[Review] YLP Unicorn 1.0 (Samsung LHD351D, 90 CRI, 18650 EDC Light)
8 posts / 0 new
liquidretro
Last seen: 2 weeks 4 days ago
YLP is a Russian Flashlight manufacturer (Lights are made in China) that is new to the US market. Their name when translated roughly means bright ray. They have been known by enthusiasts for a few years but it’s been more difficult to buy their lights, having to use google translated versions of their website. Recently they have launched a US English version of the website and got in touch with me to take a look at some of their lights. The YLP Unicorn 1.0 has been on my radar since last year so I selected that to take a further look at and review myself. Thanks to them for sending this out and providing a discount that’s in the description along with links to follow me on various social media platforms. This will probably be a little bit longer of a review so settle back and enjoy.
YouTube Version of this Review:
Join the Facebook Page: https://www.facebook.com/LiquidretroReviews/
Follow me on Instagram: https://www.instagram.com/liquidretro/
Packaging & Accessories
Packaging on the Unicorn 1.0 is a nice magnetic closure box full of printing, showing the light on the front, a lot of the highlights on the sides and more details on the back. It’s nicely designed without looking excessive. Inside the light is protected with some custom cut black foam. Accessories include a pocket clip preinstalled, a basic lanyard, and 2 extra o’rings. The manual that came with the light is in borth Russian and English. It’s pretty thorough but an advanced manual is available online as well and I will have a link to it in my description. One other thing to add, my light shipped in a box covered with cool Russian stamps on it too, definitely cool looking and not what I am used to.
Construction
The light is made from aluminum and hard anodized in a gray/brown almost tan color. It’s a really nice color and nice to see something other then black. Machining here is good, with no complaints. Branding is extremely minimal with just the Unicorn 1.0 name and Unicorn logo on the rear of the tail cap, it doesn’t even say YLP on it anywhere!
The tailcap itself is flat, and magnetic. The internal magnet is held in place with the tail spring so if you want to remove it, it’s easy to do so. You have a place for the lanyard to go on the side of the tail cap if you choose. Threads internally are beefy and square cut.
The knurling on the tail and body tube is aggressive, it feels good in my hands but you may see some accelerated wear of your pants under the pocket clip. It’s pyramid shaped with the tip left on. There is a Y shape milled out of the knurling to add some style to the light, you can see some tool paths in this but I think that’s done on purpose. The tube itself is not removable as it seems to be glued to the head.
The head itself has shallow heatsyncs around about ¾ of the range. The button sits in a slightly raised block on the head but is then recessed inside this. The button itself has a clear silicone cover over it. Underheat there are red and green LED’s used for indicating battery voltage and as a locator beacon. The buttonself is on the small side and may be a little hard to actuate with larger gloves on. The front of the light has a smooth bezel with the TIR optic in place. There isn’t glass over the optic so you may see some scratches over time.
Size & Weight
The YLP Unicorn 1.0 is a pretty compact light for what all it offers. I measured it’s overall length at 102.2mm, maximum diameter in the head at 27.20mm, and minimum diameter on the body at 25mm. When compared to the FW3A is about 20mm shorter, and the Wurkkos FC11 is about 14mm longer. The Unicorn 1.0 weighed in with a Sony VTC6 battery and clip onboard at 113.6g. Compared to the FW3A’s 98.2g, and Wurkkos FC11 at 111.8G.
Retention
The Unicorn 1.0 features a reversible pocket clip with plenty of room in it’s top loop for thicker pants. It’s not super deep cary but I found it to carry quite well. As I mentioned earlier the knurling here is aggressive and while I like the feel in my hand, you might find it wears out your pants pocket a little faster them most lights, especially under the pocket clip. The magnet in the tail is quite strong and has no trouble holding the light. It’s also fairly easy to remove if you wish. I had no issues with it activating in my pocket during cary thanks to the recessed e-switch on the head of the light.
LED & Beam
The YLP Unicorn 1.0 is using a 4200k Samsung LH351D at a minimum of 90 CRI. This is one of my favorite emitters right now and a fantastic choice for EDC in my opinion. It’s warmer in tint and doesn’t have any of the green that the LH351D in the Wurkkos FC11 had. My LED was nicely centered, and has a TIR style optic. The light doesn’t have a glass lens, which means overtime you might see a few scratches. Not a huge deal with everything else going on here. The beam pattern does have a defined hot center, and the transition to the spill isn’t the smoothest but it’s not bad either.
One of the side effects of this light not being designed for huge output numbers is heat is well controlled and it’s also configurable in the UI if you want to push it a bit more.
1 Minute = 90F
5 Minutes = 101F
10 Minutes = 104F.
I measured the parasitic drain of the eswitch at 22μA which is pretty minimal. I didn’t measure any PWM with my scope or eye.
Runtime and Outputs
Officially the light produces the following in it’s default UI. .
Turbo 850 lumens
High 450 lumens
Medium 170 Lumens
Low 40 Lumens
Moon 3 Lumens
Runtimes here didn’t have any big surprises from the regulated driver. I performed my tests with a 3000mAh Sony VTC6 battery but you don’t need such a high output battery in this application, a NGR18650GA battery would be a perfect combination here. Turbo was good for just under 4 minutes, and we then saw stepdowns to 65% relative output. This continued to decline to about 50% output at the 30 minute mark or so but then the light started increasing in output as it cooled and the battery was able to keep up. This peaked at 60% relative output before a sharp decline to the lights lowest mode at the 130 minute mark where it continued running till LVP kicked in at 2.859V at 300 minutes. It’s nice to see active thermal controls on this one.
UI This light has 4 different UI modes. By default it comes in what YLP calls Basic UI where the light has 5 discrete modes and memory mode turned on. It starts off in low and when you hold the button it starts ramping up about every second. When it gets to the top it automatically starts ramping down. Single click to turn off, Double clicking when on gets your to the maximum output. 4 Clicks gets you to battery check mode where the light flashes the batteries voltage. The way the basic UI works with it cycling up and then down instead of resetting takes a little getting used to as it’s different from a lot of lights and requires you to go up through high before going lower if thats what you want.
The other main UI modes are UI1, which is ramping with memory mode turned on. UI2 which is ramping with memory on and the buttons light on, UI 3 is 5 modes, memory off, and starting on medium instead of low.
The light has other advanced features which are best if you look at the advanced manual on the YLP website as you can adjust the thermal settings, and engineering mode where you can configure each UI mode through a series of clicks. These are complex and for time sake I won’t go over them in this review, but the manual has you covered and the translation is decent. You can find the advanced manual here.
Pro’s
  • Great overall size and clip
  • Wide acceptance on it’s battery type, flat tops, button tops, protected, unprotected it takes all the 18650 types.
  • Not another black light
  • Great LED and Tint
  • Very flexible user interface the default Basic UI does it for me just fine but ramping is available if you want it.
Con’s
  • Knurling is quite aggressive, and if EDCed in a pants pocket this will eat away at it over time.
  • Not the brightest light in this class but more than enough to get the job done with less heat and more usability.
  • Lowest output mode should be 1 lumen or less
  • Minor annoyance with the Basic UI, I would prefer it start back over on low after reaching top output rather then reversing back down through high, mediu, low etc.
Conclusion
This is a light designed with practicality in mind instead of big numbers for a marketing purpose. As a result it can sustain itself on higher outputs without large stepdows. It’s using a high CRI LED with a pleasant tint and very useful beam pattern. For me it ticks all the boxes on what I want as a solid all purpose flashlight.
I have taken it walking several times over the few weeks I have had it and it’s done great with that. It’s a useful beam pattern and I like the combination of tint and high CRI LED. It has a lot of UI options for you if you want, if not the default UI I enjoy.
I hope we see YLP continue the Unicorn line of lights, making enhancements and tweaks as it goes along. At this price point it’s a lot of value, coming in significantly less than some of the well known brands that also share animal names. I look forward to seeing other lights from YLP, after reviewing the Unicorn 1.0 the bar was set high, lets see what they can deliver. I recommend the YLP Unicorn 1.0 without reservations.
Full Image Gallery: https://imgur.com/a/rEswFKr
Lightbringer
Lightbringer's picture
Last seen: 15 hours 43 min ago
Looks nice! And 4200K is a nice CT, too.
bassoverflow
bassoverflow's picture
Last seen: 5 days 1 hour ago
I really like the look of these.
I would love to see a direct comparison with a Zebralight SC64C LE.
Quadrupel
Quadrupel's picture
Last seen: 2 days 15 hours ago
This is a budget cheap machining , linear driver flashlight. For this money you can buy new model of skilhunt M200 which have a buck driver , charger and looks great.
andyxxx
Quadrupel wrote:
This is a budget … flashlight.
– Yeah!
With VERY cuustomizable UI and good hiCRI light.
Quadrupel wrote:
… you can buy … skilhunt M200
without that features Big Smile
Lumeniac
Lumeniac's picture
Last seen: 10 hours 21 min ago
aha..linear driver, you say?
alpg88
Last seen: 2 weeks 4 hours ago
i like the tail threads,. beautiful threads, the best threads
SammysHP
SammysHP's picture
Last seen: 1 hour 33 min ago
Yes, it’s a regulated linear driver.
