expect.
*Pro’s *
- Turboglow from the Netherlands is integral to the design and is really pretty effective.
- Captured head although in theory the tail could come loose unintentionally.
- Good size and construction
Con’s
- No Low Voltage protection here, or removable battery means you need to be careful about running the light too long and keep the battery topped up.
- Non removable/replaceable battery
Conclusion
This is a neat little keychain light. I like that it’s small and compact but still has a decent amount of output for its size and task. The addition of authentic TurboGlow (Seriously if you have not tried TurboGlow it’s significantly better then any other GITD material) separates this light from the competition for me. It’s a clever design making the TurboGlow an actual part of the light body vs just an insert. I wish the light did have LVP to protect the internal cell since it cant be changed. The magnetic connection here is a give and take, it’s handy but if your concerned about the light dropping off unintentionally it’s an easy fix with some superglue or JB Weld. I don’t think it will be an issue for me. Overall let me know what you think of the Lumintop Glow I in the comments section!
Full Image Gallery: https://imgur.com/a/FU0HES3
Lumintop’s official website for the Glow I: http://www.lumintop.com/glow1.html
